Help replacong rear axle bearings.
Vince
Puget Sound, WA
Just another delay that is slightly annoying.
I have new Rear axle bearings and hub assembly.
Looking at the shop manual, (and other FWD cars I have done) it is a straight forward job.... Until I pull the rotor, and see there is no axle nut or washer. Just a solid unit with no visible method of being retained. Is the OEM assembly meant to be press fit?
Seems odd to me, so I hope someone will help out before I go renting pulling tools and such
Seeing that the Moog assemblies didn't come with a axle nut and washer, I hope my local parts store can get them.....
Domo Arigato (thank you)
VInce
Vince
Puget Sound, WA
OK, Thanks... I think...
So here (see link) is the replacement
It has both inner and outer bearings, so if I understand correctly, a slide puller will separate the existing hub from its mounting without further disassembly on the back side of the trailing arm. Correct?
I assume that when the hub comes out, the axle shaft will remain in place so the new unit can be driven back in? Is the original axle shaft end threaded so that the new unit can have a washer and castle nut installed to secure it?
Tanks again
V
Indianapolis, IN
That looks like a FWD rear hub assembly. The AWD assembly has an axle shaft built into it that bolts on the inside of the axle cup. Also, the outer bearing normally stays on it and has to be removed, the inner bearing will need pressed in/out. Here is a pic of them and a link to a set for sale. The bearings and inner seal can be found on RockAuto.
PerformancePartout
Yes, you have FWD brearings. Looking at Tom's provided photo, you can see that you need to remove the rear axle shafts and get to the 22mm (I believe) nut to be able to tap that complete stub axle assembly out to replace the bearing.
see this thread for good instructions: How to
Vince
Puget Sound, WA
Awesome...
Well, kinda, cause i gotta return and reorder.
Thank you all for your advice and words of wisdom. /ubbthreads/images/graemlins/worthy.gif
Vince
Vince
Puget Sound, WA
Sigh......
Well after that fiasco, it turns out the correct rear hub assembly is no longer available from Mitsu.....
That leaves me with just having the bearings replaced, which I cant do myself... grrrrr
Before I go to the WTB section, do any of you know of a source outside Mitsu that might still have the complete unit available, of offer rebuilt ones?
V
Still a little confused by your posts. Even if Mitsubishi still sold the rear hub, it would not have the bearing on it as a service part. They would have to be installed. Typically, this type of part is never offered by the aftermarket.
There are ways to change them at home in the shop, you just have to be a bit creative on removal and pressing them back on. I have done it before.
Vince
Puget Sound, WA
Thanks Iceman
Mitsu actually sold the whole assembly (MB569254), hub, bearings, gear, back flange and all (about $200/ea). This was my preference as I can accomplish a swap without serious effort.
Now seeing that the assembly is no longer available, I'll have to resort to replacing the bearings and seals on my existing hubs, (and hope the gear is in good condition). This isn't something I can do in my current condition.
Instead,, if no one offers a 'rebuilt', then I will hit the WTB section for a pair, buy the bearings and seals, and present them to my local shop to do. I can still drive while that is being done.
Once those are made serviceable, I can fall back once again to simply pulling and replacing the failing ones on the car.
V
