Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Replacing ball joints - bad or good?
bigandbad
Galant VR-4 org Post #: 1232060 posted 09/26/16 01:08 PM     Remind Me!  Send Private Message   Edit Post
I've to replace all ball joints at all 6 arms - the front ones and the two in the rear...
Mitsubishi offers only the complete arms - but mine are, except the ball joints, in a good condition.
My plan was to replace the bushings to some of energysuspension, that I've done some times at my Galant V and it wasn't a problem.
Rockauto offers the balljoints separetly, I read somewhere here about the original MD-number, but I haven't heard from someone doing it.
Are they after replacing tight?
Or is it dangerous?
The complete arms would cost about 1,600$ - that's too much...
Posts: 45 | From: Hamburg, Germany | Member Since: 09/06/16 | IP: (84.58.242.245) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1232061 posted 09/26/16 01:22 PM     Remind Me!  Send Private Message   Edit Post
As long as you have the right tools, they are just fine. I have always just replaced the ball-joints themselves. If you pull the circlip and it falls out or can be pushed out by hand, then a control arm may be in order.
Thom
(SOLD) 866/1000 (PTE 1200's, billet 20g+, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 907 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (172.68.58.7) | Report this post to a Moderator
bigandbad
Galant VR-4 org Post #: 1232062 posted 09/26/16 02:00 PM     Remind Me!  Send Private Message   Edit Post
Thank you, Tom...
I have the right tools in my garage.
I found two different types of ball joints - some have a fluted base, some are smooth.
What would you prefer?
Galant VR-4 org Post #: 1232064 posted 09/26/16 03:14 PM     Remind Me!  Send Private Message   Edit Post
I would prefer the smooth as long as they are the proper dimension and a tight fit. More surface area for load bearing.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10862 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Yohler
161/1000
Galant VR-4 org Post #: 1232067 posted 09/26/16 05:51 PM     Remind Me!  Send Private Message   Edit Post
For what it's worth I just did mine using Moog brand and they fit perfectly
Posts: 70 | From: New Lenox, IL | Member Since: 02/26/16 | IP: (172.68.58.12) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1232077 posted 09/27/16 06:47 AM     Remind Me!  Send Private Message   Edit Post
I too say smooth
Thom
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1232160 posted 09/29/16 07:36 PM     Remind Me!  Send Private Message   Edit Post
I second the Moog fitting well. Not even that hard and you can get a "free" ball joint press from most any auto parts stores now. Advanced and car quest do 90 rentals, not that you would need it instead of the other places doing 24 hrs.
Posts: 429 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 1232170 posted 09/30/16 01:04 AM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
I too say smooth
Ditto,
Once pressed out the serrated ones effectively junk the arm. There was a pair on the front of the lancer, so I had to swap arms a few times on that to get everything straight.
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1559 | From: Midlands, UK | Member Since: 08/04/04 | IP: (51.9.17.15) | Report this post to a Moderator
1 registered and 18 anonymous users are browsing this forum.
Generated in 0.056 seconds in which 0.04 seconds were spent on a total of 14 queries. Turbo powered.
