Galant VR-4 Forums » Galant VR-4 » Technical Discussions » MMCd Logger
MMCd Logger
Invader
Galant VR-4 org Post #: 372728 posted 08/21/06 04:01 PM     Remind Me!  Send Private Message   Edit Post
Since we were begining to take over the other thread...
Available MMCd forks that I know of...
v1.5d available from the SF page...
http://mmcdlogger.sourceforge.net/
v1.71.x available from Andrew Shin's page (based on an older Clint Batters fork)...
...this is what I used as a basis for my project as it appears to be the newest publically available source code...
http://www.ecimulti.org/mmcd/
v1.8g WITHOUT sourcecode from Clint Batters (longer playing nicely with the GPL)...
http://www.3si.org/forum/showthread.php?t=203226
http://my.fit.edu/~sschaefe/MMCd/
Also...it would appear that MMCd was pulled apart in an attempt to make it multi-vehicle compatible. Seperate display format and communication modules? I can't read Russian...and it's a much older fork (even though it's v2.2.2).
http://sh093.meditprofi.ru/
I'm waiting for responses to a post on the DSM-ECU list before I release/host my updates to Andrew's fork...
As far as what you'd need to get started playing with the code? Depends on what platform you're coding in. I run Linux, so my experiences may differ a bit...but all I needed was the Palm v5 SDK, the Handspring SDK (not so easy to find...and not really necessary except for one line of Handspring compatibility code), GNU GCC, PRC-TOOLS, PiLRC, and POSE (Palm simulator for testing).
Some changes I've made...
I saw a lot of potential for MMCd as a starting point for a configurable ECU project...which is the reason for the ECU Settings dialog. The ECU Settings menu is waiting on another post to the DSM-ECU list before I make it functional...but a configurable ECU setup is well within the scope of the E931 image project (maintaining factory compatibility, of course). But that's another discussion for another list...
| | | IP: (69.247.33.65) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 372733 posted 08/21/06 04:08 PM     Remind Me!  Send Private Message   Edit Post
I smell a How To...
-Cy
Posts: 8938 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (24.61.18.197) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 372744 posted 08/21/06 05:24 PM     Remind Me!  Send Private Message   Edit Post
I have read your posts on DSM-ECU. I certainly support your effort to tailor this program more to the DSM world. I wish I could help you in your efforts. I am at a loss with code and am only just beginning to understand the basics with the help of the members on the DSM-ECU forum. There are many members on here who are well versed in the ECU code. Some are members of DSM-ECU as well. I hope you can follow this through and please keep us informed. As has been stated many times by the members here, after having the caps. released in the ECU, the next most important modification is a logger. Thank you for your efforts.
Scott
525
Posts: 2054 | From: Norwell, MA | Member Since: 07/24/04 | IP: (71.232.41.40) | Report this post to a Moderator
Josh Weaver
Galant VR-4 org Post #: 372771 posted 08/21/06 06:31 PM     Remind Me!  Send Private Message   Edit Post
+1 on the How-to. Looks like you've made some handy changes to the program. I too have been a fan of the MMcD program and would love to see some updates. I wonder if I would be able to peck away at some code.
-Josh
| | | IP: (24.193.237.105) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 372867 posted 08/21/06 09:59 PM     Remind Me!  Send Private Message   Edit Post
I've got a ton of convenience mods in mind and I would really like to help out with getting the iQue compatibility going. I'm directionally challenged so I would be in geek heaven with GPS and a logger.
Ryan Hertz
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (67.162.67.211) | Report this post to a Moderator
Invader
Galant VR-4 org Post #: 372900 posted 08/21/06 11:38 PM     Remind Me!  Send Private Message   Edit Post
...I could use a few testers... Preferably have used different loggers (looking for insight). A warning, though...my sensor list is rearranged, so it's *NOT* compatible with the logs from older versions of MMCd...and that will change again before very long as there is lingering proprietary hardware support in the sensor list... The sensor order is one of the things I'd like some consensus on before releasing, as it's sorta set in stone for the near future...
If you're willing to test, just reply here and I'll PM info tomorrow...
I'll also post specifics on SDK's and such then...I know it's more fun to play when you can get your hands dirty.
Need sleep...will post more tomorrow...
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 372904 posted 08/21/06 11:49 PM     Remind Me!  Send Private Message   Edit Post
i'm interested. Also interested to find out if you have any opinions on how hard the code is to work with, especially since you went from palm to handspring. Obviously you're a linux guy, but given what you've gone through now, what kind of difficulty do you think it would be to port this to .NET (windows mobile devices, laptops, etc). I'm more interested in that, than anything else. I'm not great at it, but I happen to work for a .NET dev shop, so i can wrangle some help that way.
-andrew
{witty signature}
#461 Kensington Grey - 2.4L/T67/etc
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3724 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (24.19.242.70) | Report this post to a Moderator
Paul Mc369
Galant VR-4 org Post #: 372911 posted 08/22/06 12:32 AM     Remind Me!  Send Private Message   Edit Post
I really like where this is going. I hope it all works out.
As far as the ique thing. I have put myself in a position where I could no longer work on the project. I have passed it on to s_firestone. He is more capable than myself. I'm sure he would gladly accept any help offered though.
| | | IP: (128.61.43.156) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 372929 posted 08/22/06 05:12 AM     Remind Me!  Send Private Message   Edit Post
John,
I would be happy to help by testing. It does not matter to me if the new version is not backward compatable. All of my previous logs are sent to the PC and saved as Excel spreadsheets. I am presently using Ver. 1.8 and 1.71 on a Palm Vx.
Scott
525
spoulson
0 people like this
Galant VR-4 org Post #: 372937 posted 08/22/06 06:20 AM     Remind Me!  Send Private Message   Edit Post
Palm OS 3.5 Development -- Part 1, Introduction to Palm OS
Palm OS 3.5 Development -- Part 2, HotSync Conduits
Shawn Poulson*
  ʇuɐlɐƃ ɐ suʍo ɹǝƃuol ou *
Posts: 2907 | From: Middletown, DE | Member Since: 02/05/03 | IP: (63.113.210.11) | Report this post to a Moderator
powerplay
Yes Man
525/2000
Galant VR-4 org Post #: 372953 posted 08/22/06 07:01 AM     Remind Me!  Send Private Message   Edit Post
Thanks Shawn!
I have bookmarked those sites and I will read all of the information.
Scott
525
77/2000
Galant VR-4 org Post #: 373143 posted 08/22/06 01:59 PM     Remind Me!  Send Private Message   Edit Post
I'm in too, for sure.
Ryan Hertz
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (69.209.93.194) | Report this post to a Moderator
DarkDevilMMM
if I want a potential headache, I rather just get another GVR4
335/1000
Galant VR-4 org Post #: 373162 posted 08/22/06 02:25 PM     Remind Me!  Send Private Message   Edit Post
I have been thinking to rewrite everything in WinCE version or windows mobile edition. Since palm is dying and most of the smart phone nowadays start to use the mobile edition. it would be cool if we can just use our cell phone to log, or some newer device that's on the market. but hey, I am always thinking, can't really get my lazy ass off. anyways, hope u all succeed, don't be as useless as I am.
huh?
Posts: 4065 | From: Vacaville, CA | Member Since: 06/08/01 | IP: (158.96.4.13) | Report this post to a Moderator
Invader
Galant VR-4 org Post #: 373187 posted 08/22/06 03:08 PM     Remind Me!  Send Private Message   Edit Post
Yes, the Palm is pretty much dead...but that makes them cheap (err...affordable?) on eBay.
And I don't know about logging on my cell phone...it's too small to be useable for me...although I certainly dig the geek factor.
I only wish I had a color Palm...would make multiple graphs easier to read...
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 373332 posted 08/22/06 10:26 PM     Remind Me!  Send Private Message   Edit Post
I'm willing to test, I have both a Palm M505(color) and the afore mentioned Garmin IQue 3600. I also have the full MAX232 TTL to RS-232 circuit installed in the car. I may also have a Tungsten I can obtain to test.
Stephen Firestone
1992 GVR4 #918 of 1K
Edited by s_firestone (08/22/06 10:27 PM)
Posts: 1610 | From: Park City, UT USA | Member Since: 06/27/02 | IP: (24.170.24.226) | Report this post to a Moderator
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 373339 posted 08/22/06 10:39 PM     Remind Me!  Send Private Message   Edit Post
Ran that page through Babelfish, if the link doesn't work go to Babelfish on Altavista and translate the url from russian to english.
Translated MMCd page on sh093.mediprofit.ru
Stephen Firestone
StreetThisVR4
what a mouthfull
Galant VR-4 org Post #: 375564 posted 08/28/06 10:20 PM     Remind Me!  Send Private Message   Edit Post
I would also be willing to test, I don't have a nice palm but it works fine with the old version of MMCD that was on it when I got it. It should probably work, and I love the idea of a stutter-box and anti lag
Edited by StreetThisVR4 (08/28/06 10:22 PM)
Posts: 780 | From: Akron, Ohio | Member Since: 06/26/05 | IP: (70.39.139.78) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 376802 posted 08/31/06 12:21 PM     Remind Me!  Send Private Message   Edit Post
bump
Ryan Hertz
Rock Star Status
Galant VR-4 org Post #: 376827 posted 08/31/06 01:07 PM     Remind Me!  Send Private Message   Edit Post
i'd also be happy to test. i have used every version thus far, and have been excited about what will come next. my input may be minute in comparison to some of the more technical minded, but there are some things that i would like to see changed. i'm open to almost anything at this point...just would like to be of some help...
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (68.109.207.53) | Report this post to a Moderator
stevetford
Galant VR-4 org Post #: 393691 posted 10/13/06 11:15 PM     Remind Me!  Send Private Message   Edit Post
Anyone know where else I might be able to download the 1.8 version? I want to be able to log boost! I have tried to join the 3si.org site, but it will not allow me to use my e-mail address.
Edited by stevetford (10/13/06 11:16 PM)
| | | IP: (65.248.155.107) | Report this post to a Moderator
Gordian79
teh Gaugemaster
Galant VR-4 org Post #: 396194 posted 10/19/06 09:50 PM     Remind Me!  Send Private Message   Edit Post
Any updates on this new version?
#14/1000 SOLD
Riding EVIL 8 nowadays.
Posts: 2839 | From: Bronx,NY | Member Since: 05/01/05 | IP: (69.121.173.70) | Report this post to a Moderator
JSchleim18
Minor 69er
1157/2000
Galant VR-4 org Post #: 399805 posted 10/29/06 03:51 PM     Remind Me!  Send Private Message   Edit Post
If you copy the link of the website, you go to babelfish and translate the website from russian to english, does it all for you!
-Jeremy
A88 Summit White - CD (No Sunroof)
Posts: 4738 | From: Long Island, NY | Member Since: 10/16/06 | IP: (152.163.100.74) | Report this post to a Moderator
JSchleim18
Minor 69er
1157/2000
Galant VR-4 org Post #: 399806 posted 10/29/06 03:52 PM     Remind Me!  Send Private Message   Edit Post
sorry firestone i didn't notice you did this already
-Jeremy
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 402320 posted 11/04/06 07:57 AM     Remind Me!  Send Private Message   Edit Post
I'm waiting on an update from Invader. The version has some technical enhancements I have not seen in the other forks. It still has a few minor bugs in it (totally usable and stable though).
Stephen Firestone
customf4i
Galant VR-4 org Post #: 413576 posted 12/03/06 01:19 PM     Remind Me!  Send Private Message   Edit Post
thought about getting the palm trio cell phone if i could log on it.. can get one kinda cheap.. would be nice
| | | IP: (76.187.99.203) | Report this post to a Moderator
Pages: 1 | 2
Generated in 0.096 seconds in which 0.055 seconds were spent on a total of 14 queries. Turbo powered.
