Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Idle tuning (Need advice)
Nabeel
Member +
Galant VR-4 org Post #: 1236608 posted 04/15/17 02:04 PM     Remind Me!  Send Private Message   Edit Post
log below.
idle + rev log
It is being long time since my last post here, I need little help from ECMlink users, Please have a look at my log, I did some adjustments to get reasonable reading. The issue I am suffering is the car cant hold after rev or slow down.
Main mod have done to the car, fresh built, SD setup using Ecmlink kit, gt35 stock location,Tial external 38mm, HKS 264s, HKS cam gears (No adjustment yet), Fresh head with upgrade springs, steel valves (Stock size), Guides and 3g lifters, 255fuel pump, 43.5psi FP using AEM FPR. TB rebuild and fiav blocked and ISC deleted (I thought it will solve the issue). No known mechanical issue suck leaks or so. Battery+alternator replaced and relocated using Jay kit.
Any comments or advice might be helpful, Thanks
91 VR4
09 GT eclipse
91 Cefiro
Posts: 257 | From: K.S.A | Member Since: 07/14/06 | IP: (51.36.6.254) | Report this post to a Moderator
Nabeel
Member +
Galant VR-4 org Post #: 1236612 posted 04/15/17 04:31 PM     Remind Me!  Send Private Message   Edit Post
I forget to mention, Injectors are Fic 1100hz.
Posts: 257 | From: K.S.A | Member Since: 07/14/06 | IP: (51.39.55.205) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1236671 posted 04/19/17 11:07 AM     Remind Me!  Send Private Message   Edit Post
Without going into the detail you might need to go with for a full diagnosis, I would ask if the Idle Stop Switch on the side of the TB is working and TPS values are confirmed proper for idle or simulated stop switch mode. The ECU has to see idle or simulate it based upon values. Posting at work, so can't go much more with it than that, and my Link skills are not LEEt.
C53A 1 of the ~1500
Posts: 1629 | From: THE Ottawa | Member Since: 03/05/05 | IP: (173.206.108.86) | Report this post to a Moderator
1 registered and 16 anonymous users are browsing this forum.
Generated in 0.051 seconds in which 0.042 seconds were spent on a total of 14 queries. Turbo powered.
