Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Gear ratio issue?
Gear ratio issue?
18GVR4
Galant VR-4 org Post #: 1231886 posted 09/18/16 06:40 PM     Remind Me!  Send Private Message   Edit Post
I finally got my GGSX running good enough to drive daily. My rpms at 55 mph is around 3k and the engine seems to be working hard. I don't know if this is normal or if different gears have been installed previously. Any ideas? Thanks
1990 GGSX
Posts: 146 | From: snohomish, wa | Member Since: 07/09/05 | IP: (2600:100f:b02e:2) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1231888 posted 09/18/16 07:06 PM     Remind Me!  Send Private Message   Edit Post
Seems normal for the AWD models to sit a bit higher in 5th gear due to the torque delivery characteristics of the DOHC engine and the fact that AWD saps a bit more power from the drivetrain. Muy JDM Galant VR-4 sits at 3200-3300rpms at 60-65mph.
Your gearbox is the W5M31 and rear end has a 2.846 ratio so it is quite unique to the G-GSX and a handful of other cars - not likely someone has swapped something to be honest given the incompatibility with other DSMs and G-VR4s.
Posts: 2161 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (220.244.112.238) | Report this post to a Moderator
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1231889 posted 09/18/16 07:10 PM     Remind Me!  Send Private Message   Edit Post
Before I bought my GGSX, the dealer had swapped in a used rear diff with the wrong ratio. I was unaware until it had already destroyed the trans, TC and rear diff. The transmission service manual lists the ratios for the various sub-models.
Done there, been that
Posts: 1275 | From: MD | Member Since: 04/07/05 | IP: (108.31.167.181) | Report this post to a Moderator
18GVR4
Galant VR-4 org Post #: 1231968 posted 09/21/16 11:07 PM     Remind Me!  Send Private Message   Edit Post
Thanks for the info guys. Just when I thought it was good to go, I noticed a leak between the transfer case and transmission. Ugh, I should have just bought a Smart car.
1990 GGSX
Posts: 146 | From: snohomish, wa | Member Since: 07/09/05 | IP: (2600:100f:b027:3) | Report this post to a Moderator
1 registered and 26 anonymous users are browsing this forum.
Generated in 0.048 seconds in which 0.039 seconds were spent on a total of 14 queries. Turbo powered.
