Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Testing Coolant Temperature Sensors
MidEngine210
Galant VR-4 org Post #: 339510 posted 05/16/06 03:26 PM     Remind Me!  Send Private Message   Edit Post
I was wondering how I do the following:
1.) How to test the gauge and ecu coolant temperature sensors while they are in the thermostat stat housing using a multimeter. Exact settings on the multimeter is appreciated. I suspect my gauge sensor is toast.
2.) How do I test the wires that plug into these two sensors so I know they are still good? My logger showed varying temps while driving recently and I suspect faulty wiring or bad plug.
Thanks.
| | | IP: (204.13.59.250) | Report this post to a Moderator
s_firestone
Ctrl-Alt-Boost
918/1000
Galant VR-4 org Post #: 339598 posted 05/16/06 07:24 PM     Remind Me!  Send Private Message   Edit Post
Here you go.
The Thermo Sensor is the one located at the bottom of the radiator near the middle. This is a thermal switch that toggles continuity at or above 183 degrees for the fan. I recommend if you intend to test this on the car, get a set of test leads you can clip on. I would not endorse reaching down that close to the manifold while the car is at operating temperatures and secondly because of the fan. I'm not sure what behavior the car will exhibit while this is unplugged(fan runs or no fan) so be careful.
The Coolant Temperature sensor and Gauge temperature sensor locations:
The Coolant Temperature sensor and Gauge temperature diagnostics. You can test these on the car.
Stephen Firestone
1992 GVR4 #918 of 1K
Posts: 1610 | From: Park City, UT USA | Member Since: 06/27/02 | IP: (24.170.24.226) | Report this post to a Moderator
MidEngine210
Galant VR-4 org Post #: 339652 posted 05/16/06 09:20 PM     Remind Me!  Send Private Message   Edit Post
Thank you very much.
Generated in 0.126 seconds in which 0.105 seconds were spent on a total of 14 queries. Turbo powered.
