Galant VR-4 Forums » Marketplace » Cars For Sale » FS: #490/1000, Lake Orion, MI, (off market)
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 1249872 posted 10/12/20 06:20 PM     Remind Me!  Send Private Message   Edit Post
I am the 3rd owner of #490/1000. Originally Boston car. I purchased in 1999 from 2nd owner.
Car has lived inside my garage entire ownership.
Major engine overhaul and build in 2000, with very few miles (less than 500) since then.
(I have a "feeler" add from 2010 on this board, <200 miles since then)
I completed the major build in past year and it is running well in cool fall air, and also after removing a catch can setup and returning to stock PCV operation.
Just took a vid of launch and 1-3 pull on gopro.
Car as is includes:
Original window sticker, key fob #490/1000, manual, manual holder
New in 2001 and <500 miles:
T3/T4 Turbo from force performance, 4 bolt exhaust housing, external 38mm Tial wastegate
ARP studs (main, head, & rod bolts)
Super AFC
MAF Translator
Keydiver Stage 3 chipped ECU in ECU refreshed and bought from Keydiver
JE Forged Pistons-- 9.0:1 @.020 over
HKS knock off Exhaust Manifold, 1st runner wastegate mount
EGT/02 Sensor and Gauge. Guage is Westtech, never hooked up
FMIC from Shannon K, one of his "kits" with Griffin core
HKS 272/272 Cams
Head G, Slv Cyl, Tbelt, knk sen, 3G lifters, thermo housing top all replaced during build
Block bored 0.020 over, head had just a valve job and milled
Harm Bal pulley, oil pump gears, gaskets new when rebuilt
SX AFPR and inline filter
ACT 2600 new at rebuild
660 Injectors new at rebuild
SPAL fan new at rebuild
AGX's, GVR4 H&R springs. (original springs in boxes will include)
Front and rear GAB strut tower bars
<3000 miles on Kumhos but from about 2000.
Greddy turbo timer with old school pac man chime.
Paint is not flaking. Very little body rust underneath, a few spots on hood and trunk. Dents in both rear quarter panels from when purchased before.
In past year, finished '90 oil housing with remote oil cooler.
Full gas tank refinish with POR 15 kit and new 255 Walbro. Note fuel gauge sender not working after the fuel pump swap.
Full 3" exhaust, Megan 2G to dynomax bullet where cat normally is to vibrant 3" to dual exit muffler, V-band connections.
All new (rebuilt) calipers front and rear.
SS brake lines
Optima Red Top battery, breaker at battery, sturdy mount plate glued (windshield adhesive) to trunk so no through trunk holes.
0 ga ground run up to engine compartment.
Passenger side front half shaft new due to leaking boot.
Now that everything is sorted, this is a good, solid foundation.
No fluid leaks, everything is dry underneath.
Open to any questions, etc.
*Note: A/C pulley not hooked up. A/C stopped working in 2001. In troubleshooting I accidentally drained the charge. However, likely cause was the wire on top of the thermostat housing breaking internally. It fell off this summer. I have the pulley and will include in the sale.
*ABS light on when getting it back on the road in the last year. I have not tried to troubleshoot or clean / check sensor position
Have more pics and can take pics of whatever anyone wants.
Not sure how to share the vid of the first to 3rd pull, 16 PSI.
THanks,
PJ G.
#490/1000
Edited by PJGross (10/27/20 10:19 AM)
Posts: 1558 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (2601:401:4380:74) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1249873 posted 10/12/20 07:22 PM     Remind Me!  Send Private Message   Edit Post
Here is the video link. I saved on instagram since photobucket doesn't allow hosting for free anymore.
ApexHunter
Extreme Indoor Cyclist
1951/2000
Galant VR-4 org Post #: 1249890 posted 10/15/20 01:46 PM     Remind Me!  Send Private Message   Edit Post
Looks like a good one. GLWS.
Posts: 1977 | From: Marysville, WA | Member Since: 04/25/07 | IP: (2601:601:9900:6d) | Report this post to a Moderator
boostme
Galant VR-4 org Post #: 1249929 posted 10/23/20 05:44 PM     Remind Me!  Send Private Message   Edit Post
The A/C plug you speak of on top controls the fan. A/C works without that. Mine is broken too and thought I needed it.
Posts: 73 | From: Crete, IL | Member Since: 10/04/13 | IP: (172.58.143.16) | Report this post to a Moderator
PJGross
490/1000
Galant VR-4 org Post #: 1249947 posted 10/27/20 10:17 AM     Remind Me!  Send Private Message   Edit Post
Thank you for clarifying the above. Before Shannon K's death, he sent me a spare AC ECU module to try out. I had not tried it since I just removed the pulley and belt, leaving all else intact. Car will come with this spare module.
Please note, I am pausing sale, ran into an issue when driving last weekend to put some daily miles on the car. I will read the listing to see if I need to pause/etc. If I can change the title I will put "no longer active" until it is ready.
-PJ
#490/1000
Posts: 1558 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (2600:1007:b00b:9) | Report this post to a Moderator
0 registered and 22 anonymous users are browsing this forum.
Generated in 0.057 seconds in which 0.03 seconds were spent on a total of 14 queries. Turbo powered.
