Galant VR-4 Forums » Marketplace » Cars For Sale » SOLD:1991 VR4, $GG's Spent!7k on build,30rDBB,Teins,EVO8 ecu, $7900 CT
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1042925 posted 12/31/11 03:25 PM     Remind Me!  Send Private Message   Edit Post
I'm located in RI and the car is in CT. It's my toy car. She makes the 300mile roundtrip RI/CT/RI all the time. I have a poop load invested in this car and now that I'm back to a career, its time to step up my game. I have owned this car for 4yrs and done tons of work documented in my build thread.
I have a folder FILLED with receipts(90% of items) totalling $12000. This does not include the car, the time and things like tuning.
I AM IN NO RUSH TO SELL THIS!!! I get CONSTANT local offers but when its time to exchange money, no one can make good on their deal! I'm asking $8500 PRICE DROP TO $7900 which is a steal for what you are getting. I am 100% confident this car can be driven ANYWHERE in the conutry without a hiccup! I also will entertain offers with some parts removed to reduce cost....
She does have some small body items that if the car is kept, will be addressed in the spring.
-2 small rust spots around windshield quarter and dime size
-Rear quarter infront of the p/s taillight has a smal scrap/dent
Owner: Russell Richards
Bought:11/07
Year:1991
Number:381/2000
Current Mileage:100,400 and counting..... as of rt now.
Mileage on build:7,220
1/4 time: TBD
WHP: 430awhp
BUILD THREAD click
Engine: click
Built bottom end click
-Wiesco 9.0:1 .20 over pistons
-Eagle rods
-Polished unground crank
-B/S eliminated
-Balanced to 10K
-Fluidamper balancer
Built Head
-Mildly ported head by myself ext click int click
-Manley springs/retainers/keepers
-Ferrea valves with 3-angle
-BC272's
-3g lifters
-Mitsu MLS headgasket
-Hondata intake gasket($.99 on epay)
-ARP Mains, headstuds, crank bolt, exhaust studs, rod bolts, turbo bolts
-New Mitsu oil pump/cover, mitsu waterpump, new mitsu tensioner, idle pulleys, new waterpump/oil pump cover/tensionor hardware click
-90' OFH, -8an lines, B&M 11x6 cooler
-New oilpan, knock sensor, ALL GASKETS/SEALS
-Drilled and filled motor mounts
-NGK spark plugs
-NGK spark plug wires
-New oem 1g dipstick with modified tube with spring click
Turbo:
-Garrett GT3076R in EVOIII exhaust housing click
-35mm internal wastgate
-Stainless braided oil feed from head
-Stock oil return
-Custom -6AN ss water feed line and return
Intake:
-Rebuilt VR4 throttle body
-2g t/b elbow
-2g MAF
-4" FP recirc intake pipe
-K&N filter
-Custom short route Aluminum 2.5" intercooler piping.
-Spearco intercooler with custom endtanks (core size - 24 x 9 x 4)
-Oil catchcan
-Crushed oem NIB BOV
Exhaust:
-2g ported exhaust manifold
-2g manifold heat shield and modified o2 shield
-ARP Stainless exhaust manifold studs
-2.5" to 3" mild steel downpipe
-3" mild steel bent catback with Borla single tip muffler click
-Catco 3" high flow cat
-EvoIII ported o2 housing
-RRE/Indy Race Cores Aluminum Radiator GVR4 specific
Electronics:
-Evo8 ecu
-Black Top CAS
-Greddy electronic Boost, EGT and memory/warning oil pressure
-NIB Greddy Profec B spec (original from 95)
-Dual stage turbo timer
-NEW Bosch 90amp alternator(original receipt with lifetime warranty)
Fuel system:
-Rewired Supra TT fuel pump
-Aeromotive AFPR
-SS -6an lines from filter to rail, from rail to afpr and from fpr to return.
-750cc FIC injectors
Drivetrain:
-Rebuilt TRE trans dual syncs in 2-3, filter, new forks, bearings, seals, rails
-Redline MT-90
-New front axles
-2g shift fork and throwout bearing upgrade
-ACT 2600
-ACT Flywheel
-Stainless braided clutch line
-DSM 5-lug conversion with all new bearing, seals and dust shields
-4bolt LSD rear end w/ AWS click
-Restored rear subframe. Complete sandblast and Eastwood products click
-Restored lines, rear rack, rear pump, dist block
-Rebuilt driveshaft with FM u-joints and new carrier
Suspension:
-Tein HR coilovers with front camber/pillow and rear pillow mounts
-Ingalls adjustable rear upper control arms
-DSM front and rear adjustable strut tower bars
-New rear sway bar end
Brakes:
-Front- 94+ 3kgt 4 pot calipers with 12.65" dual vented rotors, stock pads
-TunerNation(GW) caliper brackets
-Rear - Stock calipers on DSM 5 lug rotor
-Complete ABS removed and swapped for 1g non abs lines and proportioning valve
-SS brake lines
Wheels/tires:
- 17" EVO 9 Enkei Wheels
- 235/40/17 Azenis
Interior:
-EVO MR SE gas, clutch and brake pedals with WRX dead pedal
-1989 Light weight underdash with pocket
-Starion OPEN headrests in black leather click
-Sony Explod Black out CD player
-Double DIN carbon fiber plate for radio, Greddy oil pressure, boost and egt gauges
-"MITSU" 1g leather steering wheel
-2g DSM shift knob
-Leather shift boot
-1g DSM EXTREME PSI short shifter
-Paint removed from cluster needles, repainted red on tach and temp gauge click
-Moroso NHRA legal sealed battery box click
-Custom TURBOFLANAGAN numbered floor mats click
Exterior:
-JDM vented RS hood
-Eterna grill
-MMC VR4 trunk badges(removed Galant, DOHC and MITSUBISHI emblems) click
-OEM Mudflaps click
-JDM Eterna Grill
-93 crystal headlights
-Amber corners with signal and parking light
-Tinted tail lights
-Complete Rubberized undercoating to entire underside including under skitrs, doglegs and wheel wells click click
Again, I'm in no rush but would like to payoff a CC before I dive back into the car payment world!
Thanks, Russ
Sent from my iPhone
2007 Shelby GT
2002 RAM 1500 Quad Cab DD
1968 Camaro 427BB
2006 GSX-R 750 SOLD 3/19/12
1991 GVR4 #381 SOLD 3/27/12
Edited by 381gvr4 (08/23/13 12:08 PM)
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (68.15.48.195) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1042927 posted 12/31/11 03:57 PM     Remind Me!  Send Private Message   Edit Post
wow gorgeous car and awesome price. i wish i had an extra 8g's lying around so i could buy this....
138/2000
152/1000
Posts: 3654 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.2.98) | Report this post to a Moderator
akdriverjd
Galant VR-4 org Post #: 1043023 posted 01/01/12 05:20 AM     Remind Me!  Send Private Message   Edit Post
This looks like an awesome car; such a shame it's on the other side of the country. Free bump.
| | | IP: (24.237.4.1) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1043079 posted 01/01/12 04:28 PM     Remind Me!  Send Private Message   Edit Post
sale pending....
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (198.228.193.170) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1043918 posted 01/05/12 06:43 PM     Remind Me!  Send Private Message   Edit Post
Back up due to deadbeat without funds! BUMP
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (198.228.193.231) | Report this post to a Moderator
turbojew
Small Tattoo of 97 Chrysler Concorde on Left Buttock
Galant VR-4 org Post #: 1044011 posted 01/05/12 11:46 PM     Remind Me!  Send Private Message   Edit Post
Would love to trade my 89 starion for it lol
97 Chrysler Concorde 20k original
89 Mitsubishi Starion Sold
I vant b0000000000000000st.
Posts: 126 | From: Dallas, Tx | Member Since: 01/02/12 | IP: (24.38.212.196) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1044092 posted 01/06/12 11:36 AM     Remind Me!  Send Private Message   Edit Post
No thank you. Looking to trade cash for 381....
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
codeofdastreets
Galant VR-4 org Post #: 1044211 posted 01/06/12 10:17 PM     Remind Me!  Send Private Message   Edit Post
car has ac?
1991 Talon TSI-Project 9's
1990 Eclipse GSX-sold
1992 Galant VR4/[email protected]
Team B.U.M Squad..
Posts: 65 | From: Palm Harbor FL | Member Since: 08/30/08 | IP: (74.66.131.249) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1044250 posted 01/07/12 12:38 AM     Remind Me!  Send Private Message   Edit Post
A/c removed but have parts....
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (198.228.193.192) | Report this post to a Moderator
Rock Star Status
Galant VR-4 org Post #: 1044298 posted 01/07/12 02:19 PM     Remind Me!  Send Private Message   Edit Post
Need that location in the title.
Rance lives here...
Posts: 12049 | From: Cleveland, OH | Member Since: 12/21/04 | IP: (75.187.155.123) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1044323 posted 01/07/12 04:19 PM     Remind Me!  Send Private Message   Edit Post
Quoting akdriverjd:
Quoting 381gvr4:
I am 100% confident this car can be driven ANYWHERE in the country without a hiccup!
Thanks, Russ
Take him up on the challenge Sally!
Posts: 1607 | From: Manchester, NH | Member Since: 07/17/06 | IP: (71.181.55.124) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1048071 posted 01/25/12 08:29 PM     Remind Me!  Send Private Message   Edit Post
Price drop to $7900.... No trades
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (198.228.193.123) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1055235 posted 03/07/12 02:56 PM     Remind Me!  Send Private Message   Edit Post
ttt
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
quato
32/1000
Galant VR-4 org Post #: 1056061 posted 03/12/12 12:18 AM     Remind Me!  Send Private Message   Edit Post
I would love to take this car off your hands! However, I'm not due to come back to the states until this fall. If it's still for sale then, remember me, lol!
Posts: 230 | From: San Antonio, TX | Member Since: 01/31/12 | IP: (132.3.9.68) | Report this post to a Moderator
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 1056760 posted 03/15/12 12:57 PM     Remind Me!  Send Private Message   Edit Post
tempting! your right around the corner too!
E16g, fmic, 1000's, SD, v3, LC2 WB, fp2 cams, ARP's, etc
Posts: 681 | From: mass | Member Since: 02/17/09 | IP: (24.34.184.3) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1056789 posted 03/15/12 02:34 PM     Remind Me!  Send Private Message   Edit Post
^^^^ No deposit yet! I've had ALOT of interest with the weather change.
I had our dent guy at our dealership do $350(retail ) worth of work yesterday. He messaged out the D/S rear door crease and a couple of little door dings!
Spring time BUMP!
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
ScreaminE
Just don't like an idiot
Galant VR-4 org Post #: 1056792 posted 03/15/12 02:50 PM     Remind Me!  Send Private Message   Edit Post
I swear I'll never own another DSM or GVR4, but your car is so tempting. You seem like the type of person you really want to buy a car from.
-Scott H.
1267/2000 - sold
Posts: 646 | From: Pittsburgh South Hills | Member Since: 09/04/08 | IP: (208.216.231.17) | Report this post to a Moderator
turbojew
Galant VR-4 org Post #: 1056796 posted 03/15/12 03:13 PM     Remind Me!  Send Private Message   Edit Post
WISH I could buy this. Amazing Car and Build, just double my budget. haha
Posts: 126 | From: Dallas, Tx | Member Since: 01/02/12 | IP: (24.38.213.61) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1056814 posted 03/15/12 05:11 PM     Remind Me!  Send Private Message   Edit Post
^^^ Double your budget and about 1/2 of what I spent! lol Gotta love cars!
Quoting ScreaminE:
Thanks for the kind words. I AM a neurotic, nut case! I just want something with a warranty so I can throw the keys to one of my techs and say " FIX THIS!" Used GT500 or new Coyote.....
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Edited by 381gvr4 (03/15/12 05:16 PM)
turbophein
Member ++
1079/2000
Galant VR-4 org Post #: 1056822 posted 03/15/12 05:39 PM     Remind Me!  Send Private Message   Edit Post
i here you... new car warranty is the way to go. I know i am going to get flamed for this but i was considering the new turbo kia optima or the hyundai genesis for a toy car, with warranty of course. so much easier to just fill it up and do proper maintenance. they don't look half bad nowadays either.
138/2000
152/1000
Galant VR-4 org Post #: 1056862 posted 03/15/12 08:06 PM     Remind Me!  Send Private Message   Edit Post
^^ im all about that new kia. i was thinking the same thing... except the hybrid version... there cheap and get crazy awesome gas.
138/2000
152/1000
jmorri15
424/1000
Galant VR-4 org Post #: 1056912 posted 03/15/12 11:05 PM     Remind Me!  Send Private Message   Edit Post
the new genesis coupe is coming out too, 274hp 4b11 powered 34mpg and the aftermarket is beginning to make parts for it. ive driven the optima and sonata both are great cars but the new genesis is so sexy
2016 Mazda6 GT
2014 Chevy Volt (Totaled)
2013 Buick Regal GS (Sold)
2003 Nissan Sentra SE-R Spec V (Sold)
1994 3000GT SL (Sold)
1995 3000GT SL (Sold)
1992 GVR4 424/1k
1998 Ford Escort (Sold)
1996 Ford F-150
Posts: 171 | From: Kemp, TX | Member Since: 07/11/09 | IP: (141.156.175.105) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1057732 posted 03/20/12 02:48 PM     Remind Me!  Send Private Message   Edit Post
Looking to move on and getting more motivated to sell. Already have loan for new Stang but want this gone to go as downpayment!!!!!
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1058947 posted 03/26/12 09:53 AM     Remind Me!  Send Private Message   Edit Post
sale pending
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (198.228.193.175) | Report this post to a Moderator
381gvr4
used by hotroders
381/2000
Galant VR-4 org Post #: 1059162 posted 03/27/12 03:42 PM     Remind Me!  Send Private Message   Edit Post
SOLD.... I hope the new owner loves her as much as I did!
Sent from my iPhone
2007 Shelby GT
1968 Camaro 427BB
Posts: 568 | From: Wakefield, RI/Meriden, CT | Member Since: 11/05/07 | IP: (198.228.195.44) | Report this post to a Moderator
Pages: 1 | 2
Rating: *
Generated in 0.119 seconds in which 0.058 seconds were spent on a total of 14 queries. Turbo powered.
