Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Turbo inlet gasket?
Turbo inlet gasket?
Iggy
741/2000
Galant VR-4 org Post #: 1239567 posted 09/16/17 06:26 PM     Remind Me!  Send Private Message   Edit Post
I'm in the process of putting my turbo back on but the gasket kit that I have has a really weird looking gasket. One of them is centered in the same diameter as the manifold outlet , but the other one is smaller and offset. I'm pretty sure that's the one that goes on the turbo but is it normal? Seems weird that it will be smaller and offset and not directly in line. I just want to make sure I'm. Or doing something wrong here.
Dirt, snow, grass, or ice if it's a loose surface I'm going sideways and happy about it.
Posts: 50 | From: Ashland. Wi | Member Since: 05/08/15 | IP: (68.234.77.33) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1239569 posted 09/16/17 07:29 PM     Remind Me!  Send Private Message   Edit Post
if you had an auto turbo dsm you would use the weird gasket.
138/2000
152/1000
Posts: 3658 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Iggy
741/2000
Galant VR-4 org Post #: 1239572 posted 09/16/17 09:58 PM     Remind Me!  Send Private Message   Edit Post
So do I just need the normal looking one?
Posts: 50 | From: Ashland. Wi | Member Since: 05/08/15 | IP: (2600:1008:b16a:c) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 1239574 posted 09/17/17 04:59 AM     Remind Me!  Send Private Message   Edit Post
Don't use a gasket with a hole that is smaller than the diameter of the parts you're mating. It will restrict flow and eventually the gasket will come apart and the bits will get sucked into the works. So, yes, you want the one on the bottom.
Here's a general rule: With cars as old as ours that had as many "sister" cars with slight variations, you will often come across parts that look *almost right* but clearly don't fit. In these cases you just have to apply common sense. If it looks wrong, it usually is wrong.
Roger B. Scott
'91 Belize Green
Posts: 3312 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (92.236.24.155) | Report this post to a Moderator
Iggy
741/2000
Galant VR-4 org Post #: 1239577 posted 09/17/17 09:11 AM     Remind Me!  Send Private Message   Edit Post
I figured the smaller one wasn't right, but when I took my turbo off I remember it having two gaskets. Which probably means whoever put it on last must have made the same mistake I almost made.
Posts: 50 | From: Ashland. Wi | Member Since: 05/08/15 | IP: (68.187.138.207) | Report this post to a Moderator
1 registered and 36 anonymous users are browsing this forum.
Generated in 0.057 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
