Galant VR-4 Forums » Galant VR-4 » Technical Discussions » fuel gauge, continuity
SleepinGVR4
What are we going to do today Ferb?
629/2000
Galant VR-4 org Post #: 366910 posted 08/05/06 04:15 PM     Remind Me!  Send Private Message   Edit Post
How would u test your fuel guage on your sending unit for continuity to make sure its working right?
Sean
Posts: 2483 | From: Danville, Pennsylvania | Member Since: 02/12/03 | IP: (24.115.169.229) | Report this post to a Moderator
TonyNZ
Galant VR-4 org Post #: 367011 posted 08/06/06 12:48 AM     Remind Me!  Send Private Message   Edit Post
Quick tests:
1. short out the wire that goes to the sender to any convenient ground. The gauge will then go (slowly) all the way over to 'F' if it and its wiring are OK. If not, check the continuity of the wire from the sender up to the gauge, and of course check all fuses to be sure power is getting to the gauge.
If that test passes, the sender is dead.
2. disconnect the sender from the loom at the plug, connect a multimeter set to 'ohms *1' range between the sender wire and ground. It should show a fairly low resistance in the order of tens of ohms, which varies down to nearly zero for a full tank. You may want to pull the sender out so you can operate the float by hand to check that the resistance varies smoothly with angle.
That should help you localize the problem.
| | | IP: (219.89.29.73) | Report this post to a Moderator
0 registered and 31 anonymous users are browsing this forum.
Generated in 0.115 seconds in which 0.097 seconds were spent on a total of 14 queries. Turbo powered.
