Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Drive shaft not straight
Galant VR-4 org Post #: 1212978 posted 07/21/15 08:04 PM     Remind Me!  Send Private Message   Edit Post
I have all the proper engine mounts and my drive shaft is still not straight. The car make entirely too much noise. I'm going to try to get it on a frame straightener on Saturday to make sure it's not twisted. I'm not sure what else it could be. Any ideas?
Edited by tektic (07/21/15 08:06 PM)
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.56.49) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1212979 posted 07/21/15 08:28 PM     Remind Me!  Send Private Message   Edit Post
Can you get under the car and post a couple pictures? Aside from the mounts and actual unibody as you mentioned, there isn't really much else I could think of unless there is a problem with the driveshaft itself.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (2601:49:102:1540) | Report this post to a Moderator
Galant VR-4 org Post #: 1212983 posted 07/21/15 09:20 PM     Remind Me!  Send Private Message   Edit Post
Is the drive shaft different between an auto and a manual?
Fiascoxl
Member +
740/1000
Galant VR-4 org Post #: 1212994 posted 07/21/15 11:33 PM     Remind Me!  Send Private Message   Edit Post
I will say that the drive shaft does not sit exactly straight from transfer case to rear differential. It comes out the transfer case slightly towards the passenger side, then after the first carrier bearing it shoots straight to the rear differential.
92 VR4 #740 Nile Black
Posts: 320 | From: Stuarts Draft, Va | Member Since: 01/26/13 | IP: (2601:5ce:100:b94) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1213007 posted 07/22/15 08:09 AM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
you shouldn't be able to get an auto driveshaft. the AWD was never introduced to america in automatic, at least i don't think it was.
138/2000
152/1000
Edited by transparentdsm (07/22/15 08:10 AM)
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.26.248) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1213008 posted 07/22/15 08:12 AM     Remind Me!  Send Private Message   Edit Post
Could be the lobro joint if its making noise, Or possibly your center diff in the trans...
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1653 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (69.11.233.34) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1213010 posted 07/22/15 08:47 AM     Remind Me!  Send Private Message   Edit Post
Quoting Fiascoxl:
Exactly. It's got a weird angle in it factory. I don't think you have some crazy chassis problem. Sounds more like a driveshaft or T-case/differential problem. This is why pictures can help. It might look completely normal to some of us that have been under these things for years.
91 #108/2000- link
05 CTS-V
09 Hummer H3T
715/1000
1284/2000
Galant VR-4 org Post #: 1213012 posted 07/22/15 08:49 AM     Remind Me!  Send Private Message   Edit Post
The shaft doesn't go perfectly straight from t case to rear diff. It does "curve" some towards the passenger side around where the stock cat convertor would be.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Galant VR-4 org Post #: 1213022 posted 07/22/15 11:22 AM     Remind Me!  Send Private Message   Edit Post
I looked for a picture but couldn't find a decent one. I'd have to jack it up to show what I'm talking about. There is a good sized dent in the floor near the first mount though.
Its a ggsx that came auto utilizing the auto drive shaft so they made it state side in that aspect.
I originally thought it was mostly because of the aluminum flywheel I had in here. That's gone still makes a racket.
Ill get a pic tonight when its cool out. Wait no going out tonight... Tomorrow maybe. Its not a ridiculous angle but its not as straight as it could be.
138/2000
152/1000
Galant VR-4 org Post #: 1213023 posted 07/22/15 11:42 AM     Remind Me!  Send Private Message   Edit Post
i did not know they made the GSX in an automatic. thats cool
138/2000
152/1000
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1213025 posted 07/22/15 11:43 AM     Remind Me!  Send Private Message   Edit Post
Driveshaft would not be different Auto vs Manual. But, if it is dented near the carrier bearing bracket, and it changes the angle it is mounted at, then that could be the issue
Thom
Posts: 905 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (50.58.165.200) | Report this post to a Moderator
Galant VR-4 org Post #: 1213030 posted 07/22/15 01:25 PM     Remind Me!  Send Private Message   Edit Post
You don't want a driveshaft perfectly straight in all planes actually. There needs to be offset for the u joints to work properly and not transmit vibration and noise.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10838 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Banthony
555/1000
Galant VR-4 org Post #: 1213034 posted 07/22/15 01:34 PM     Remind Me!  Send Private Message   Edit Post
Mine isn't perfectly straight either. As you can see, it has a slight angle to the most forward part.
97 CBR900RR
2012 Hyundai Veloster
Posts: 3537 | From: Near Seattle, Washington | Member Since: 06/02/08 | IP: (50.47.89.122) | Report this post to a Moderator
Galant VR-4 org Post #: 1213135 posted 07/23/15 07:34 PM     Remind Me!  Send Private Message   Edit Post
This is what it looks like after I took a bfh to the floor under the passenger seat.
That's an awful picture I'm just noticing.
715/1000
1284/2000
Galant VR-4 org Post #: 1213155 posted 07/24/15 08:14 AM     Remind Me!  Send Private Message   Edit Post
That pic is tricky to make out the shaft.
12yr+ Vr4 owner.
Family Guy
Galant VR-4 org Post #: 1213166 posted 07/24/15 09:41 AM     Remind Me!  Send Private Message   Edit Post
That sounds dirty.
715/1000
1284/2000
Galant VR-4 org Post #: 1213167 posted 07/24/15 09:52 AM     Remind Me!  Send Private Message   Edit Post
There's going to be a lot of that in a thread about a crooked shaft.
12yr+ Vr4 owner.
Family Guy
Galant VR-4 org Post #: 1213208 posted 07/24/15 06:46 PM     Remind Me!  Send Private Message   Edit Post
Ok now I'm leaning tword a broken center diff. I had some pretty gnarled "dug dug dug" noise in a quick right than long left maneuver it came from the front right corner.
Differential diagnosis starts by spinning wheels off the ground right?
Also is common to be able to chirp second?
Edited by tektic (07/25/15 08:11 AM)
2 registered and 6 anonymous users are browsing this forum.
Rating: *
Generated in 0.095 seconds in which 0.07 seconds were spent on a total of 14 queries. Turbo powered.
