Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Make my ABS light turn off.
lunchbox
:ugh: face
Galant VR-4 org Post #: 328814 posted 04/16/06 09:59 PM     Remind Me!  Send Private Message   Edit Post
I followed the VFAQ posted here and removed my ABS but for whatever reason the link to get to the other thread about getting the lights to turn off and getting the computers out is dead.
How do I get my Anti-lock light to turn off? I dont want to start randomly pulling and disconnecting stuff. I have my front sensors removed, the pump removed, and a non-ABS proportioning valve from a GGSX and lines installed.
Posts: 1140 | From: Mil-walk-it-out, WI | Member Since: 05/29/05 | IP: (69.95.141.162) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 328842 posted 04/16/06 10:44 PM     Remind Me!  Send Private Message   Edit Post
You don't happen to have a logger connected and your car is a 92, do you?
-Jeff
1881/2000
50/1000
Posts: 7871 | From: KC, Missouri | Member Since: 08/08/04 | IP: (24.180.143.181) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 328868 posted 04/17/06 05:15 AM     Remind Me!  Send Private Message   Edit Post
If you don't go in the trunk and unplug the ABS ECU then the light will stay on. That is for a 1991, I don't know about 1992's.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.222.254) | Report this post to a Moderator
GSNT
Deer Slayer
Galant VR-4 org Post #: 328871 posted 04/17/06 05:43 AM     Remind Me!  Send Private Message   Edit Post
Yes removing the computer in the left side of the trunk next to the power antenna will kill the light, not to mention take a few lbs out of the car.
Posts: 520 | From: Louisville, KY | Member Since: 07/06/03 | IP: (24.219.233.202) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 328899 posted 04/17/06 07:53 AM     Remind Me!  Send Private Message   Edit Post
I think you can also remove one of the big fusible links off the battery terminal. But, removing one of them makes your idle faster, the other one kills the light, and I can't remember which is which. I think you need to remove the larger one, like 100 amp.
| | | IP: (68.232.56.164) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 328910 posted 04/17/06 08:21 AM     Remind Me!  Send Private Message   Edit Post
Or pull your cluster and take out the light itself.
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.4) | Report this post to a Moderator
ron
Galant VR-4 org Post #: 328919 posted 04/17/06 08:37 AM     Remind Me!  Send Private Message   Edit Post
I just got my abs light to turn off last week.
I used the method mentioned by Hertz in the following thread.
web page
But it was the plug that was toward the front of the car instead of the middle one.
Edited by ron (04/17/06 08:39 AM)
| | | IP: (75.2.168.68) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 328921 posted 04/17/06 08:43 AM     Remind Me!  Send Private Message   Edit Post
Post that info as a correction to that thread, if you don't mind.
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.153) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 328925 posted 04/17/06 08:59 AM     Remind Me!  Send Private Message   Edit Post
The light will still stay on if you follow Jeff's idea. The bulb gets power from another source and the ABS ECU grounds the bulb in the dash to turn it on.
John
ron
Galant VR-4 org Post #: 328993 posted 04/17/06 11:20 AM     Remind Me!  Send Private Message   Edit Post
Done.
I pulled the 60 amp fues and the ABS computer in the trunk but the light stayed on. Unplugging the ABS computer underhood WORKED! Thanks Hertz. It is not the middle plug on my car but the one closer to the headlight. It's the biggest plug with 7 or 8 wires.
| | | IP: (67.114.159.41) | Report this post to a Moderator
Generated in 0.095 seconds in which 0.064 seconds were spent on a total of 14 queries. Turbo powered.
