Calling all transmission gurus!
maxash0775
Bakersfield, CA
So the mechanic working on my trans can't locate a part for reverse. Here is a picture of it. Does anyone know where I can get it? It is the rod and littler real piece with the number 11 stamped on it.
It's number 56
maxash0775
Bakersfield, CA
I relied on the me Janice who said he called and they can't get it but I will give them a try also for due diligence.
maxash0775
Bakersfield, CA
I just used caps to find part number. Will call dealer tomorow. Whn I punch in google search it appears to be available at multiple places on line.
Barnes
Richland, WA
Don't bother trying to replace just the little cast piece that is pinned to the shaft. Just buy the entire 5th/reverse shift rail. Just make sure you compare the new one, to the one you have. I don't remember specifically, but some shift rails have changed over the years.
maxash0775
Bakersfield, CA
Sorry if I was unclear, but you are correct. I am looking to replace the entire rail. Will have to wait till Monday to contact local dealer. I will let you know what they charge. When I order it, how will I know if its the correct one? If I am using caps and put my VIN in shouldn't that be the correct one?
maxash0775
Bakersfield, CA
Called the dealer and the response was " that part is obsolete and longer available". Thats what you really want to here!!
Near Seattle, Washington
Quoting maxash0775:
Also lookin at a 1g tranny rebuilt by TRE stage one never installed. Will any 1g manual trans 23 spline work?
tr
No. You'll need the shift rail assembly specific to your transmission.
Street Surgeon
Omaha, Nebraska
Uuuuuuuuuuuum, yes it sure will work if the following conditions are met:
1. You currently use a 23spline tcase, then it's a no brainer direct bolt-in.
2. If you have a 22spline tcase on the GVR4 there's a simple fix. Simply remove the 1G trans' 5th gear cover, slide out the 23 spline output shaft, and slide in the 22 spline shaft from the trans that you already have. Bingo, you can now use a 22 spline tcase on your "23 spline" trans.
