Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 313/1000 Minnesota $2000
xaisomboun
313/1000
Galant VR-4 org Post #: 1187933 posted 09/07/14 02:50 PM     Remind Me!  Send Private Message   Edit Post
Up for sale is a 1992 Galant VR-4 (313/1000).
2xx,xxx miles on the chassis and unknown on the motor as it was replaced by previous owners.
The car is in running condition right now although a little rough around the edges. (Please read cons if concerned.)
The following is copy/pasted from previous sale threads for this car to save time.
Engine:
(Engine was rebuilt due to melted piston)
-Bored .020
-Forged 8.3:1 wiseco pistons
-Head and block decked for Cometic MLS head gasket
-Reconditioned stock rods
-ARP head studs
-Head lightly ported
-Head reconditioned(new guides,springs, valve job, etc.)
-New front case(oil pump)
-Balance shafts removed
-All new timing components and water pump
-All bearings and gaskets etc.
-Rebuilt 14b turbo
-3inch turbo back exhaust. (Old magnaflow muffler rusted a hole in it so I just replaced it with a 3 inch pipe.)
Now onto things I've replaced.
-New-ish Exedy Stg 1 clutch replaced by me about 5k miles ago.(Replaced clutch fork, pivot ball, resurfaced flywheel for
the new clutch, and a new OEM throw out bearing.)
-STM Performance -6an fuel feed line kit with re-wired walbro 255 fuel pump.(Replaced old fuel feed because the hardline
for the fuel sending unit snapped off.)
-New radiator fan. (Stock one did not turn on when I acquired the car.)
-New 90amp alternator from Beck/Arnley.
-Not so new but better than before power-steering pump. (Previous one had a wobbly wheel.)
-Philips x-treme power headlights. (Old ones burnt out.)
-DIY Rear bumper support. (Old bumper support got rusted so bad to the point where it was about to literally fall off
the car. Guide was followed on this thread. -> link)
-BRAND new tires 2k ish miles ago.
-I HAD a newer socketed ECU with a mild chip tune to throw in but one of the pins have corroded away. Now running stock
ECU. (Socketed ECU will come with car.)
-New Akebono brake pads on the front.
-Ni-copp rear brake lines. (Old brake line was leaking pretty bad.)
-Techna-fit braided brake lines from B2Autodesigns (Bobdole) on the .org forums. (Have only done 2 corners so
far, haven't had time to do the other 2)
-Clutch master cylinder replaced around the same time as the new clutch.
-Brand new short shifter from JNZ tuning.(It's the longer one suited for a GVR4.)
-New passenger side control arm with new ball joint and swaybar link.
CONS:
-Ever since I've owned it, it does NOT like sitting in 80-90 degree humid weather in stop and go traffic for long periods of
time.
-Minnesota rust on the under-carriage.
-Leaks power steering BAD. One of the previous owners thought it was a good idea to JB-weld a high-pressure hardline on
the rack and has decided to fail pretty recently. I have removed the power-steering belt to prevent damage to the pump.
-Idle-air controller on the ECU is acting funny so it will have a low idle/idle surge when warming up. (Idle calms down
after completely warmed up.)
-Leaks a drop of oil every day or so. Not sure where its coming from.
-Passenger side e-brake cable has snapped. (I have a brand new replacement still in box.)
-Will need new front rotors soon. (I might replace them before the car sells if I have enough time.)
-Sub-zero degrees in the Minnesota winter will make the lifters tick for a while. (I have a new set of ITM 3g revised
lifters in a container of oil, bled and ready to be installed.)
-Turbo spools pretty slow, I'm assuming its either the wastegate actuator or a leak on
the wastegate flapper.
Reason for selling:
-I work full time and I'm planning to go back to school soon. I really have no more time to work on this car with all of
it's flaws that I've discovered from owning it.
Asking for $2000. (Please no low-balling, I am in NO rush to sell this car.)
PS. It will come with a box of extra replacement parts I have accumulated for the car. (Spare radiator, coil-packs, power transistors, headlight housings, valve cover.)
Pics:
(Will update with more pics later.)
Edited by xaisomboun (11/21/14 02:35 PM)
Posts: 117 | From: Minnesota | Member Since: 06/19/11 | IP: (71.63.226.251) | Report this post to a Moderator
Lancer99
$6500 obo
902/1000
Galant VR-4 org Post #: 1187947 posted 09/07/14 04:18 PM     Remind Me!  Send Private Message   Edit Post
I love the cop in the back round. GLWS
When the clutch drops...
The bullsh*t stops!
902/1000
Still working on it after 5 years
97 Volvo 850 Estate
Posts: 1284 | From: Somewhere over the rainbow | Member Since: 08/23/04 | IP: (69.47.180.30) | Report this post to a Moderator
ExplicitCC
901/2000
Galant VR-4 org Post #: 1187956 posted 09/07/14 06:55 PM     Remind Me!  Send Private Message   Edit Post
Do you think it will make it back to cali?
"You want to be happy once in your life? Seek revenge...... You want to be happy the rest of your life? FORGIVE!!!" S.H.M.J.M.E
Posts: 49 | From: Lake elsinore, CA | Member Since: 02/24/14 | IP: (108.23.31.50) | Report this post to a Moderator
xaisomboun
313/1000
Galant VR-4 org Post #: 1187958 posted 09/07/14 07:57 PM     Remind Me!  Send Private Message   Edit Post
Not sure, the longest I've driven it was for about 2 hours straight with no issues.
OMFGeofffff
All I want is a dodgy
567/1000
Galant VR-4 org Post #: 1188238 posted 09/09/14 11:55 PM     Remind Me!  Send Private Message   Edit Post
Soooo tempting.
-Jeff
Kensington Grey - A87 stock (EQ/input, no sunroof)
XBL - uh oh its JEFF
Posts: 867 | From: Burnsville, MN | Member Since: 05/05/06 | IP: (66.41.122.157) | Report this post to a Moderator
bluzvr4
Galant VR-4 org Post #: 1192043 posted 10/21/14 08:37 AM     Remind Me!  Send Private Message   Edit Post
If u were willing to make the trip I would trade u this
73 Opel gt (race car)
51/2000 (being built now)
94 vr4 (the pretty one)
Posts: 57 | From: san jose IL | Member Since: 02/21/11 | IP: (174.238.224.64) | Report this post to a Moderator
xaisomboun
313/1000
Galant VR-4 org Post #: 1194067 posted 11/16/14 11:31 AM     Remind Me!  Send Private Message   Edit Post
sold!
Posts: 117 | From: Minnesota | Member Since: 06/19/11 | IP: (66.102.6.31) | Report this post to a Moderator
Tonyc1970
Newbie
Galant VR-4 org Post #: 1200403 posted 02/01/15 06:02 PM     Remind Me!  Send Private Message   Edit Post
Do u still have
Posts: 1 | From: Elk river mn | Member Since: 10/21/11 | IP: (68.112.146.94) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1200475 posted 02/02/15 02:36 PM     Remind Me!  Send Private Message   Edit Post
^Comments like this should put the ban hammer in motion.... Need to trim the fat around here!
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock
Posts: 2767 | From: Savannah, GA | Member Since: 08/30/05 | IP: (2602:304:af36:ca) | Report this post to a Moderator
Tonyc1970
Newbie
Galant VR-4 org Post #: 1239679 posted 09/23/17 11:24 PM     Remind Me!  Send Private Message   Edit Post
Talk about trimming the fat maybe we should trim the fat on people that don't know how to put sold on the front page so people don't read the whole thing to find out it is sold
Posts: 1 | From: Elk river mn | Member Since: 10/21/11 | IP: (107.77.87.130) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1239684 posted 09/24/17 07:47 PM     Remind Me!  Send Private Message   Edit Post
Back from the dead!
Reading is hard. Don't hurt yourself...
1135- 100% stock
Posts: 2767 | From: Savannah, GA | Member Since: 08/30/05 | IP: (69.245.80.109) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1239693 posted 09/25/17 09:42 AM     Remind Me!  Send Private Message   Edit Post
dude reading is super fudge... i mean hard, yo...
138/2000
152/1000
Posts: 3645 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
sleeper1ga
313/1000
Galant VR-4 org Post #: 1239780 posted 10/01/17 12:29 PM     Remind Me!  Send Private Message   Edit Post
I mean for the right price it's for sale
Actually was looking at listing it for trades soon, love the car but ready for an a-body mopar...
It's changed a fair bit, but 313 is still alive and driving daily
Daily: 313/1000 20g, dsmlink V3(soon to be SD)
Grudge/Street Car: 90 DSM HX40, Auto, Spray
Build thread links in my bio
Posts: 33 | From: Illinois | Member Since: 04/08/16 | IP: (131.230.42.8) | Report this post to a Moderator
Generated in 0.134 seconds in which 0.075 seconds were spent on a total of 14 queries. Turbo powered.
