FS: #1185/2000, Nile Black, Sturgis, SD - $6,250
New in the past 5,000 miles
Rebuilt engine
Reconditioned 1g rods
New 2g pistons
New 3rd generation lash adjusters
Balance shafts eliminated
New front cover/oil pump
HKS 264 cams
All new OEM timing parts
ARP head studs
OEM 4-layer steel head gasket
Prothane polyurethane engine mount inserts, black
2g (plastic) dipstick
All new rubber underhood
NGK plug wires
NGK BPR7ES plugs
Tires, Winterforce M+S 185/65-15
Stage 3 Keydiver E85 chip
Carquest battery
Windshield
10,000
Lightweight chromoly flywheel
6-puck sprung Clutchnet clutch disc
OEM pressure plate
OEM inner tie rods
OEM outer tie rods
OEM Montero tie rod ends
OEM front ball joints
OEM front sway bar endlinks
OEM front wheel bearings
Megan 3" stainless steel downpipe
3" mild steel downpipe-back exhaust
Full size muffler
2g DSM cast aluminum intake pipe, Injen clone
2g DSM mass air
850cc Delphi injectors
'93 Galant clear headlights
OEM thermostat
OEM knock sensor
15,000
OEM clutch master cylinder
OEM clutch slave cylinder
OEM clutch fork and pivot ball
Stainless steel clutch line
Goodridge stainless steel brake lines
OEM rear brake calipers
Front and rear brake pads
Front axles
OEM harmonic balancer
OEM ISC motor
OEM fuel filter
25,000
Walbro 255lph high pressure fuel pump
AMS Galant VR-4 specific front mount intercooler and piping
2.25" piping from turbo to intercooler
2.5" piping from intercooler to throttle body
1g DSM blowoff valve flange
Spearco intercooler core
Evo3 16g turbo
Ported 2g DSM oxygen sensor housing
Ported 2g DSM exhaust manifold
Blitz dual solenoid electronic boost controller
Autometer auto-lite gauges
Boost/Vacuum
Air/Fuel
Water Temperature
Oil Temperature
Oil Pressure
Other mods
Socketed EPROM ECU
Battery mounted in trunk with aluminum battery box
1g DSM "short" shifter
Crushed blowoff valve
'90 DSM oil filter adapter
B&M bar and plate oil cooler
Cruise control eliminated
Air conditioning eliminated
Switched new engine to Mobil-1 10-30 synthetic at 3,500 miles
Also available
Yakima roof rack (Towers and clips)
Functional and complete extrude honed JDM cyclone intake manifold
Stock aircan with EVO mass air
DSM MAF Translator, extension harness, 3" GM mass air
16" 15-spoke alloy wheels (graphite colored)
Forced Performance ported Evo3 16g w/ ~5k miles
Palm m105 with datalogger cable
More photos here on Flickr
As can be seen in the photos the car could use a little paint and body love. Prior owner hit a deer and the core support is slightly mangled, I have a straight core support off of a white VR-4 that goes with the car if the new owner wants it. Apart from that the worst of it can be seen in the photos of the drivers side front fender.
I am willing to negotiate reasonable delivery as far as Sioux Falls, SD, Denver, CO, Billings, MT or a similar distance from 57793.
Selling because I have decided to focus on #880.
TurboTrader
Pemberton, NJ
Not even to mention, just look at the mods and OEM replacements. Bump for a very clean Galant VR4 with the mods/replacements and upgrades to support it!
steve
NJ
Please keep on topic. Negative comments are not accepted.
Still have this, started leaking boost into the cooling system shortly after I posted this ad. Car has been sitting since (started a few times briefly), just haven't had time to touch this one. Needs a fresh head gasket and water pump o-ring (have them, they will come with the car), but you can hear it run. -- Delivery still an option, will take $4k.
