Galant VR-4 Forums » Galant VR-4 » Technical Discussions » 2g upper spring mounts
V8EATER
still thinking pink
Galant VR-4 org Post #: 331840 posted 04/25/06 06:06 PM     Remind Me!  Send Private Message   Edit Post
I installed these last week, and had a question concerning the fit of the spring isolators. Which one does everyone else use, the 1g or the 2g? The 2g isolator fits the mount, but not the spring, and vice versa. Should I trim the 1g isolator to fit the upper mount? I haven't had any drivability issues, but I haven't pushed the car since installation.
1992 Audi UrS4
545/1000, sold
Posts: 2172 | From: Independence, MO | Member Since: 08/19/03 | IP: (69.242.141.244) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 331872 posted 04/25/06 06:57 PM     Remind Me!  Send Private Message   Edit Post
Did you do this to fine tune fender clearance? Or are they just "better"?
Ryan Hertz
Posts: 13501 | From: Chicago, IL | Member Since: 07/29/02 | IP: (68.254.141.65) | Report this post to a Moderator
V8EATER
still thinking pink
Galant VR-4 org Post #: 331878 posted 04/25/06 07:09 PM     Remind Me!  Send Private Message   Edit Post
I have 1g springs, and the back was a little lower than the front. I have cut the fronts before, and didn't like it, so I put in another uncut front set in and decided to alter the back springs this time instead.
1992 Audi UrS4
545/1000, sold
girlieracr4g63
Galant VR-4 org Post #: 332071 posted 04/26/06 08:38 AM     Remind Me!  Send Private Message   Edit Post
Glad to see this thread. I did the same thing, and my car sits lower in the rear as well. Why do you think this is? Sorry not trying to hijack the thread.
PS what did you do to alter the rear?
Wendy
Edited by girlieracr4g63 (04/26/06 08:40 AM)
| | | IP: (205.157.244.33) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 332074 posted 04/26/06 08:40 AM     Remind Me!  Send Private Message   Edit Post
Because the rear springs are too short? The 2g upper mount gives it a little bit of a boost.
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 332127 posted 04/26/06 11:39 AM     Remind Me!  Send Private Message   Edit Post
I'm wondering if a combination of Evo8 and TEL springs + 2g mounts can make something that is level and performs well for a daily driver... I have the Evo and TEL springs, some day I'll lookup the spring rates and heights and figure something out.
Ryan Hertz
Key Fob Guy
Galant VR-4 org Post #: 332129 posted 04/26/06 11:50 AM     Remind Me!  Send Private Message   Edit Post
The Evo spring rates are about double what the DSMs are. I wish I had gone with Evo's instead.
-mitsuturbo
77/2000
Galant VR-4 org Post #: 332217 posted 04/26/06 02:51 PM     Remind Me!  Send Private Message   Edit Post
On a DD, really?
Ryan Hertz
turbogalant
Galant VR-4 org Post #: 332219 posted 04/26/06 02:52 PM     Remind Me!  Send Private Message   Edit Post
^ Ah hell, his car only sits broken outside of his work anyway .
| | | IP: (68.63.206.140) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 332266 posted 04/26/06 04:40 PM     Remind Me!  Send Private Message   Edit Post
werd, it would look better sitting there with Evo suspension. Honestly the 1g stuff wasn't a huge improvement.
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (24.149.159.155) | Report this post to a Moderator
V8EATER
still thinking pink
Galant VR-4 org Post #: 332282 posted 04/26/06 05:36 PM     Remind Me!  Send Private Message   Edit Post
yeah, i'm pretty disappointed as well with the 1g. rolls like a barge in the corners. without swapping struts, do the evo springs bolt in, ala 1g awd springs? I've seen the how to section on the full swap, but i've got some newer struts that i would rather keep.
1992 Audi UrS4
545/1000, sold
V8EATER
still thinking pink
Galant VR-4 org Post #: 332286 posted 04/26/06 05:40 PM     Remind Me!  Send Private Message   Edit Post
btw, wendy, i installed 2g upper spring mounts in the place of my 1g/vr4 upper mounts. they are an inch shorter or so, so they jack up the rear of the car to even it out.
1992 Audi UrS4
545/1000, sold
Key Fob Guy
Galant VR-4 org Post #: 332304 posted 04/26/06 06:26 PM     Remind Me!  Send Private Message   Edit Post
Yup.
-mitsuturbo
V8EATER
still thinking pink
Galant VR-4 org Post #: 332327 posted 04/26/06 07:20 PM     Remind Me!  Send Private Message   Edit Post
do you need to trim the springs at all?
1992 Audi UrS4
545/1000, sold
Senior Ricer
1552/2000
Galant VR-4 org Post #: 332329 posted 04/26/06 07:23 PM     Remind Me!  Send Private Message   Edit Post
Only the fronts.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.222.254) | Report this post to a Moderator
V8EATER
still thinking pink
Galant VR-4 org Post #: 332343 posted 04/26/06 07:53 PM     Remind Me!  Send Private Message   Edit Post
will i need the 2g upper mounts in the back, or the stock ones?
1992 Audi UrS4
545/1000, sold
Senior Ricer
1552/2000
Galant VR-4 org Post #: 332358 posted 04/26/06 08:32 PM     Remind Me!  Send Private Message   Edit Post
Either one. Everyone says the 2G mounts make the back sit 3/4" higher than the stock mounts with the same springs. I'm not so sure about it but that's what they say.
John
Generated in 0.054 seconds in which 0.038 seconds were spent on a total of 14 queries. Turbo powered.
