Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 91 galant vr4 $7000 1439/2000
Tim
Newbie
Galant VR-4 org Post #: 1176217 posted 06/11/14 08:09 PM     Remind Me!  Send Private Message   Edit Post
1991 Mitsubishi Galant VR-4 vr4
Engine machine work done here by Goza machine, head decked, block decked, hot tanked,
bored .020 over, supertech 9.5:1 pistons, cometic head gasket, acl race bearings on all rotating assembly
1g rods, balance shaft removal kit, (oil port blocked accordingly) Rotating assembly fully balanced by Goza also matched & ground all piston rings for each cylinder + mated pistons to corrosponding cylinders for balance. All oil squirters still in place
head rebuilt by goza machine as well, valve job, new guides, etc
Ecm rebuilt with new capacitors etc + socketed by keydiver when he was still around
ECM Link v3
Precision 6262 dual ball bearing
AEM FPR
custom fabbed oil catch can
custom remote oil filter setup now uses sb GM filters larger + holds more oil
Afco Scirocco radiator + aftermarket fan
Tial Q BOV
JMF Sheet Metal Intake Manifold
Tial 38mm waste gate
Megan racing SS turbo manifold with custom waste gate flange
megan racing 2.5" SS tubular 02 housing
Extreme Motorsports 3" exhaust
4gperformance 3" custom intake piping
3" GM Maf + ECM link GM maf cable
JMF COP setup
Hallman manual boost controller
Jay racing alternator relocation kit w/ new alternator
Web cams(272 intake/276 exhaust)
Bosch 044 fuel pump in tank
Delphi 850cc injectors
4gperformance FMIC setup with ETS core
90 DSM external oil cooler
Drivetrain + Suspension:
Shepard Stage 1 Tranny with Evo steel shift forks
Spec stage 2 clutch with <100 miles on it
Bulfab tubular 3 pc subframe
KSport 32 way adjustable coilovers
Whiteline front and rear swaybars
Powerstop slotted rotors x 4(200 mi)
Hawk Brake Pads x 4 (200 mi)
ABS delete using OEM proper non-abs fluid dist. block + OEM non abs lines
Stainless steel brake lines
4WS removed (common on GVR4's, systems get old & leaky, near impossible to fix)
Power steering removed with a proper ratio OEM Mitsu manual rack in its place, not a power rack
with the hoses cut off.
Advan Racing 2 piece SA3A 17x7 front and 17x8 rear
215/40/17 Kuhmo Ecsta front and rear, tires still good for while wheels are super light, rare,
jdm pieces with no rash or bends, centers could use a little refinishing
Exterior:
JDM front and rear bumpers
JDM projector fogs with custom made carbon trim pieces
HiRev Carbon fiber JDM style hood
Aerocatch Flush Mount Hood Pins
HiRev Carbon trunk with Moroso battery kill and MMC emblem
1993 Headlights
1992 Grille
92 Tailights
Interior / other:
2003 Evolution VIII front and rear seats on custom brackets and Netami harnesses
1989 under panel
2G shift knob with 1G leather boot/lever
Aeroworks Galant Specific Dual Pillar Pod
AEM Tru-Boost Boost controller/Gauge Combo (not in use, being used for boost gauge)
Aem Uego Wideband
Sunroof won't open for some reason
AC removed but heat works awesome
Kenwood Double Din CD player works good
all lights, jdm fogs, brights, turns, etc work well
Posts: 4 | From: Maryland | Member Since: 04/17/14 | IP: (108.50.37.91) | Report this post to a Moderator
Tim
Newbie
Galant VR-4 org Post #: 1176483 posted 06/15/14 06:50 AM     Remind Me!  Send Private Message   Edit Post
I will trade for a newer 1000cc bike but I prefer a zx14. Thanks
Jesus_Negros
Unempowered ADMIN
Galant VR-4 org Post #: 1176496 posted 06/15/14 10:00 AM     Remind Me!  Send Private Message   Edit Post
I remember this car. GLWS
Quoting coyotes:
Just because you WANT your rare turd to be valuable doesn't mean it's gonna be.
Posts: 2338 | From: USA | Member Since: 01/07/12 | IP: (71.177.218.188) | Report this post to a Moderator
jnava Galant VR4.org Moderator
Galant VR-4 org Post #: 1176529 posted 06/15/14 06:03 PM     Remind Me!  Send Private Message   Edit Post
Le crankwalks
57/2000
1865/2000
1058*/2000-SOLD
1989 Conquest Tsi
2000 2.5Gen Montero
2013 Outlander Sport
Posts: 2065 | From: Arlington, Tx | Member Since: 04/18/08 | IP: (70.122.204.153) | Report this post to a Moderator
Tim
Newbie
Galant VR-4 org Post #: 1178480 posted 07/01/14 08:44 PM     Remind Me!  Send Private Message   Edit Post
If I can't sell the car will part out. Will sell car for $6000 OBO
JackstandTSi
Galant VR-4 org Post #: 1178481 posted 07/01/14 08:49 PM     Remind Me!  Send Private Message   Edit Post
This may or may not be my phones lockscreen wallpaper I found on good a few months back GLWS.
Posts: 117 | From: Columbus Ohio | Member Since: 07/04/12 | IP: (172.14.76.217) | Report this post to a Moderator
15psi88
Galant VR-4 org Post #: 1178615 posted 07/02/14 06:38 AM     Remind Me!  Send Private Message   Edit Post
Dibs on trunk lid
Posts: 101 | From: State College, PA | Member Since: 08/19/09 | IP: (50.164.17.90) | Report this post to a Moderator
Jon Galant VR4.org Administrator
Administrator
Galant VR-4 org Post #: 1178628 posted 07/02/14 08:13 AM     Remind Me!  Send Private Message   Edit Post
Ebony and ivory....
Man, I want an oreo.
Posts: 1436 | From: Franklin, TN, USA | Member Since: 02/21/01 | IP: (68.63.243.24) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1178702 posted 07/02/14 01:30 PM     Remind Me!  Send Private Message   Edit Post
Always loved this car too, so different and unique.
2001 R34 Nissan Skyline “Eleanor”
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3717 | From: Houston, Texas | Member Since: 04/07/11 | IP: (172.56.21.191) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1178896 posted 07/03/14 03:14 PM     Remind Me!  Send Private Message   Edit Post
I love my crazy mother!!!
Posts: 1678 | From: Manchester, NH | Member Since: 07/17/06 | IP: (74.94.142.161) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1178927 posted 07/03/14 04:55 PM     Remind Me!  Send Private Message   Edit Post
Pics of the underside and interior?
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock (sold)
Posts: 2767 | From: Savannah, GA | Member Since: 08/30/05 | IP: (2602:304:ab3a:8f) | Report this post to a Moderator
Tim
Newbie
Galant VR-4 org Post #: 1179127 posted 07/05/14 07:54 PM     Remind Me!  Send Private Message   Edit Post
tinkolby_25
1439/2000
Galant VR-4 org Post #: 1179291 posted 07/06/14 10:29 PM     Remind Me!  Send Private Message   Edit Post
I pm'd with no response. I actually used to own this car. I am semi-interested in it.
Posts: 33 | From: Gadsden, Al | Member Since: 08/17/10 | IP: (184.61.255.153) | Report this post to a Moderator
Tim
Newbie
Galant VR-4 org Post #: 1181745 posted 07/26/14 06:40 PM     Remind Me!  Send Private Message   Edit Post
Car is sold
Posts: 4 | From: Maryland | Member Since: 04/17/14 | IP: (108.22.247.40) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1181941 posted 07/28/14 08:38 AM     Remind Me!  Send Private Message   Edit Post
May I ask what you got for it?
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1657 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (199.96.227.1) | Report this post to a Moderator
Rating: *
Generated in 0.042 seconds in which 0.023 seconds were spent on a total of 14 queries. Turbo powered.
