Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Exhaust resonator type choice
Galant VR-4 org Post #: 1191711 posted 10/17/14 09:04 AM     Remind Me!  Send Private Message   Edit Post
After installing the correct engine brackets for a manual trans my exhaust no longer fits. The down pipe bangs against the body. The way I see it I have two choices. I can cut the first hanger and flange off after the down pipe and reposition them or use this as an excuse to ad a resonator where the cat would normally reside.
If I Chose to add a resonator these seem like common choices:
#1142 Vibrant Performance Ultra Quiet Resonator 3" x 10"
or
#1794 Vibrant Performance Exhaust Resonator 3" x 12"
Has anyone installed an 1142 in the cat position that can tell me how it fits and sounds? It seems like it may be a tight fit and I might just go with the 1794 so I don't run in to further issues.
Are there any other inline resonators I should consider?
7 1G DSM's now a GGSX build.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (24.45.85.14) | Report this post to a Moderator
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 1191714 posted 10/17/14 09:27 AM     Remind Me!  Send Private Message   Edit Post
It you are looking to quite it down i would go with a Magnaflow
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Posts: 4326 | From: Orlando, FL | Member Since: 04/24/03 | IP: (199.101.175.5) | Report this post to a Moderator
Galant VR-4 org Post #: 1191719 posted 10/17/14 09:50 AM     Remind Me!  Send Private Message   Edit Post
is there a specific type from Magnaflow, or your just loyal to that brand?
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 1191742 posted 10/17/14 12:55 PM     Remind Me!  Send Private Message   Edit Post
On my vr4 i wanted it quite. I have tried Borla and vibrant but the magnaflow silence the beat , I am will be cutting my the apeni N1 of my Evo and replace it with a magnaflow very soon .
pick the size you need
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Galant VR-4 org Post #: 1191779 posted 10/17/14 06:45 PM     Remind Me!  Send Private Message   Edit Post
Cool. Expert recomndation! Just to be clear can you recall which borla and vibrant resonators you used?
Eager Beaver
Galant VR-4 org Post #: 1191846 posted 10/18/14 07:45 PM     Remind Me!  Send Private Message   Edit Post
This will make your car relatively quiet, maintain a burble at idle and sound deep enough to let you know it's installed when leaning into it; boost makes it a little bit louder.
These mufflers (you want a resonator and likley it's designed exactly the same way, just with less volume and sound deadening material/packing), use a straight pipe
with round holes/perforations in the internal section of the pipe.
The casing can rot out all it wants, the pipe will still be standing when it's all said and done. Ask me how I know ...
Just installed the muffler in this link (Colt w/4g63t, 264/272, Evo3 turbo, 2.5", 2x90 degree and an over axle section, catalytic installed).
Magnaflow mufflers - not GVR4 specific, 2.5" offset/offset, universal
Granted 2.5" piping is always quieter, so install a catalytic and 1 long or two short
resonators and call it a day. The more length and volume in the resonator, the more drone
you will help to cancel out.
You still need a better muffler to make the car liveable in my books, but 3" usually means
a high flow option and nothing but.
Try a pair of these on:
5" wide, 14" long universal satin finish Magnaflow
Edited by FlyingEagle (10/18/14 07:52 PM)
Posts: 1631 | From: THE Ottawa | Member Since: 03/05/05 | IP: (99.239.220.151) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1191849 posted 10/18/14 07:51 PM     Remind Me!  Send Private Message   Edit Post
I have this same magnaflow on my VR4, 3" from the o2 housing back with a high flow cat. Car is decently quiet but not super quiet. It can get loud when you get on it. I wish the sound had more character, not enough rumble and mostly just a deep tone. It has that typical 4g63 sound but I wish it had a little something more. No idea what I am looking for exactly or how to get it.
I have been considering redoing my setup and running just a resonator or two in line on the straight section of the exhaust: cat converter -> resonator -> resonator, and then just a straight pipe out the back, no muffler. I don't want it to be loud but I want a different sound and some more rumble.
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (67.168.54.49) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1191876 posted 10/18/14 11:48 PM     Remind Me!  Send Private Message   Edit Post
Coy, you have emissions in wa?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (2605:a000:140d:c) | Report this post to a Moderator
coyotes
Hipster VR4
1226/2000
Galant VR-4 org Post #: 1191884 posted 10/19/14 03:41 AM     Remind Me!  Send Private Message   Edit Post
Every 2 years, but 25 year old vehicles are exempt. I wold continue to run a cat however, personal ethics.
1226/2000
Posts: 1544 | From: Seattle, WA | Member Since: 11/15/13 | IP: (2607:fb90:190f:5) | Report this post to a Moderator
boostx
On The Wrong Side.
23/2000
Galant VR-4 org Post #: 1192036 posted 10/21/14 05:46 AM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
The vibrant one was the Ultra Quiet Resonator. i can't remember which one of the borla it was.
Love the F Letter
Four wheel steering
Four doors
Four cylinders
Force induced
><((((º>
Galant VR-4 org Post #: 1218150 posted 10/08/15 01:23 PM     Remind Me!  Send Private Message   Edit Post
Had a vibrant resonator installed today.
It had very little effect on reducing sound. I shoud have got a bigger one. Or just went with the magnaflow. Now I don't have as much boost creep. I had exhaust leaks fixed as well so that may of had something to do with it.
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (47.20.56.49) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1218162 posted 10/08/15 03:17 PM     Remind Me!  Send Private Message   Edit Post
Your lifting points on the front and the front right "framerail" have me like
I love my crazy mother!!!
Posts: 1672 | From: Manchester, NH | Member Since: 07/17/06 | IP: (104.129.192.65) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1218165 posted 10/08/15 03:45 PM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
What size? I've been thinking about the vibrant 18" bottle resonator. I've got a 3" turbo-back system and I don't thing the ultra quiet would fit with the extra diameter.
That being said, if your didn't notice much of a difference in sound, that's something for me to consider.
RIP 543
Ded click
2006 Suzuki SV-650 (for sale)
2011 BMW 335d (~510'lb/tq and 36mpg. hwy. How can you go wrong?)
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (209.152.44.218) | Report this post to a Moderator
Galant VR-4 org Post #: 1218166 posted 10/08/15 03:47 PM     Remind Me!  Send Private Message   Edit Post
I know :'(
I'm ordering metal for subframe connectors tonight. Talked to the muffler guy about welding it on for me.
That's what your talking about right?
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.35.171) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1218174 posted 10/08/15 06:36 PM     Remind Me!  Send Private Message   Edit Post
No, he means because they didn't use the pads of the lift on the pinch welds/subframe/frame rail etc. Just swung the arms under there and let them touch the floor and pinch welds. I'm anal, so it bothers me, but I know a lot of quick shops do this. As long as you don't have side skirts lower than the pinch welds, it's probably not hurting anything. You'll never see me do it on my or a customers car at home though.
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Edited by EMX5636 (10/08/15 06:37 PM)
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (2601:49:102:1540) | Report this post to a Moderator
Galant VR-4 org Post #: 1218180 posted 10/08/15 07:32 PM     Remind Me!  Send Private Message   Edit Post
[Quote]
I think its the 12". I was thinking the same thing about the diameter but seeing this one installed there's room for a wider one.
Fish
392/2000
Galant VR-4 org Post #: 1218188 posted 10/08/15 09:18 PM     Remind Me!  Send Private Message   Edit Post
I did that to a cop car once at work, dodge charger. I positioned the pads under the frame rail and the arms caught the pinch weld before the pads contacted. I didn't notice until the car was already off the ground and figured it would be ok. It was.
On another note, at my old job I saw somebody lift a dodge sprinter by the pinch welds. It looked fine but I know those things are fairly heavy. After he lowered it the doors barely opened due to body deformation. The customer was so pissed. That's always been a good reminder for me to watch where I'm lifting from.
Quoting EMX5636:
Posts: 206 | From: Idaho Falls, ID | Member Since: 11/13/12 | IP: (159.118.221.240) | Report this post to a Moderator
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1218248 posted 10/09/15 05:10 PM     Remind Me!  Send Private Message   Edit Post
Quoting tektic:
[Quote]
Evan's (EHMotorsports) advice to me regarding resonators was that I should get the absolute longest one I can fit on my car. Anyone here have an 18" resonator that can share their experiences?
RIP 543
Ded click
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (209.152.44.116) | Report this post to a Moderator
Gtpdz
594/1000
Galant VR-4 org Post #: 1219635 posted 11/02/15 05:06 PM     Remind Me!  Send Private Message   Edit Post
I have tried with a meganaflow 3 inch resonator, around 20-22 inch I think. Quiet down the idling and low rev range mostly, according to my neighbor it was quieter. Didn't do much with the high rpm range though. Gonna put on the vibrant flat black muffler later to see if it helps. Right now it has some cheap 4 inch outlet on, my garage door and wall are resonating when I park inside and idling, but not loud to the ear just a very deep rumble.
Posts: 140 | From: Gig Harbor, WA | Member Since: 03/12/15 | IP: (74.115.237.100) | Report this post to a Moderator
Generated in 0.081 seconds in which 0.043 seconds were spent on a total of 14 queries. Turbo powered.
