Galant vr4 wont turnover
jduke0308
Active member
Aurora, CO
Cant figure this out. It wont start or even turnover, I pulled the starter and got it tested, came back fine. Got a new battery still nothing. Even replaced my fuel pump and CAS with a black top with nothing remedying the problem. Let me give you guys some back round on the car and the situation in which the car died and would never start again. About a month and a half ago I was driving in rush hour traffic of course and all of a sudden when I'm rolling at 60mph the car just cuts off no power and wont start. now before that for about 3 months before that I got my caps replaced because they were leaking, also got a new knock sensor. After that the car would have a hard time starting but ALWAYS started no matter what. Now after all that it still wont even turnover just one click nothing else. All other electronics work in the car which I could care less about I just want the damn thing running again. Daily driving my 240sx is hell, its meant for the track not aging Colorado roads lol so please any help is much appreciated!
James
Port richey Florida
How much power is no power? Does your clock work? Does the radio work? If you have nothing at all I would say check your wiring around the battery/to the starter. A loose ground could cause that.
rdomeck
Indianapolis, In.
Can you turn your engine over with a wrench? Is your battery charged? You could run a wire from your trigger on the starter and touch it to your hot wire on the battery to eliminate any issues with wiring in the car!
jduke0308
Active member
Aurora, CO
Quoting James:
All electronics work I can play my radio, all lights come on in and out.
jduke0308
Active member
Aurora, CO
Quoting rdomeck:
Battery is charged, havent tried turning it over with s wrench yet but i will give it a try tomorrow.
Wizardawd
Franklin, NC
Quoting rdomeck:
That was my guess, either timing belt jumped or balance shaft siezed keeping the motor from turning. I would definately see if the motor will even turn by hand first. 1/2" drive extension/ratchet thru the driver's wheel well and try to turn it clockwise.
Wiz
