Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Evo Springs broken
Evo Springs broken
pudhed
Galant VR-4 org Post #: 234591 posted 07/09/05 03:29 PM     Remind Me!  Send Private Message   Edit Post
If you are running Evo springs, be sure to get the Evo rubber pads for the rear top mounts. The springs do not fit into the stock Galant top mounts, and will destroy the stock rubber pads. That's part number 5 in the picture below.
I've been running the Evo shocks and springs, with the stock GVR4 rear top mounts. When I put them on, it was obvious that the rear Evo springs are a little smaller diameter than the GVR4 springs, and doesn't quite fit into the rubber pad in the top mount.
After beating on it for a little while, the rubber pad has broken, and the spring has burst through and is resting on the metal part of the top mount. The spring is also no longer centered, and is pushed up against the shock body.
EDIT: Some people have still had spring unseating problems with the Evo rubber pad in Galant top mounts after extended beating on the car..
Using full Evo top mounts, metal and rubber, won't have this problem.
Edited by pudhed (04/29/06 02:53 PM)
| | | IP: (66.218.52.237) | Report this post to a Moderator
crucible
Galant VR-4 org Post #: 234598 posted 07/09/05 03:47 PM     Remind Me!  Send Private Message   Edit Post
I noticed the same thing.I haven't been able to drive my car to verify your claims
but thanx for the heads up
| | | IP: (69.118.8.97) | Report this post to a Moderator
dime2nr
Member ++
905/2000
Galant VR-4 org Post #: 234602 posted 07/09/05 03:55 PM     Remind Me!  Send Private Message   Edit Post
thanks i started on mine today thanks for the heads up
im guessing they are a dealer part do you know the cost?
Edited by dime2nr (07/09/05 04:42 PM)
Posts: 639 | From: Portland OR | Member Since: 09/01/04 | IP: (24.92.73.37) | Report this post to a Moderator
Yao
Galant VR-4 org Post #: 234741 posted 07/10/05 08:30 AM     Remind Me!  Send Private Message   Edit Post
It's usless, The spring will eventually move around because Part number 4 on the galant is bigger then the Evo. The spring will bind and move quite a bit. The real fix is to use all galant part, but cut the top coil of the EVO spring off, then they will match.
3"K&N, B16g, 2.5pipe, Synapse DV, ETS Frntmnt, FP4r, ZFG Long Block, 2g mani, evo3o2/5th, 3"exst,fic1100cc/walbro,
6an, poly mnts, DEL-abs/ps/4ws/egr/evp, Jack's tran, SB-clutch, evo8 whls-245/45/17/springs, 3kvr4 brakes, Koni, 4bolt rear,
ds-map, ntk.
Posts: 810 | From: Denver, CO | Member Since: 03/06/01 | IP: (67.172.151.43) | Report this post to a Moderator
dime2nr
Member ++
905/2000
Galant VR-4 org Post #: 234856 posted 07/10/05 07:52 PM     Remind Me!  Send Private Message   Edit Post
can you explain how cutting the spring will be better
im just curious
Luke
201/2000
Galant VR-4 org Post #: 332862 posted 04/28/06 12:13 AM     Remind Me!  Send Private Message   Edit Post
I used evo rubber pads, but galant top mount on my evo suspension conversion.
Still does not work, and the evo springs eventually came off the evo rubber pads.
this is because the galant top mount is bigger than the evo rubber pads, thus the rubber pads are not secured in the center.
2.3L 6-bolt, BJ's ported 2G head, TRE tranny, GT3076R, 255lph, 850cc, AFPR, ROM emulator, Aquamist, ETS FMIC, LSD rr Quaife ft diff, WL swaybars, Bilstein, HKS 264/272 cams, ZT2 WBO2
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (71.141.170.73) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 333074 posted 04/28/06 12:56 PM     Remind Me!  Send Private Message   Edit Post
So would you say that this is a definitive reason to use fully adapted Evo springs and struts?
Ryan Hertz
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (68.254.141.65) | Report this post to a Moderator
Luke
201/2000
Galant VR-4 org Post #: 333141 posted 04/28/06 03:39 PM     Remind Me!  Send Private Message   Edit Post
I am already using all evo parts for my rear evo suspension conversion: evo struts, evo springs, evo rubber pads. All except for the evo top mount.
I used the galant top mount because the galant top mount has the right shape to fit in the rear shock towers.
I am still unsure how I would fix this issue.
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (209.213.198.25) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 333165 posted 04/28/06 04:52 PM     Remind Me!  Send Private Message   Edit Post
Use all evo parts!
The ones on my car and the ones I fabbed up for Hill uses the complete evo rear assembly with just the lower mount from the Galant/dsm welded on the bottom. Direct bolt in/no mods what so ever.
The rear sits 1 7/8 inches off the top of the tire with a 215/45/17.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (65.135.143.118) | Report this post to a Moderator
Luke
201/2000
Galant VR-4 org Post #: 333249 posted 04/28/06 10:33 PM     Remind Me!  Send Private Message   Edit Post
curtis: Any issue with using the evo metal top plate ( top mount ) on the galant ? I know the shape does not fit the shock tower of our car perfectly..
How many miles have you had it on the car ?
I didn't have issue with my setup initially either.. but after about 20K miles and 3 track days, it came unseated off the rubber pads.
Posts: 752 | From: San Jose, CA | Member Since: 07/16/02 | IP: (71.141.176.152) | Report this post to a Moderator
pudhed
Galant VR-4 org Post #: 333378 posted 04/29/06 02:45 PM     Remind Me!  Send Private Message   Edit Post
I run Evo top mounts, and Evo rubber spring seats. It fits fine and I haven't had any unseating problems. The only reason I originally used Galant top mounts was because the Evo suspension I bought didn't come with top mounts.
475/1000
Galant VR-4 org Post #: 333744 posted 05/01/06 07:36 AM     Remind Me!  Send Private Message   Edit Post
I've only put less than 1000 miles on it but the install in the rear was a direct bolt on. I wish the fronts could run the factory evo tops because they were in perfect shape but I didn't want to start drilling holes in the car's strut towers when I had a set that fit.
92 GVR4 0475/1000
Posts: 11892 | From: Clarksville TN | Member Since: 05/04/03 | IP: (65.142.59.137) | Report this post to a Moderator
1 registered and 14 anonymous users are browsing this forum.
Generated in 0.143 seconds in which 0.099 seconds were spent on a total of 14 queries. Turbo powered.
