Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Firewall Grommet locations
4dr_vr4
Galant VR-4 org Post #: 1240449 posted 11/11/17 12:22 PM     Remind Me!  Send Private Message   Edit Post
Went to replace my speedometer cable today but I can't get it through the firewall hole because of all the wires I have going through there to support gauges and fuel pump rewirs etc. Guess this means that I have to redo all the wiring running through there which sucks.
What are some other locations that I can use in the future? Looking at the firewall there doesn't seem to be many.
Posts: 79 | From: NC | Member Since: 05/18/13 | IP: (206.223.254.5) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1240458 posted 11/12/17 07:20 AM     Remind Me!  Send Private Message   Edit Post
If you intend to run more gauges or other electrical devices, there is a grommet on the Driverside that I would encourage you to use. It sits behind the Driver Fender and is the same grommet that the Chassis Harness passes through. From my horrible memory, the easiest way to locate it is, is to remove the front fender wheel well lining and you'll see an oval/squareish black rubber grommet. This to me is the ideal location to run cabling/tubing/etc.
182/1000
Posts: 1524 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (2606:a000:5191:e) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1240469 posted 11/12/17 07:24 PM     Remind Me!  Send Private Message   Edit Post
Thank you brother.
Posts: 79 | From: NC | Member Since: 05/18/13 | IP: (71.206.182.9) | Report this post to a Moderator
1 registered and 29 anonymous users are browsing this forum.
Generated in 0.051 seconds in which 0.044 seconds were spent on a total of 14 queries. Turbo powered.
