Galant VR-4 Forums » Galant VR-4 » Technical Discussions » JDM ECU Swap 5810 to 5808
Dale
Newbie
Galant VR-4 org Post #: 1230098 posted 07/08/16 07:18 AM     Remind Me!  Send Private Message   Edit Post
I have an A-spec HH, 5810 ECU was faulty and wouldn't start car. I got my hands on a 5808 ECU. Has anyone swapped these before. I'm aware that it's a RS ECU and therefore requires 510cc injectors. I need info on wiring/pin changes. Do I need to swap 6 & 14? What about ABS & Fuel Pump signal wiring changes? Seeking help as this ECU is in excellent condition and I don't want to damage it. Any help will be appreciated.
1990 Aus Spec HH vr4
Jap Spec 4g63 Built Motor
Posts: 13 | From: Brisbane, QLD | Member Since: 06/18/14 | IP: (101.183.237.204) | Report this post to a Moderator
kumfasa
Galant VR-4 org Post #: 1230099 posted 07/08/16 08:03 AM     Remind Me!  Send Private Message   Edit Post
This may be helpful. click
Even the wool your trying to pull over my eyes is 95% polyester.
Posts: 125 | From: Tauranga, New Zealand | Member Since: 02/28/15 | IP: (81.232.125.104) | Report this post to a Moderator
Dale
Newbie
Galant VR-4 org Post #: 1230101 posted 07/08/16 08:36 AM     Remind Me!  Send Private Message   Edit Post
Thanks, after looking at that I gather I don't have to swap 6 & 14. Install 510cc injectors, swap ABS (11Aus to 13 J-Spec). Any idea what to do with fuel pump drive signal?
kumfasa
Galant VR-4 org Post #: 1230110 posted 07/08/16 11:04 AM     Remind Me!  Send Private Message   Edit Post
I'd be inclined to leave it and see if the fuel pump runs as it should. If it does good, if not then I'd jump 13 to 56.
Dale
Newbie
Galant VR-4 org Post #: 1230143 posted 07/09/16 05:30 AM     Remind Me!  Send Private Message   Edit Post
Swapped ABS pins, left fuel pump signal pin disconnected. Fired up ok, seems fine without it. Thanks for your help. I can run in my motor and clutch now.
kumfasa
Galant VR-4 org Post #: 1230145 posted 07/09/16 09:10 AM     Remind Me!  Send Private Message   Edit Post
Glad to hear it.
1 registered and 21 anonymous users are browsing this forum.
Generated in 0.046 seconds in which 0.039 seconds were spent on a total of 14 queries. Turbo powered.
