Car doesnt start up,was fine yesterday, it just clicks now. :l
nsin
monterey bay, ca.
I use car about once per month, autocross mainly. I turn on, and let her idle for 10min, just to keep fresh, maybe once per week (small battery). So, it didnt turn on yesterday, so i though batt. was dead. I charged it today and nothing. The ecu clicks on ignition, then clicks again a few secs later, like normal when ignition off. Car is pretty much stock, besides suspension. any ideas? /ubbthreads/images/graemlins/confused.gif thanks guys..
BlitzVR4
Virginia Beach, VA
Mine did the same thing. Check the battery cables. Sometimes corrosion builds up on the wire near the terminals.
JCorbo25
Sacramento, CA
could also be the clutch sensor, if it doesn't detect the clutch as disengaged then it will just click.
nsin
monterey bay, ca.
Ok i will check cables. those sensors go out often?
quicktsi
Yukon, OK
I had the plastic piece that pushes the clutch switch in, brake from old age. I just unplugged the clutch switch.
James
Port richey Florida
Always unplug the clutch switch.
nsin
monterey bay, ca.
Oh i thought it was a sensor, not switch.. the switch has been bypassed. i cant find clayton book damit. iguess i can check voltage at starter, start there? what about ecu? it does have those updated capacitors.. everything else works fine. just no start. Wasnt the batt. cables either. /ubbthreads/images/graemlins/dunno.gif
nsin
monterey bay, ca.
thanks for links man! Hey, it ended up being somthing before starter.. Because, i manually gave it 12v+, and she fired up! So, its a relay, im gussing..?
