Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » timing setting
timing setting
ercp98
perpetual n00b
1148/2000
Galant VR-4 org Post #: 484231 posted 05/25/07 10:31 AM     Remind Me!  Send Private Message   Edit Post
so i followed the vfaq way of setting the timing in the gvr4. i have it set at 5 degrees. all is ok while i set it using the timing light. i grounded the line attached to the firewall.also i took oout the logger while i was setting the timing. now why is it that my logger is showing (TMA) 8-10 degrees while at idle?
Posts: 1338 | From: northlake in illinois | Member Since: 08/05/03 | IP: (67.108.71.202) | Report this post to a Moderator
spoulson
0 people like this
Galant VR-4 org Post #: 484237 posted 05/25/07 10:47 AM     Remind Me!  Send Private Message   Edit Post
The logger shows you timing + base timing. The ECU is assuming the base timing is at 5* at all times.
Shawn Poulson*
  ʇuɐlɐƃ ɐ suʍo ɹǝƃuol ou *
Posts: 2907 | From: Middletown, DE | Member Since: 02/05/03 | IP: (63.113.210.29) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 484306 posted 05/25/07 01:03 PM     Remind Me!  Send Private Message   Edit Post
8-10 is correct at idle, without the terminal grounded. As soon as you connect the logger you are no longer in the "timing adjust" mode, so it should go back to using the maps.
| | | IP: (74.246.126.243) | Report this post to a Moderator
Polish
Dr. Pilosh Haagenscodyberger
Galant VR-4 org Post #: 484319 posted 05/25/07 01:25 PM     Remind Me!  Send Private Message   Edit Post
Which pin do you ground? I always forget which is the fuel pump and which is the timing since they are right next to each other.
My car site
Old GVR4 #1186/2000
Posts: 8936 | From: NE, IN | Member Since: 01/10/05 | IP: (69.245.199.104) | Report this post to a Moderator
CP
Galant VR-4 org Post #: 484321 posted 05/25/07 01:28 PM     Remind Me!  Send Private Message   Edit Post
There's only one metal pin in the plug on the firewall, at least on my car. The other side is plastic.
-Cy
Posts: 8936 | From: West Simsbury, CT | Member Since: 08/30/04 | IP: (198.105.0.129) | Report this post to a Moderator
IslandVr4
Galant VR-4 org Post #: 484322 posted 05/25/07 01:28 PM     Remind Me!  Send Private Message   Edit Post
the fuel pump is a single wire single type connector. the timing one is a connector that looks like a two pin but only has one. if it's still there it may have a dead head cap on it as well.
| | | IP: (207.118.53.186) | Report this post to a Moderator
Polish
Galant VR-4 org Post #: 484325 posted 05/25/07 01:31 PM     Remind Me!  Send Private Message   Edit Post
Both of mine are single wires with connectors on the end. One is larger than the other though, I assume the larger is the timing one? I haven't messed with it since last year and I've forgotten.
My car site
Old GVR4 #1186/2000
IslandVr4
Galant VR-4 org Post #: 484326 posted 05/25/07 01:35 PM     Remind Me!  Send Private Message   Edit Post
yea the larger one, when you look into it you'll see it could also be used as a two pin.
Polish
Galant VR-4 org Post #: 484328 posted 05/25/07 01:38 PM     Remind Me!  Send Private Message   Edit Post
Gotcha, thanks much. I'm going to label that one so I don't forget again.
My car site
Old GVR4 #1186/2000
CP
Galant VR-4 org Post #: 484332 posted 05/25/07 01:59 PM     Remind Me!  Send Private Message   Edit Post
I've never even seen the fuel pump one The one I use for timing is above the clutch fluid reservoir.
-Cy
IslandVr4
Galant VR-4 org Post #: 484337 posted 05/25/07 02:06 PM     Remind Me!  Send Private Message   Edit Post
two pry bars, upper one points to fuel pump test connector lower one points to timing connector.
1 registered and 7 anonymous users are browsing this forum.
Generated in 0.03 seconds in which 0.017 seconds were spent on a total of 14 queries. Turbo powered.
