Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Clutch fork position
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1205885 posted 04/08/15 10:14 PM     Remind Me!  Send Private Message   Edit Post
I'm mating my engine and transmission together before dropping the motor in my car. Once the transmission is bolted up to the block, it seems like my clutch fork is sitting a bit too far toward the driver side of the window in the bellhousing. I have just under a 1/4" between the edge of the clutch fork and the edge of the window. There's nothing that I can find that's abnormal about my setup, so I'm thinking the pressure plate fingers just might be taller than average. I'm not super worried, but want someone to sanity check this. Here are all the details:
-Centerforce dual friction organic/carbon composite clutch & pressure plate
-ACT StreetLite Flywheel
-clutch fork in good condition
-New Mitsu OEM TOB
-New pivot ball (not shimmed)
-starter plate is installed
Can someone look at these pictures and throw in their .02?
Just under 1/4" of space in this picture:
Posts: 3436 | From: SoCal | Member Since: 01/02/12 | IP: (72.45.2.251) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1205896 posted 04/09/15 01:48 AM     Remind Me!  Send Private Message   Edit Post
That looks way too far to the right. Also, pic two makes it look like the fork isn't fully seated on the pivot ball.
*edit* Maybe it is fully seated. Hard to tell in that pic. I can't tell wtf is going on, but it looks too far from center.
-Mark
1051
Edited by turbowop (04/09/15 01:49 AM)
Posts: 11965 | From: Yakima, WA | Member Since: 04/29/01 | IP: (71.81.174.197) | Report this post to a Moderator
diambo4life
476/2000
Galant VR-4 org Post #: 1205899 posted 04/09/15 07:25 AM     Remind Me!  Send Private Message   Edit Post
It really will depend. Most of the times sitting too far to the right like that is from shimming the pivot ball quite a bit. Most DSM clutch setups work best with the fork almost in the middle of that window. Mine sits almost like that but I have an ACT 3200 which required it to fully disengage. The only real test is to make sure the clutch will not start slipping on you prematurely.
PS: I had the CFDF in my Galant about two years ago and that worked perfectly with the fork in the "normal" middle position.
1991 Belize Green GVR4 #476/2000: 788WHP/588wTQ (dynojet) Old setup, 3400lbs
Edited by diambo4life (04/09/15 07:26 AM)
Posts: 249 | From: Edmond, OK. USA. | Member Since: 07/07/13 | IP: (69.174.87.60) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1205900 posted 04/09/15 07:31 AM     Remind Me!  Send Private Message   Edit Post
Is it a new flywheel, or machined? Seems off to me for what parts you have. Is it a 2nd gen revised clutch fork?
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1205903 posted 04/09/15 08:04 AM     Remind Me!  Send Private Message   Edit Post
The fork is definitely seated on the pivot ball. Far as the fork goes, it's not a 2g fork that I'm aware of. It came out of my old transmission, which worked fine at the time, so unless someone swapped it, it's not from a 2g.
Flywheel is used, but never machined.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (04/09/15 08:07 AM)
(174.236.230.35) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1205904 posted 04/09/15 08:14 AM     Remind Me!  Send Private Message   Edit Post
Hard to tell, but in the second pic it looks like the fork is touching the PP. If it is or the clearance is super thin, I'd say there is something wrong with the fork, or the pivot ball.
I don't think it should be that far off from center with that clutch set-up.
12yr+ Vr4 owner.
Family Guy
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1205906 posted 04/09/15 08:37 AM     Remind Me!  Send Private Message   Edit Post
Well, the pivot ball is new. The fork clears the pp fine where it's currently sitting.
I suppose the fork could be wrong, I just assumed not since it was out of the other 1g trans. Ill need to do some research and figure out what different revisions there are, and how they could affect position.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Galant VR-4 org Post #: 1205907 posted 04/09/15 08:42 AM     Remind Me!  Send Private Message   Edit Post
What was the step height of the flywheel? I'm pretty sure that was my issue.
7 1G DSM's now a GGSX build.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1205909 posted 04/09/15 08:47 AM     Remind Me!  Send Private Message   Edit Post
There is only one revision on the fork. The 2g was a redesign that is much stronger and has better clearance. It still has the same dimensions, so I doubt it would make a difference. Yours could be bent, but it would be in the wrong direction. In fact Mitsu will sell you a 2G one when ordering a fork for a 1G.
Even if the flywheel was never machined, you still need to check step height. You can't assume it's right. Also I'd measure the thickness of the disc and call southbend to verify it's the right disc. After that, I really don't know what would cause this.
12yr+ Vr4 owner.
Family Guy
Coltsfan
631/1000
Galant VR-4 org Post #: 1205921 posted 04/09/15 11:26 AM     Remind Me!  Send Private Message   Edit Post
I would be seriously worried abut the thickness of the disc. As it wears, it's only going to move closer to the right. There has to be something wrong.
92 Galant Vr4 631/1000 ---------DD well on it's way to having new everything...
90 AWD Colt Hatchback ----------Fun car
51 Buick Special ---------------Boring car
Posts: 200 | From: Tonawanda | Member Since: 05/04/14 | IP: (76.180.2.9) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 1205925 posted 04/09/15 12:15 PM     Remind Me!  Send Private Message   Edit Post
You could also run into an issue with the fork rubbing against the casting of the pressure plate. Happened to me once. Started it up - sounded like a woodpecker on crack. It turned out I had overshimmed the pivot ball. Had to pull the trans to fix it...
Roger B. Scott
'91 Belize Green
Posts: 3313 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (153.90.192.83) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1205930 posted 04/09/15 01:58 PM     Remind Me!  Send Private Message   Edit Post
I'll pull it back apart and take some measurements/pictures of the assembly. Thanks for the help guys.
One other question...Any of you still running a stock cast flywheel? Word on the street is, they explode. Any truth to that?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (04/09/15 02:00 PM)
(174.236.228.108) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1205933 posted 04/09/15 02:39 PM     Remind Me!  Send Private Message   Edit Post
They CAN. It's happened, but not to anyone I've known. Lightened ones will for sure.
12yr+ Vr4 owner.
Family Guy
Galant VR-4 org Post #: 1205937 posted 04/09/15 02:46 PM     Remind Me!  Send Private Message   Edit Post
Probably very dependent on how hard/how often you launch. I can't see it happening from normal usage unless the flywheel has gotten damaged/cracked and continues to be used.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10838 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1205952 posted 04/09/15 05:04 PM     Remind Me!  Send Private Message   Edit Post
Quoting prove_it:
Archive thread dealing with the flywheel picture we all rememebered but is now missing on the interwebs
Found it on Tuners searching "Bruce Kwartlers flywheel".
Click
Facebook video
C53A 1 of the ~1500
Edited by FlyingEagle (04/09/15 05:09 PM)
Posts: 1631 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.239.219.116) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1205979 posted 04/10/15 08:09 AM     Remind Me!  Send Private Message   Edit Post
Forgot about that, never running a stock wheel ever again.
12yr+ Vr4 owner.
Family Guy
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1206138 posted 04/12/15 02:46 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
Pulled this G-bomb about a year ago.
Posts: 1275 | From: MD | Member Since: 04/07/05 | IP: (108.18.239.74) | Report this post to a Moderator
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1206140 posted 04/12/15 03:08 PM     Remind Me!  Send Private Message   Edit Post
I think the fork is on the ball correctly. Darkness conceals the far end from view. Here is a picture of a new set from the top, then a couple more at an angle similar to your #2 picture.
Done there, been that
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1206152 posted 04/12/15 05:01 PM     Remind Me!  Send Private Message   Edit Post
If you didn't shim the pivot ball, and have pressure plate clearance, I wouldn't worry. You want the fork about 2/3 through the window for proper disengagement. Usually the step height is the other way (deeper) and the fork will only be about halfway, and will put the pedal engagement all the way at the floor.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (69.249.15.96) | Report this post to a Moderator
WaRrIoRs16
Member +
796/2000
Galant VR-4 org Post #: 1206162 posted 04/12/15 08:41 PM     Remind Me!  Send Private Message   Edit Post
My fork is sitting in about that same location. I shimmed my pivot ball til it was at that location because otherwise my clutch wasn't disengaging until the pedal was on the floor. It works fine for me. I have a new ACT 2600 setup, fresh surface on a fidanza flywheel, brand new OEM TOB, new OEM pivot ball, new OEM fork, and I bleed the clutch correctly but it wouldn't disengage properly without the fork that far over.
796/2000 Summit White
628/1000 Summit White
91 Black Cherry Talon Auto AWD
94 Pearl White 3KGT
88 Fiji Blue Conquest TSi
03 Labrador Black Evo
Posts: 373 | From: Ferndale, WA | Member Since: 03/23/08 | IP: (204.153.130.50) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1206163 posted 04/12/15 08:42 PM     Remind Me!  Send Private Message   Edit Post
Found a little read on Tuners: Click
C53A 1 of the ~1500
presterone
'92 Protege VR-4
Galant VR-4 org Post #: 1206412 posted 04/15/15 09:35 PM     Remind Me!  Send Private Message   Edit Post
I know the guy who bought bruces VR4 and had the flywheel shoot out, he hates galants now and begged me not to resurrect that one he once had.
98 BMW 328i
92 GVR-4 #221
92 GVR-4 belize green#702
Posts: 514 | From: brunswick maine | Member Since: 01/23/12 | IP: (75.68.184.72) | Report this post to a Moderator
Eager Beaver
Galant VR-4 org Post #: 1206706 posted 04/19/15 09:05 PM     Remind Me!  Send Private Message   Edit Post
Quoting FlyingEagle:
From this thread, I think there may be room for a case to be made, that you could over-extend the clutch fingers?
Am I barking up the wrong tree?
C53A 1 of the ~1500
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1206951 posted 04/22/15 08:22 PM     Remind Me!  Send Private Message   Edit Post
It's possible, but usually happens with too thick of a shim, or extended slave rods etc. With proper pedal adjustment, you will be fine.
91 #108/2000- link
05 CTS-V
09 Hummer H3T
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1210121 posted 06/13/15 10:33 PM     Remind Me!  Send Private Message   Edit Post
So new question; How can I tell of my clutch is putting unnecessary pressure on the crank thrust?
Current setup details:
- Rod on the clutch pedal to the clutch master is nearly adjusted all the way out (nut and rod are even with the end of the clevis)
- Clutch fork position is sitting on the driver side (crank/timing belt side) of the motor just as the pics show above
- When I push the clutch fork in toward the slave with my hand, there is sufficient movement and the slave returns the fork to it's original position as it should
- Clutch is bleed, definitely no air in the system
- Clutch feels good and the disengagement/engagement is near the middle of the pedal travel
I've come to the conclusion the Centerforce PP is just tall, and causes the clutch fork to sit to the driver side...At least, that's the only conclusion can come to give all the shit I've changed and/or inspected.
So, my question really is, how can I tell if my clutch is putting pressure on my crank thrust? I'd do a check with the dial indicator, but I'd think that wouldn't show the issue until there's an issue, which I'm not trying to wait around for. Also, I've always been told if the clutch slave returns with you push it in with your hand, you're good. Any truth to this?
Any help, advice, or comments are appreciated. Thanks in advance.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (06/13/15 10:33 PM)
Pages: 1 | 2
Generated in 0.087 seconds in which 0.047 seconds were spent on a total of 14 queries. Turbo powered.
