Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 91 Belize Green Galant VR4 (564/2000) Denver area, CO $2600 *SOLD*
jackal
Galant VR-4 org Post #: 1222191 posted 12/27/15 02:00 PM     Remind Me!  Send Private Message   Edit Post
I am selling my Belize Green 1991 Galant VR4. I would like $2600. I bought the car in 2008 and did a fair amount of work throughout the years to get it running reliably. I bought the car in mostly stock condition. The intake air filter, and battery were relocated by the previous owner. All the work I did was to get the car running reliably so I could enjoy it as a daily driver. Which I did for many years until the transmission started going. Some of the syncros seem to be in bad condition and there is noise coming from the transmission when the clutch is engaged. When this started, I parked the car and was hoping to get around to fixing the transmission but I ran out of time and now I won't have a garage to work on it anymore. So unfortunately I'm going to have to sell it.
Also, I got in a minor accident some time ago that caused some front end damage. I slid on some black ice and hit a work van at low speed. Unfortunately, the van's bumper was just a bit higher than mine so it damaged the headlights, hood, and the radiator. I repaired most of it but the fenders and bumper still show some damage. I drove the car for 3 or 4 years after the accident.
Photos:
FS: Galant Vr4 Photos
Mileage: 234089 miles
The Bad:
- Needs Transmission Rebuild
- Needs Suspension Work. One of the Rear Springs appears to be sagging.
- Has Some front end damage from an accident.
- Bumper Cover is cracked and warped.
- Stock Radio is Removed but I have it and is included.
- Sunroof works but I had to reroute the power to bypass the control module.
- Will Need Timing Belt Soon
- Will Need Carrier Bearings Soon(Current bearings are starting to have play)
The Good:
- Windshield was replaced recently
- Throttle Body - Shafts Seals Replaced
- Throttle Body - Idle Air Control Valve Replaced
- Throttle Body - Fast Idle Air Valve Blockoff Plate Installed
- ECU - Capacitors Replaced
- ECU - Added ZIF Socket for EPROM
- ECU - Has Stock EPROM installed
- Brakes - Rear and Front Calipers Replaced
- Brakes - Stainless Steel Braided Brake Lines Installed
- Brakes - Master Cylinder Replaced
- Brakes - Both Rear Parking Brake Cables Replaced
- Fuel - Stock Fuel Injectors and Seals Replaced
- Fuel - Stock Fuel Pressure Regulator Replaced
- Fuel - Stock Fuel Filter Replaced
- Fuel - Fuel Hose from Filter to Fuel Rail Replaced (Has AN fittings)
- Fuel - Stock Fuel Pump Replaced
- Engine - Rings seem to be in good shape. Have not noticed any oil burn and compression seems good.
- Engine - Head Rebuilt
- Engine - Exhaust Manifold Bolts Replaced
- Engine - Front Engine Mount Replaced
- Engine - Valve Lash Adjusters replaced with larger diameter oil port
- Engine - Oil Pan and Pan Gasket Replaced
- Engine - Cam Angle Sensor Replaced
- Intake - OEM 1G DSM Blow Off Valve and Gasket Installed
- Exhaust - Catalytic Converter Replaced. Passes Emissions Test.
- Exhaust - EVO III O2 Housing Installed
- Exhaust - SS Exhaust Manifold Studs
- Clutch Master Cylinder Replaced
- Driveline - Right Front CV Axle Replaced
- Cooling - Replaced Most Coolant Hoses
- Power Steering - Replaced all seals
Edited by jackal (01/08/16 09:33 AM)
Posts: 34 | From: CO | Member Since: 10/05/08 | IP: (71.218.48.81) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1222192 posted 12/27/15 02:36 PM     Remind Me!  Send Private Message   Edit Post
Does the car run currently?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3436 | From: SoCal | Member Since: 01/02/12 | IP:
(24.145.93.250) | Report this post to a Moderator
jackal
Galant VR-4 org Post #: 1222194 posted 12/27/15 04:00 PM     Remind Me!  Send Private Message   Edit Post
Yes, it starts and runs. I started it and ran it for a while a few weeks ago.
Posts: 34 | From: CO | Member Since: 10/05/08 | IP: (172.56.9.176) | Report this post to a Moderator
mistaVR4
Rest in Peace
484/1000
Galant VR-4 org Post #: 1222653 posted 01/06/16 07:34 PM     Remind Me!  Send Private Message   Edit Post
This is a great car! When I owned her she was excellent. The seller is my friend who bought it from me and he took excellent care of the car!
SteveW
484/1000 Kensington Grey - Running VERY well :-)
564/2000 Belize Green ~ SOLD
749/2000 Summit White ~ SOLD
1989 Chrysler Conquest TSi SHP ~ SOLD
2004 Saab 9-5 ARC ~ Daily Driver
Posts: 4768 | From: Boulder, CO | Member Since: 12/16/03 | IP: (2601:281:8001:26) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1222696 posted 01/08/16 06:11 AM     Remind Me!  Send Private Message   Edit Post
Do you know how to contact him I'm interested.
138/2000
152/1000
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (50.37.22.248) | Report this post to a Moderator
Generated in 0.055 seconds in which 0.026 seconds were spent on a total of 14 queries. Turbo powered.
