Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Start Up Issues. RESOLVED for now
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1214448 posted 08/12/15 04:14 PM     Remind Me!  Send Private Message   Edit Post
The question is, what triggers the 3 lights in the stock boost gauge when you turn the key to on?
All I get is a solid CEL when I turn the key to on. Unless I first disconnect and reconnect the positive battery lead, then the CEL goes off after 5 seconds or so and I get the boost lights. That only lasts for one start, after starting it goes back to a Solid CEL and no lights. Am I looking at a relay? bad ground? fuse? I've tried everything I can think of.
Edited by Mn92gvr4 (08/15/15 12:30 PM)
Posts: 110 | From: North branch mn | Member Since: 01/11/14 | IP: (96.2.134.194) | Report this post to a Moderator
Galant VR-4 org Post #: 1214452 posted 08/12/15 05:05 PM     Remind Me!  Send Private Message   Edit Post
Check Mpi relay is functional. See if you can connect to the diagnostic port.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.35.71) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1214453 posted 08/12/15 05:10 PM     Remind Me!  Send Private Message   Edit Post
MPI relay is functioning properly. I can connect link when all is well but there isn't any codes. when shes in the shitter I cant connect.
936/1000-almost going places
95 Honda civic notec DD
Galant VR-4 org Post #: 1214454 posted 08/12/15 05:12 PM     Remind Me!  Send Private Message   Edit Post
Try another ecu? Have the caps been leaking in yours?
Edited by tektic (08/12/15 05:13 PM)
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1214455 posted 08/12/15 05:15 PM     Remind Me!  Send Private Message   Edit Post
I just had the caps all replaced when I had link installed. she was clean then she is cleaner now. but that's not the issue. Im not getting power somewhere. almost as if something isn't resetting after I shut the car off
Galant VR-4 org Post #: 1214477 posted 08/12/15 09:03 PM     Remind Me!  Send Private Message   Edit Post
Start with ignition harnesses then check grounds. If the components work that leaves wires. I got nothing else.
Better yet check from the ecu harness for power and ground and work backwards. That may prove easier.
Edited by tektic (08/12/15 09:08 PM)
"Just to be pedantic!"
Galant VR-4 org Post #: 1214537 posted 08/13/15 08:25 PM     Remind Me!  Send Private Message   Edit Post
did you check what fault code is being stored by the ECU which is triggering the CEL to come on in the first place?
Posts: 2161 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (122.62.148.183) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 1214564 posted 08/14/15 12:35 AM     Remind Me!  Send Private Message   Edit Post
Quoting Mn92gvr4:
Do you have a turbo timer?
the bitterness of low quality remains long after the temporary joy of a low price has faded
Posts: 3541 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (70.196.194.181) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1214686 posted 08/15/15 12:29 PM     Remind Me!  Send Private Message   Edit Post
No on the timer. At this point it is resolved. I deleted the fuse box that hooks directly to the battery and got nothing. unplugged the ecu and plugged it back in. so far it has been working for 2 days without interruption. not entirely sure what did it tho.
thanks for the imput guys.
Generated in 0.062 seconds in which 0.045 seconds were spent on a total of 14 queries. Turbo powered.
