Galant VR-4 Forums » Marketplace » Cars For Sale » FS: AZ 1998 Subaru Legacy GT "restored" with WRX swap $15,000 FIRM
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 976496 posted 03/13/11 02:47 PM     Remind Me!  Send Private Message   Edit Post
This car was originally purchased as a driver with a bad head gasket on the factory 2.5 NA engine. It was completely gutted and stripped down for a thorough restoration and drivetrain upgrade. A wrecked 2002 WRX was acquired as a donor car for the complete engine/drivetrain conversion. The end result is a classy looking second generation Legacy with a factory backed power boost with an emphasis on reliability and usable every day comfort. From it's rebuilt heads to it's brand new OEM shortblock with 1 year factory warranty, this car's powertrain should be ready for years of reliable daily driver duty. Below is a complete list the work done to the car to make it what it is today...
EXTERIOR
- Complete exterior color change from red to Porsche Mexico Blue using DuPont Chroma System products.
- New OEM upper window seals (A-pillar, B-pillar, and C-pillar)
- New OEM upper door trim
- New OEM grill and emblem (charcoal)
- JDM tail lights (with clear turn signals)
- JDM projector headlights
- Filled holes in rear deck-lid from emblems
INTERIOR
- New OEM floor mats
- 2007 STI seats front and rear
- 2007 STI steering wheel
- New OEM center vent panel
- New OEM shift boot and surrounding panel
- New OEM STI 5 speed shift knob
- Leather WRX emergency brake handle
- WRX Pedals
- New Alpine SPS600 rear speakers
- New Alpine SPS600C front speakers (w/tweeters)
- New Kenwood KDC-MP345U head unit (has USB and AUX ports in front)
SUSPENSION
- New ball-joints
- New wheel bearings
- Polyurethane bushings
- 2007 WRX steering rack
- Custom modified Legacy steering column to work with WRX steering rack and u-joints
- 2007 WRX front and rear sub-frames
- New brake calipers on all 4 corners (painted red and silver)
- New brake rotors on all 4 corners
- Stainless steel braided brake lines and clutch line
- Whiteline sway bars front and rear
- Whiteline sway bar end-links front and rear
- Tokico D-Spec shocks modified for Ground Control coil-over kit
- Ground Control coil-over kit
- All control arms and spindles repainted satin black
- Rota Wheels w/black lugnuts
- Nitto NT05 tires
ENGINE/TRANSMISSION
- Complete 2002 EJ205 WRX engine and transmission swap
- Matching WRX rear differential
- Brand new OEM short block (new from Subaru) with 1 year warranty
- New OEM oil pump
- Completely rebuilt heads
- New timing belt with all new pulleys and tensioners
- New water pump
- New thermostat
- All new rubber fuel lines
- New OEM fuel filter
- New Walbro 255 fuel pump
- New OEM A/C compressor
- Rebuilt A/C lines
- New serpentine belts
- Wrinkle black powder coated intake manifold and TGVs
- TGVs deleted and ported
- Wrinkle black powder coated valve covers
- Custom 3 intake with K&N filter
- Exhaust manifolds de-tabbed and header wrapped.
- Invidia cat-less up-pipe header wrapped
- Invidia cat-less down-pipe header wrapped and modified for V-band clamp
- Custom stainless steel 3 exhaust using Magnaflow muffler with polished tip and V-band clamp
- Stock TO04 turbo from 2007 WRX (34K miles)
- Custom oversized aluminum radiator with twin SPAL fans
- Custom aluminum radiator overflow tank
- New light-weight flywheel (chromoly not aluminum)
- New clutch and pressure plate
- Completely rebuilt driveshaft
- Polyurethane shifter bushings
- Odyssey lightweight battery
For a detailed write-up of the entire build, you can find a documented thread at the following link...
The asking price will start at $15,000 FIRM.
"I am fast...to give you a reference point, I'm somewhere between a snake and a mongoose...and a panther." - Dwight K. Schrute
Edited by kcpaz (03/13/11 02:58 PM)
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.67.87) | Report this post to a Moderator
1990/2000
Galant VR-4 org Post #: 976497 posted 03/13/11 02:52 PM     Remind Me!  Send Private Message   Edit Post
As always, nice looking build, Kent!
Can you toss the price in your title?
Thanks!
the bitterness of low quality remains long after the temporary joy of a low price has faded
Posts: 3541 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (208.54.38.67) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 976498 posted 03/13/11 02:58 PM     Remind Me!  Send Private Message   Edit Post
Thanks... sorry about the lack of price in the title... I feel like a newb now
Sr71sss
Member ++
Galant VR-4 org Post #: 976510 posted 03/13/11 05:10 PM     Remind Me!  Send Private Message   Edit Post
excellent car, The other white meat as they say I was close to building one before getting my first vr4 way back in 98!
GLWS-I love subie or anything that the F N F movies havent basterdized yet
Wanna trade for a Pulsar GTI-R-thought I would throw it out there
supersonic bluebird
Posts: 711 | From: by the river next to the delta | Member Since: 03/24/06 | IP: (99.7.140.118) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 976512 posted 03/13/11 05:34 PM     Remind Me!  Send Private Message   Edit Post
^^^ how do you have access to a GTI-R? you in Canada?
VR4ownzU
IcanHazFugly
Galant VR-4 org Post #: 976521 posted 03/13/11 06:58 PM     Remind Me!  Send Private Message   Edit Post
Beautiful car! Awesome rebuild.
WTB: CLEAN Galant VR4
05 Saab 9-2x Aero - Garage Queen
04 Subaru Forester XT - Wife's DD
00 Subaru Forester L - My DD
Posts: 3101 | From: Orlando, FL | Member Since: 11/10/03 | IP: (24.101.214.69) | Report this post to a Moderator
socalgvr4
Member +
Galant VR-4 org Post #: 976608 posted 03/14/11 01:27 AM     Remind Me!  Send Private Message   Edit Post
Kent -- Yet again, a very different and clean build.
I've had the pleasure of meeting Kent in Az for some Galant VR4 parts and I can say he is great guy to deal with. Also knows his stuff better than most.
Good luck with the sale Kent.
Posts: 294 | From: Hillsboro Oregon, USA | Member Since: 09/19/07 | IP: (12.232.239.98) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 976612 posted 03/14/11 01:51 AM     Remind Me!  Send Private Message   Edit Post
Awh thanks
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.106.226) | Report this post to a Moderator
Olson
Pwnd by Rance.
338/2000
Galant VR-4 org Post #: 976666 posted 03/14/11 01:14 PM     Remind Me!  Send Private Message   Edit Post
Quoting kcpaz:
Sr71 is in the bay area CA
338/2000
05 TDI Wagon
88 Raider
"Oh, and if you want to build your status and rank, go play some WoW. Come back when you're ready to talk cars". Qship
Posts: 1237 | From: Moreno Valley CA | Member Since: 10/08/06 | IP: (132.3.9.68) | Report this post to a Moderator
Sr71sss
Member ++
Galant VR-4 org Post #: 976692 posted 03/14/11 03:05 PM     Remind Me!  Send Private Message   Edit Post
Quoting kcpaz:
No this is in a secret location, known to small number of people here in norcal as the BAT cave haha
supersonic bluebird
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 976702 posted 03/14/11 03:31 PM     Remind Me!  Send Private Message   Edit Post
I've always wanted one of those GTI's... but I MUST resist the urge... Is it LHD?
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.18.54) | Report this post to a Moderator
Olson
Pwnd by Rance.
338/2000
Galant VR-4 org Post #: 976853 posted 03/15/11 04:33 AM     Remind Me!  Send Private Message   Edit Post
You want it. trust me its a sexy sexy car. seen it SR had to beat me back with a stick
338/2000
05 TDI Wagon
88 Raider
Posts: 1237 | From: Moreno Valley CA | Member Since: 10/08/06 | IP: (180.131.229.0) | Report this post to a Moderator
MrP
Galant VR-4 org Post #: 976964 posted 03/15/11 04:05 PM     Remind Me!  Send Private Message   Edit Post
it isnt LHD
Edited by MrP (03/15/11 04:05 PM)
| | | IP: (69.110.27.228) | Report this post to a Moderator
Sr71sss
Member ++
Galant VR-4 org Post #: 976978 posted 03/15/11 05:05 PM     Remind Me!  Send Private Message   Edit Post
Quoting kcpaz:
haha I have been trying to resist the cars of my youth for more than 20 years now and damn its always hard to resist, its original RHD jdm YO!
sorry couldnt resist the jdm lingo- Im older than I write, kinda fun but this is adult owned and driven albeit very short distance
JAKE: I'll ship this to you if you want it, I'll trade you your broke [email protected]# mitsu
LHD pulsar are uber rare as I have heard that there were only literally a few 100's imported to the UK and then they were canned in 1994, so getting a LHD pulsar is ultra(man) rare although it can be converted albeit with a similar chassis nissan like the 91-94 nissan sentra se-r, I thought about doing that so the cops wouldnt give me more looks at the car
BTW: GREAT real world build without compromises, I just love it weather its a subaru or mitsu or for that matter hyundai genesis coupe!
supersonic bluebird
Edited by Sr71sss (03/15/11 05:12 PM)
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 976982 posted 03/15/11 05:19 PM     Remind Me!  Send Private Message   Edit Post
Quoting kcpaz:
Porsharu on CCWs...Porsharu on CCWs...
Just keep chanting that.
Michael
The rebuild of 1101
Posts: 4085 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (167.80.246.204) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 976995 posted 03/15/11 06:07 PM     Remind Me!  Send Private Message   Edit Post
^^^ ahhh... the voice of reason...
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.72.18) | Report this post to a Moderator
Sr71sss
Member ++
Galant VR-4 org Post #: 977038 posted 03/15/11 09:23 PM     Remind Me!  Send Private Message   Edit Post
yum yum CCW, yes please I need them on my 71 datsun 240Z imsa FUN toy but I need them in a 17x10 and a 17x14 size with 335 40 17 rear tires to boot
CCW classics make anything look good
supersonic bluebird
jcgalntvr4-244 Galant VR4.org Moderator
WAY 2 many
244/2000
Galant VR-4 org Post #: 977097 posted 03/16/11 12:15 AM     Remind Me!  Send Private Message   Edit Post
1991 JDM Galant Vr4
1991 Galant Vr4 244/2000
1991 Galant Vr4 30/2000
1991 Galant Vr4 142/2000
Yeah Im an addict.......
Posts: 3135 | From: DesMoines Iowa | Member Since: 11/09/03 | IP: (71.214.224.171) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 977099 posted 03/16/11 12:19 AM     Remind Me!  Send Private Message   Edit Post
I just got the car tuned with the new engine. It's surprisingly quick considering how relatively stock it is.
And Yes, CCW Classics make everything more gooder... especially when they are super wide and wrapped in 335mm slicks... I can't wait.
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.60.160) | Report this post to a Moderator
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 977246 posted 03/16/11 02:18 PM     Remind Me!  Send Private Message   Edit Post
Quoting Sr71sss:
Just wait until you see what they're going on.
Michael
The rebuild of 1101
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 977538 posted 03/17/11 12:42 PM     Remind Me!  Send Private Message   Edit Post
MAN! Ive always had a soft spot for the LGT but this one is the best of ALL worlds. Only way I could swing it is if you take a #381/2k trade in! lol
Beautiful!
Sent from my iPhone
2007 Shelby GT
2002 RAM 1500 Quad Cab DD
1968 Camaro 427BB
2006 GSX-R 750 SOLD 3/19/12
1991 GVR4 #381 SOLD 3/27/12
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (68.15.48.195) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 978548 posted 03/21/11 03:01 PM     Remind Me!  Send Private Message   Edit Post
Quoting Sr71sss:
pictures? Just curious...
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.121.186) | Report this post to a Moderator
time
Galant VR-4 org Post #: 979669 posted 03/24/11 11:35 PM     Remind Me!  Send Private Message   Edit Post
Wow, this thing is amazing. I'm actually in the market for a Legacy GT, I just don't know if the bank will cough up $15k for a 98. What's the status of the title?
| | | IP: (99.59.155.97) | Report this post to a Moderator
kcpaz
Señor Fabricator
1121/2000
Galant VR-4 org Post #: 979671 posted 03/24/11 11:43 PM     Remind Me!  Send Private Message   Edit Post
The title is free, clear, and NOT salvage... but yeah, no bank is going to loan on a 13 year old car... especially at any sort of value.
BTW... if the Ebay listing doesn't end at $15K with a buyer, I will be dropping it down to $13K for another 10 days. If it doesn't sell then, I'll just keep if for a while and get some enjoyment out of it.
Posts: 1307 | From: Gilbert, AZ | Member Since: 01/28/06 | IP: (184.98.96.232) | Report this post to a Moderator
time
Galant VR-4 org Post #: 979677 posted 03/25/11 12:00 AM     Remind Me!  Send Private Message   Edit Post
If I come up with $13k in the next week, I'll give you a buzz, but is highly unlikely. Whoever gets that ride will certainly be a happy customer. Good luck with the sale.
Pages: 1 | 2
Generated in 0.063 seconds in which 0.027 seconds were spent on a total of 14 queries. Turbo powered.
