Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Does this timing look correct?
Lesac
Galant VR-4 org Post #: 1245247 posted 01/31/19 07:43 PM     Remind Me!  Send Private Message   Edit Post
I tried to get the best pictures I could. But does this look correct or is it off just slightly. The car runs a hair lumpy at idle but I feel like itís more of a vacuum leak than anything else. Iíve gone through the fuel system and that is fine. The ignition is also working well. So itís either just off timing or sucking in air somewhere. Or the tune is crap.
736/2000 sold
848/1000 current daily
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2600:8804:0:b800) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1245248 posted 01/31/19 07:50 PM     Remind Me!  Send Private Message   Edit Post
You need to pull the cover and check the actual timing gear mark, also if the car has balanace shafts the belt could be loose or that could be off a tooth.
Edit - gears look on point, harmonic balancer looks a bit off, but that could be from the angle the picture was taken.
138/2000
152/1000
Edited by transparentdsm (01/31/19 07:51 PM)
Posts: 3613 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (69.36.193.100) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245250 posted 01/31/19 08:23 PM     Remind Me!  Send Private Message   Edit Post
Irritating thing is that I had the timing cover off before this and wasnít smart enough to check it before I reassembled the whole thing.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (68.13.149.65) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 1245252 posted 02/01/19 05:47 AM     Remind Me!  Send Private Message   Edit Post
Your cam gears are lined up so the question is whether the crank is sitting at TDC. If you draw a line from the center of the harmonic balancer (in the middle of where your wrench head is) to the '0' tick on the timing cover, it looks like it passes right through the notch on the edge of the balancer wheel. To me that indicates that your timing is good. If it's vibrating a lot you could have your rear balance shaft out by 180*. If it's just idling poorly check your ignition timing and fuel/vacuum/etc.
Roger B. Scott
'91 Belize Green
Posts: 3312 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (134.36.232.110) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245254 posted 02/01/19 01:39 PM     Remind Me!  Send Private Message   Edit Post
Here is another quick question. Would the factory lower timing cover be black? All the oem replacements I see are silver. Mine is black and seems to be warped as it rubs bad on the ac tensioner.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (72.14.241.63) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1245255 posted 02/01/19 01:53 PM     Remind Me!  Send Private Message   Edit Post
Yeah, just the OEM VR4 one is black, but the silver works just finished new as long as it's for a 6 bolt engine.
138/2000
152/1000
Posts: 3613 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245256 posted 02/01/19 02:59 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the help guys, going to just order a new cover and check the timing when itís off.
736/2000 sold
Galant VR-4 org Post #: 1245257 posted 02/01/19 03:45 PM     Remind Me!  Send Private Message   Edit Post
I have a brand new in box black cover I will sell you. I will price match whatever you can find one for.
BTW, the Eclipse/Talon/Laser engine versions used the silver covers.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10741 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245259 posted 02/01/19 04:59 PM     Remind Me!  Send Private Message   Edit Post
Cheapest Iíve seen a silver cover for was $108. Color doesnít matter much to me. Iím going to have to rebuild my throttle body too so, Iím likely going to have to make a bigger parts order.
736/2000 sold
138/2000
152/1000
Galant VR-4 org Post #: 1245260 posted 02/01/19 05:15 PM     Remind Me!  Send Private Message   Edit Post
I use rtm out of Canada when I order my throttle body shaft seals.
138/2000
152/1000
Lesac
Galant VR-4 org Post #: 1245481 posted 03/02/19 03:15 PM     Remind Me!  Send Private Message   Edit Post
Just wanted to verify this timing was correct, and I found my issue. Was not related to timing.
736/2000 sold
Generated in 0.087 seconds in which 0.068 seconds were spent on a total of 14 queries. Turbo powered.
