Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 1991 Galant Vr4
FS: 1991 Galant Vr4
91galantvr4_4WS
579/2000
Galant VR-4 org Post #: 1223773 posted 02/05/16 05:27 PM     Remind Me!  Send Private Message   Edit Post
I have a 1991 Galant Vr4 (579/2000) that is stock (Nile Black). I used all OE parts to replace defective parts. My goal was to make a dependable Vr4 for a daily driver. I have other projects that require my attention and I am trying to free up some space and work load. I have put a lot of work and time into this car to make sure everything is done correctly. The car pulls great for stock and the AWS works well. Below is some information on the car:
Cylinder Compression -- (factory-164 psi)
Cyl 1 -- 155 psi
Cyl 2 -- 155 psi
Cyl 3 -- 160 psi
Cyl 4 -- 155 psi
Cylinder Leak Down Test (results shown are indicating good sealing surfaces)
Cyl 1-- 87%
Cyl 2-- 89%
Cyl 3-- 86%
Cyl 4-- 85%
Recently replaced:
-All Rotors (Rybesto)
-All Pads (Rybesto)
-Brake master cylinder (Reman)
-All new brake fluid (DOT 3)
-Brake booster (OEM)
-Front strut mounts (KYB)
-Rear shocks (KYB)
-Shifter bushings (Mitsu)
-Alternator belt (Mitsu)
-Plugs (NGK (.029 Gap))
-Wires (NGK)
- o2 Sensor (Denso)
-Valve cover gasket (Felpro)
-Throttle body shaft seals (Mitsu)
-Injector seals (Mitsu)
-Rear half shafts (Mitsu)
-New Injector on cylinder number 2 (OE)
-Coil Pack (OE)
-Fuel Pump (OE)
-New Passenger Side Control Arm with ball joint (Precision)
-New Driver side Control Arm with ball joint (Prescesion)
-New Passenger side wheel bearing (dealer installed. Brand unknown)
There are some problems with the car still. They aren't huge problems but I'm not going to try and hide them from anyone.
- Pulls to the left.
-Front right ABS sensor was not working properly. It would kick the abs on when it wasn't necessary so for now, I just pulled the fuse so I can stop without the ABS kicking in. Because of this, whenever the car is over 15 mph and you are in neutral, the rpms will rise (approx 2300 rpm).
-There is a little damage in the back right panel and door. I bought it like this with intentions on fixing it. I am not a body guy so I was putting that off until last.
-The car has started everytime but once the entire time I owned it (besides a dead battery from sitting for a while). I unplugged the battery and plugged it back up after letting it sit and it fired back up. Ran just fine after starting it including driving home.
-The auto locks work fine. They were annoying me so I decided to pull the fuse. (10 amp)
The previous owner said the head was replaced on it before he got it, I cannot confirm this as I never saw any receipts. The car has 215K on it. The car has almost no rust on it and under it.
That is all that is wrong with the car mechanically and body wise that I know of currently. This is a 1991 vehicle...If you have any questions, please feel free to message me or call. I would like to get $3,000 for this car. If you don't like the price, feel free to shoot me an offer. I have a clean and clear title to the car in my name. Thank you for looking.
1991 Talon TSI AWD
1991 Galant VR4
2008 Pontiac Grand Prix
1997 Ford F250 HD
Posts: 29 | From: Salem, IL | Member Since: 01/03/15 | IP: (75.129.246.177) | Report this post to a Moderator
Beefslamdenver
Newbie
Galant VR-4 org Post #: 1223817 posted 02/06/16 09:33 AM     Remind Me!  Send Private Message   Edit Post
Very impressive car. May consider in the next few weeks. I'll pm you later and we can start talking about it.
Posts: 2 | From: Denver colorado | Member Since: 01/28/16 | IP: (172.56.9.222) | Report this post to a Moderator
91galantvr4_4WS
579/2000
Galant VR-4 org Post #: 1223835 posted 02/06/16 12:05 PM     Remind Me!  Send Private Message   Edit Post
Sounds good. If you have any questions in the meantime, please let me know I will try to respond to them as quickly as possible.
1991 Talon TSI AWD
1991 Galant VR4
1997 Ford F250 HD
576
Newbie
Galant VR-4 org Post #: 1223913 posted 02/07/16 02:38 PM     Remind Me!  Send Private Message   Edit Post
I sent u a message highly interested
Posts: 1 | From: Steger il | Member Since: 02/07/16 | IP: (73.22.254.226) | Report this post to a Moderator
576
Newbie
Galant VR-4 org Post #: 1223971 posted 02/08/16 04:37 PM     Remind Me!  Send Private Message   Edit Post
When can I come super interested let me know?
Posts: 1 | From: Steger il | Member Since: 02/07/16 | IP: (2601:244:4000:1a) | Report this post to a Moderator
91galantvr4_4WS
579/2000
Galant VR-4 org Post #: 1223974 posted 02/08/16 05:26 PM     Remind Me!  Send Private Message   Edit Post
I sent you a return message, please let me know on here if you do not receive it.
1991 Talon TSI AWD
1991 Galant VR4
1997 Ford F250 HD
576
Newbie
Galant VR-4 org Post #: 1223980 posted 02/08/16 06:18 PM     Remind Me!  Send Private Message   Edit Post
I got it I sent one back
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1224055 posted 02/10/16 04:15 PM     Remind Me!  Send Private Message   Edit Post
They sent each other pm's and returned each others pm's.
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2332 | From: USA | Member Since: 01/07/12 | IP: (132.3.37.82) | Report this post to a Moderator
Tudds
Newbie
Galant VR-4 org Post #: 1224060 posted 02/10/16 05:18 PM     Remind Me!  Send Private Message   Edit Post
Where are you located ?
Looking for a gvr4. Message me
2002 Camaro SS 1971 Super Beetle Vert
1988 Mustang Lx 1990 Eclipse GSX
2005 Grand Cherokee Hemi
Posts: 17 | From: Long Island | Member Since: 03/24/15 | IP: (107.77.70.80) | Report this post to a Moderator
91galantvr4_4WS
579/2000
Galant VR-4 org Post #: 1224080 posted 02/10/16 08:27 PM     Remind Me!  Send Private Message   Edit Post
The car has sold. Thank you for all your expressed interest.
1991 Talon TSI AWD
1991 Galant VR4
1997 Ford F250 HD
Generated in 0.081 seconds in which 0.037 seconds were spent on a total of 14 queries. Turbo powered.
