Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Fuel pumps
Fuel pumps
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215205 posted 08/24/15 03:29 PM     Remind Me!  Send Private Message   Edit Post
I'm looking for a fuel pump that has the flattest flow vs pressure possible. The bosch -044 pump fits the bill perfectly. Only problem is I really don't want to mount a pump externally and can't seem to find anything on mounting a -044 in tank. Is this not possible/recommended? Is there some new fangled pump that mounts internally that I don't even know about yet? It needs to flow at least 220 lph @ 90psi. It will probably never flow E85 so that's not a concern.
I love my crazy mother!!!
Posts: 1675 | From: Manchester, NH | Member Since: 07/17/06 | IP: (74.94.142.161) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1215207 posted 08/24/15 04:05 PM     Remind Me!  Send Private Message   Edit Post
Would the Deatschwerks DW300 pump work? It's exactly like a walbro 255, but way better since it's a turbine pump instead, plus 2 year unlimited warranty.
DW300 specs.
Otherwise, not sure about an in-tank pump that has stable flow with pressure.
The bosch can be mounted in-tank, but you'll need to fab up some sort of sock and mounting method. The DW pump mounts like a 255, I mounted mine using the walbro install kit even. So no mods/fab needed.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Edited by prove_it (08/24/15 04:08 PM)
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215213 posted 08/24/15 05:33 PM     Remind Me!  Send Private Message   Edit Post
I saw this chart and am liking how the 044 doesn't flow an obscene amount of fuel at idle but still beats almost all the other pumps at 90 psi. According to this test too the DW300 won't be enough fuel.
[image][/image]
Edited by CutlassJim (08/24/15 05:34 PM)
Posts: 1675 | From: Manchester, NH | Member Since: 07/17/06 | IP: (73.143.213.37) | Report this post to a Moderator
KJL
Newbie
1788/2000
Galant VR-4 org Post #: 1215217 posted 08/24/15 06:16 PM     Remind Me!  Send Private Message   Edit Post
Jim, back in the day there were a good amount of people running 044s in-tank on 1Gs. There should be some write ups on the dsmlink forums along with a few pics from people selling them, like this: click
I used to feed an in-line 044 with a 255 on my 2G; partly because testing proves it will maintain flow better at higher pressures, and partly because 2G's have suck-ass gas tanks.
Kyle L
263/1000
1788/2000
Posts: 3 | From: Manchester,NH | Member Since: 06/08/14 | IP: (2601:18d:8102:12) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215220 posted 08/24/15 06:37 PM     Remind Me!  Send Private Message   Edit Post
Minus the pantyhose for a strainer I like it!
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1215226 posted 08/24/15 07:48 PM     Remind Me!  Send Private Message   Edit Post
You didn't mention what voltage. Also the injector size?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215253 posted 08/25/15 06:57 AM     Remind Me!  Send Private Message   Edit Post
Stock alternator voltage. Injector size shouldn't matter but 4x 1000's.
715/1000
1284/2000
Galant VR-4 org Post #: 1215256 posted 08/25/15 08:11 AM     Remind Me!  Send Private Message   Edit Post
Are you against running a dual pump set-up?
12yr+ Vr4 owner.
Family Guy
138/2000
152/1000
Galant VR-4 org Post #: 1215264 posted 08/25/15 09:12 AM     Remind Me!  Send Private Message   Edit Post
i have an AEM320 50-1000, you should look into them. i really like mine.
138/2000
152/1000
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.25.140) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215276 posted 08/25/15 10:47 AM     Remind Me!  Send Private Message   Edit Post
Quoting prove_it:
Not against running dual pumps just don't want a pump outside the tank. Two pumps in parallel would get me double the flow at the pressures I'm not worried about but still drop off up top. A series setup is all that would work for me.
That AEM pumps chart doesn't even go up to 90 psi which is not a good sign.
Almost every aftermarket pump will flow enough fuel in a regular setup but we are looking to run 55-60 psi base pressure with up to 30-32 on top of that. I think I'm going to have to lean towards an Evo 9 pump in tank feeding a Bosch -044 external.
I'm mostly asking because last time I looked into fuel pumps your choices were Supra/Denso, Walbro 190 or 255 and that's it. Seems like everyone makes a pump these days but are still focusing on people running 43.5psi base pressure.
715/1000
1284/2000
Galant VR-4 org Post #: 1215280 posted 08/25/15 11:22 AM     Remind Me!  Send Private Message   Edit Post
43.5 PSI is the industry standard for fuel systems. Injector flow, pump flow, line size are all calculated at a standard 43.5 psi. Knowing that your going to be pushing that high, I'd agree that a series pump set-up would be best.
Pros and cons on both sides.
12yr+ Vr4 owner.
Family Guy
OldHairyBastard
I take bottom on trannies
1/0000
Galant VR-4 org Post #: 1215282 posted 08/25/15 11:38 AM     Remind Me!  Send Private Message   Edit Post
If you pull the pin and basket out of the in tank feed pump that's there to help with holding pressure you will be able to increase the flow but I would recommend a different route. I would suggest a high volume low PSI pump to feed a small one gallon tank from your gas tank with a high pressure pump to pull from the one gallon tank. This insures that you will not be sucking air on hard accelerations and corning and cuts out any flow problems with a stock like pump. This would probably be your best route for a time attack, 1/4 mile and road course daily driver. It's a race proven design and not hard to do. Or you can replace your tank with a proper fuel cell but even with the sponge you might still have some starvation issues. One thing I like about this type of system is that you can use an old school fuel filter for carbs on the low pressure side and eliminate all of the restrictions between your high pressure pump and your fuel rail.
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-210M
2008 Toyota Sequoia 5.7L V8-125M
2013 Toyota Tundra 5.7L V8-107M
2017 VW Passat 1.8L Turbo-45M
2019 Cevy Camaro SS 1LE-5M
Edited by OldHairyBastard (09/01/15 01:18 PM)
Posts: 4500 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (50.193.72.173) | Report this post to a Moderator
swe_gvr4_1991
Galant VR-4 org Post #: 1215283 posted 08/25/15 12:18 PM     Remind Me!  Send Private Message   Edit Post
You will be more than happy with a in-tank mounted 044.
I have ran mine like that for many years. Removed the check valve and mounted a straight piece in place. Starts right up on every crank.
Running 47 PSI base pressure on my RC 1000's with max boost of 2 bar (30 PSI). Never once have I seen a rising AFR due to the pump not being able to keep up.
Pump sees gasoline, E85 and mixtures inbetween in cycles many times per year.
I went through two Walbro pumps before switching to the 044. Never looked back.
.. KiM H ..
Galant VR-4 1991. Gulf spec.
Author of Swede Density software - REAL speed density for 1G's and GVR4's - Videos
Edited by swe_gvr4_1991 (08/25/15 12:19 PM)
Posts: 177 | From: Sweden, Alingsås | Member Since: 07/27/06 | IP: (85.228.6.197) | Report this post to a Moderator
diambo4life
Member +
476/2000
Galant VR-4 org Post #: 1215552 posted 08/29/15 09:53 PM     Remind Me!  Send Private Message   Edit Post
The AEM 320 pump would be the best for a single on gasoline. Compact and easy bolton. I can tell you right now it works great at 90psi line pressure. I have two in #476. I have also used the Bosch 044 in my old car and that worked great too.
1991 Belize Green GVR4 #476/2000: 788WHP/588wTQ (dynojet) Old setup, 3400lbs
Posts: 250 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (68.12.105.68) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1215568 posted 08/30/15 09:49 AM     Remind Me!  Send Private Message   Edit Post
diambo, any issues with a wacky fuel gauge? I had 2 255HP's in #108 for a little while and while driving on the highway for extended periods of time, the gauge would start to drop because I assume the pumps were sucking the baffled section in the tank down faster than the windows/pipes that feed the baffled section could refill it.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (2601:49:102:1540) | Report this post to a Moderator
diambo4life
Member +
476/2000
Galant VR-4 org Post #: 1215593 posted 08/30/15 06:08 PM     Remind Me!  Send Private Message   Edit Post
Yes, I have fuel gauge issues but I suspected it was going to happen since squeezing that stuff into the tank is extremely tricky. My Galant almost rarely has less than 1/2 a tank of E85 in it anyway so I don't worry too much. The pump(s) work phenomenal. From my experiments, don't go over 95psi. I think there's a bypass set there. But again, with 43psi base, that's 52psi boost.
Edited by diambo4life (08/30/15 06:08 PM)
Coltsfan
631/1000
Galant VR-4 org Post #: 1215597 posted 08/30/15 08:07 PM     Remind Me!  Send Private Message   Edit Post
That's good to know about the 95 psi cutoff since I run around 52psi base pressure in my Colt and screw the boost controller in until it bottoms out.
I agree with Old Hairy Bastard about the swirl pot approach. I made one for my Colt out of a 4" cylinder to house my Walbro, and I feed it with a $30 in-tank lift pump designed for a Ford pickup. You can turn smoky AWD doughnuts on a half gallon of fuel.
92 Galant Vr4 631/1000 ---------DD well on it's way to having new everything...
90 AWD Colt Hatchback ----------Fun car
51 Buick Special ---------------Boring car
Edited by Coltsfan (08/30/15 08:20 PM)
Posts: 200 | From: Tonawanda | Member Since: 05/04/14 | IP: (76.180.2.9) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 1215606 posted 08/30/15 10:12 PM     Remind Me!  Send Private Message   Edit Post
What about a Walbro 465?
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2354 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (70.196.137.31) | Report this post to a Moderator
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.084 seconds in which 0.048 seconds were spent on a total of 14 queries. Turbo powered.
