Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Boost Gauge install
Boost Gauge install
Iggy
741/2000
Galant VR-4 org Post #: 1236730 posted 04/22/17 05:47 PM     Remind Me!  Send Private Message   Edit Post
I'm trying to install my mechanical boost gauge right now, but I'm not sure which vacuum line to T into. I can't find an actual answer.
Dirt, snow, grass, or ice if it's a loose surface I'm going sideways and happy about it.
Posts: 50 | From: Ashland. Wi | Member Since: 05/08/15 | IP: (68.187.138.207) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1236731 posted 04/22/17 06:57 PM     Remind Me!  Send Private Message   Edit Post
I "T"d mine off the FPR vacuum line.
Thom
Posts: 894 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2600:387:b:8::41) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1236775 posted 04/25/17 03:10 PM     Remind Me!  Send Private Message   Edit Post
There's a few rules:
* T off the Intake
* don't touch the vac line to the fuel pump
* distribution blocks are your friend
* T as close to the gauge as possible (limit the length of the vac line)
Unless you are planning to invest in a new intake mani w/ more hose nipples, I would suggest getting a distribution block. My vac lines were t'd to hell before I got my cyclone intake. Speed density, boost, BoV... I wish I had picked up a distro block early on. So much easier.
Quoting Iggy:
RIP 543
Ded click
2006 Suzuki SV-650 (for sale)
2011 BMW 335d (~510'lb/tq and 36mpg. hwy. How can you go wrong?)
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (71.36.125.103) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1236776 posted 04/25/17 03:22 PM     Remind Me!  Send Private Message   Edit Post
For a blow off valve I wouldn't source from a vac block. Especially if it's hks. Go direct to the intake mani.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (50.193.76.1) | Report this post to a Moderator
slugsgomoo
god hates stupid people
461/1000
Galant VR-4 org Post #: 1236780 posted 04/25/17 08:00 PM     Remind Me!  Send Private Message   Edit Post
not one mention of www.vfaq.com ???
I went there, and here's a how to, brought to you straight from the 1990's click
-andrew
{witty signature}
2015 Triumph Tiger 800 XCx
2014 Ford Focus ST
Posts: 3711 | From: Tacoma, WA | Member Since: 10/16/03 | IP: (216.161.254.66) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1236815 posted 04/28/17 05:53 AM     Remind Me!  Send Private Message   Edit Post
Almost everything should be taken directly from the intake manifold. I actually tapped my intake (stock) for more vacuum/boost ports.
1991 Belize Green GVR4 #476/2000: 788WHP/588wTQ (dynojet), 3400lbs!
Posts: 245 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (64.135.58.130) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1236839 posted 04/29/17 08:05 PM     Remind Me!  Send Private Message   Edit Post
Would have been easier to use a vacuum distribution block mike. Or use the existing holes on either side of the intake that have plugs in them from the factory just waiting for you to use them.
We run everything off of a single distribution block and have had no issues up to 1000hp so far.
I GIVE ZERO FUCKS. I HATE YOU ALL.
Edited by biglady112 (04/29/17 08:06 PM)
Posts: 1244 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (97.122.243.73) | Report this post to a Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1236841 posted 04/29/17 09:52 PM     Remind Me!  Send Private Message   Edit Post
Quoting G:
With speed density I meant.
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1236844 posted 04/30/17 08:21 AM     Remind Me!  Send Private Message   Edit Post
Quoting diambo4life:
This is also what I prefer to do. It's simple, easy to do, allows you to clean the intake manifold ( they always need that), replace some potential bad gaskets, best of all it cleans things up and allows you to hide the hoses and even some extra ones.
When I do mine I usually add 1 extra port then needed and cap it in case methanol would like to be added later.
138/2000
152/1000
Posts: 3645 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1236847 posted 04/30/17 09:07 AM     Remind Me!  Send Private Message   Edit Post
I mean this is the best way, but unless you want to pull your mani and tap it (and are comfortable doing so), a distro block is your next best-bet.
RIP 543
Ded click
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (71.36.117.142) | Report this post to a Moderator
biglady112
or what
359/2000
Galant VR-4 org Post #: 1236849 posted 04/30/17 03:08 PM     Remind Me!  Send Private Message   Edit Post
We run our blow off valve off of the vacuum block, with speed density. I don't see why an HKS one would be different, then again I would not put that junk on a car I own. That is for sure. If I cannot hookup an Army/Navy or JIC fitting to my blow off valve, I am not interested in it. Those HKS are junk and leak horribly at both the flange oring and the nipple that is pressed into the back I it.
Posts: 1244 | From: Commerce City, Co | Member Since: 09/30/05 | IP: (2601:280:c100:98) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1236856 posted 04/30/17 10:24 PM     Remind Me!  Send Private Message   Edit Post
Quoting biglady112:
Quoting biglady112:
Quoting biglady112:
Well, guess you don't have to worry about that since per the usual, these aren't your cars.
Posts: 3431 | From: SoCal | Member Since: 01/02/12 | IP: (207.255.187.121) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1236857 posted 05/01/17 05:04 AM     Remind Me!  Send Private Message   Edit Post
And your just fucking talking to talk now.. I use a block for everything .. then 2 second's later blocks are junk never on my car make up your fucking mind...
138/2000
152/1000
Edited by transparentdsm (05/01/17 05:06 AM)
diambo4life
476/2000
Galant VR-4 org Post #: 1236866 posted 05/01/17 12:49 PM     Remind Me!  Send Private Message   Edit Post
Quoting biglady112:
My intake was off so I tapped it. I agree if it is something you are doing with the intake in the car, a distribution block would work fine. I just don't like T'ing off the FPR or wastegate lines. Just a preference.
PS: I think I rounded off those blockoffs in the intake attempting to break them loose.
Edited by diambo4life (05/01/17 12:51 PM)
Generated in 0.144 seconds in which 0.093 seconds were spent on a total of 14 queries. Turbo powered.
