Galant VR-4 Forums » Galant VR-4 » Technical Discussions » I think I found the problem.
Iggy
741/2000
Galant VR-4 org Post #: 1211563 posted 07/06/15 05:04 PM     Remind Me!  Send Private Message   Edit Post
So after replacing my rubber brake lines because one had blown, I wasn't getting any fluid to the rear wheels. The i decided to check the block on the fire wall that the lines run through, which I believe is the propositioning valve(tho I have no idea how it works.) I have fluid going into it and NONE coming out of it. I even took it off an tried to blow compressed air trough it an got nothing.
So my question is, why can I not find one for a car with ABS. Even JNZ only sell them for non ABS cars. So what's the deal? can I use a non ABS one?
heres some pics of the part.
Dirt, snow, grass, or ice if it's a loose surface I'm going sideways and happy about it.
Posts: 50 | From: Ashland. Wi | Member Since: 05/08/15 | IP: (68.187.138.207) | Report this post to a Moderator
467
mass moment of inertia
467/1000
Galant VR-4 org Post #: 1211569 posted 07/06/15 05:38 PM     Remind Me!  Send Private Message   Edit Post
If you bypass the ABS pump yes you can. Non ABS lines from a galant or 1g eclipse will bolt up, or you can carefully rebend the present lines to fit.
Posts: 915 | From: Fremont Ca | Member Since: 03/16/01 | IP: (24.6.21.118) | Report this post to a Moderator
Galant VR-4 org Post #: 1211572 posted 07/06/15 06:22 PM     Remind Me!  Send Private Message   Edit Post
I'm not sure compressed air is valid test to prove it's no good.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10857 | From: Michigan | Member Since: 03/05/01 | IP: (2602:304:ccc7:35) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1211577 posted 07/06/15 07:22 PM     Remind Me!  Send Private Message   Edit Post
Not the best way to do it, but sometimes quick stabs of the brake pedal will clear up a stuck valve.
Make sure all brake lines are connected correctly.
Bleed fronts.
Try to bleed rears. If that is a no go and you have what feels like a brake pedal do some kick ninja quick to the brake pedal to try to unstick it.
Bleed rears.
Bleed fronts again.
Posts: 429 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:e000:1c0d:8) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1211579 posted 07/06/15 07:43 PM     Remind Me!  Send Private Message   Edit Post
I just had to replace one of those in a 1G because of a stuck valve. I don't remember if they are available anymore, but the part number for a new one is MB699656 (That's the Galant specific number). JNZ Tuning lists them for $73. You would have to call or email to check availability.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (2601:49:102:1540) | Report this post to a Moderator
0 registered and 16 anonymous users are browsing this forum.
Generated in 0.047 seconds in which 0.038 seconds were spent on a total of 14 queries. Turbo powered.
