curtis Space Blanket from NASA plumbed into the attic 475/1000
posted 05/25/03 08:35 PM
I found a 89 Galant in the junk yard last fall with a small glove box panel next to the drivers left knee. I purchased the whole panel with flip open box for five dollars. its the same color as the old panel and is flat instead of a bulge toward your legs its a direct bolt in except for two steel brackets that have to be removed and make sure you get the air tube because its different. Makes a great place for boost controllers and afcs. The beautiful thing is that it can be closed and no ones the wiser great for the 4 door sleeper
Yes, any Galant with the manual seat belts will have this glove box in the drivers side kick panel. Don't forget about the pass side box too. Its a few pounds lighter. You do have to worry about color. There are some blue and I believe brown interiors out there.
Ward
quote:Originally posted by 4orced4door: That's awesome! Perfect place for my new VPC...
Were all the '89-ish Galants equpped with this glove box?
Posts: 911 | From: Fremont Ca | Member Since: 03/16/01 | IP: (12.235.99.210) |
