Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Hot no-start
Hot no-start
alik
Member +
40/2000
Galant VR-4 org Post #: 1216862 posted 09/19/15 01:57 PM     Remind Me!  Send Private Message   Edit Post
Still struggling with this issue.
When the car is cold, starts fine. When it gets to temp, it won't refire.
Sounds like it's struggling to turn over, but the battery is fine, sparkplugs are ok, no other visible issues apart from a very predictable fact that when the engine is hot, it absolutely refuses to refire. Turns over, but no cigar.
What say you?
Posts: 357 | From: Boston, MA | Member Since: 08/08/06 | IP: (209.6.41.231) | Report this post to a Moderator
highrpm666
677/1000
Galant VR-4 org Post #: 1216882 posted 09/20/15 12:00 AM     Remind Me!  Send Private Message   Edit Post
Start with the basics. Check for spark. Check fuel pressure. And do a compression test as well. Sounds like you have a component that's failing when heat soaked. Ptu.. coil pack.. I had an injector that wouldn't pulse when hot a while back. It stuck open causing a cylinder 3 misfire when started hot. Worked fine on a cold start. Lots of 20+ year old electrical parts don't like to work when heat soaked.
VR4 677/1000-rebadged. AKA Charlie the turbo slut DD
Posts: 121 | From: Morrison, Co | Member Since: 02/19/14 | IP: (2601:283:4403:b7) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1216980 posted 09/21/15 11:22 AM     Remind Me!  Send Private Message   Edit Post
Check the starter. I know this may sound funny but My old rx7 used to do that because of the heat it was getting so once it was hot there was no kicking that thing over. Had to literally push start it every time lol.
"Money doesn't sleep, so why should I"
^ the rotary guy who doesn't know anything about pistons lol
Posts: 42 | From: Chicago, IL | Member Since: 09/03/15 | IP: (104.129.196.49) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1216991 posted 09/21/15 02:09 PM     Remind Me!  Send Private Message   Edit Post
Temp sensor for the ECU maybe?
93 Mitsubishi Expo LRV
95 Eagle Summit DL coupe
98 Mitsubishi Mirage DE coupe
Posts: 2502 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (71.52.129.43) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1216995 posted 09/21/15 02:45 PM     Remind Me!  Send Private Message   Edit Post
Quoting Illinoisinc:
This is common on a lot of cars but I've never seen it on a 4G because the starter location is far away from any heat source. Still possibly worth checking out though.
I love my crazy mother!!!
Posts: 1672 | From: Manchester, NH | Member Since: 07/17/06 | IP: (104.129.192.54) | Report this post to a Moderator
Illinoisinc
Galant VR-4 org Post #: 1217004 posted 09/21/15 04:14 PM     Remind Me!  Send Private Message   Edit Post
^ thanks for the confirmation cutlassjim
rgeier11
sled driving mullet brain
Galant VR-4 org Post #: 1217018 posted 09/21/15 07:17 PM     Remind Me!  Send Private Message   Edit Post
Do you have a way to see what the ECU sees? I agree on the coolant temp sensor would be my first test.
1992 GVR-4 #649/1000 SOLD
1998 3000GT VR4 1of19 in New Zealand Green
1992 TSI AWD
Posts: 726 | From: Chicago Suburbs, IL | Member Since: 09/26/04 | IP: (73.208.136.136) | Report this post to a Moderator
Galant VR-4 org Post #: 1217049 posted 09/22/15 07:56 AM     Remind Me!  Send Private Message   Edit Post
if the coolant temp sensor signal is absent the ecu figures the car to be operating temp. It could be stuck reading cold... but if it was the cts you would most likely have a hard time starting it cold not hot.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.56.49) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1217055 posted 09/22/15 09:25 AM     Remind Me!  Send Private Message   Edit Post
When you say it doesn't start, does it crank and sputter like it wants to start but won't, or does it just crank and no attempts to even try and run?
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (96.2.247.27) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1217057 posted 09/22/15 09:30 AM     Remind Me!  Send Private Message   Edit Post
so the fuel pressure solenoid has not been checked?
Posts: 273 | From: NV | Member Since: 08/05/08 | IP: (120.29.74.188) | Report this post to a Moderator
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 1217058 posted 09/22/15 09:31 AM     Remind Me!  Send Private Message   Edit Post
Quoting 89Mirageman:
+1, I strongly recommend the coolant temperature sensor.
182/1000
Posts: 1548 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (204.34.247.201) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1217059 posted 09/22/15 09:31 AM     Remind Me!  Send Private Message   Edit Post
or these ones?
Edited by AllanL (09/22/15 09:34 AM)
alik
Member +
40/2000
Galant VR-4 org Post #: 1217265 posted 09/25/15 06:42 AM     Remind Me!  Send Private Message   Edit Post
Quoting prove_it:
It barely turns over like the engine is stuck or something, and it pretty much refuses to fire. If I could describe it, it is as if the battery is dead (yet mine is full of unicorn juice, freshly charged).
Turning the engine over by hand feels fine.
Disconnecting the battery produces the same result.
It feels like an electrical issue, and I'm getting ready to pull the starter this morning, but do you guys believe that it isn't?
Edit : since there's a possibility of it being the starter, I'm gonna yank it and bring it back to Autozone to have them replace it under warranty.
#40/2000, Nile Black
'90 Miata, waay too fast in corners
Edited by alik (09/25/15 06:46 AM)
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1217268 posted 09/25/15 07:02 AM     Remind Me!  Send Private Message   Edit Post
I'd swap it out since its under warranty but it sounds like something else to me. If it starts fine when the engine is cold I don't know why it would drag later once the engine is warm. Maybe one of the accessories tries to seize when they get hot like the alternator or P/S pump? Really hard to diagnose from a distance.
MuffinMan7580
570/1000
Galant VR-4 org Post #: 1217433 posted 09/27/15 10:46 PM     Remind Me!  Send Private Message   Edit Post
It may have nothing to do with it, but you could also double check your grounds. Hot surfaces tend to be poor conductors, especially if they're old and corrosion is present.
'92 GVR4 #570/1000
Posts: 142 | From: Fort Bragg, NC | Member Since: 08/06/11 | IP: (65.191.76.208) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1217457 posted 09/28/15 09:05 AM     Remind Me!  Send Private Message   Edit Post
Knowing this, I'd say it's either the starter or the cables. Hot cables have more resistance. If they are worn and fraying it can cause these issues, but a starter is more likely.
Quoting alik:
Quoting prove_it:
12yr+ Vr4 owner.
Family Guy
alik
Member +
40/2000
Galant VR-4 org Post #: 1217498 posted 09/28/15 04:04 PM     Remind Me!  Send Private Message   Edit Post
Dude.
It WAS the starter.
Even though Autozone checked it 15 ways to Sunday, it was making some rattling sound. I took a replacement home along with the new one, installed the new one, and right now I'm sitting in the car, car is hot, and it refires without skipping a beat. Fucking A!
Posts: 357 | From: Boston, MA | Member Since: 08/08/06 | IP: (2607:fb90:2900:3) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1217499 posted 09/28/15 04:27 PM     Remind Me!  Send Private Message   Edit Post
Awesome, glad you got it figured out.
Whoodoo
buff guys = good time but my dream is to fondle 1051
62/2000
Galant VR-4 org Post #: 1218273 posted 10/10/15 08:41 AM     Remind Me!  Send Private Message   Edit Post
Glad you got the problem solved. In case anyone searches for this in the future I thought I would share my hotmail start problem that had a different solution. Occasionally on a hot start It wouldn't fire up at all, sometimes it would start but run rough like it only had three cylinders, and sometimes it would be fine. I suspected the power transistor but swapping that had no affect. After a nice long 2 hour trip, my radio started to turn off, dash lights got funky... You know where this is going. Failed alternator - oh and it must have lunched my battery too because one cell wouldn't hold a charge. If someone is having similar issues I would get the alternator checked.
62/2k
Posts: 926 | From: Binghamton, NY | Member Since: 07/11/09 | IP: (24.179.98.130) | Report this post to a Moderator
Generated in 0.093 seconds in which 0.062 seconds were spent on a total of 14 queries. Turbo powered.
