non abs hardlines and awd proportioning valve Part Numbers
324vr4
Bozeman, Montana
next mod is to yank the abs system so i need:
non-abs proportioning valve from awd dsm,
the two hard lines that run from the brake cylinder to prop valve,
the two hard lines that run from the prop valve to front calipers.
please let me know if you have any of these in good condition. thanks
spartan
Sheboygan, WI
I would only look for a used prop valve if you are doing this conversion. I just bought brand new hard lines from mitsubishiparts.com for like $32 shipped! If you want the part #'s I can pm them to you, or post them up.
powerplay
Norwell, MA
MB699654 Valve
MB500563 Brake line Right (replacement# MB699881)
MB534428 Brake line Left (MB699045)
MB534855 M/cyl line Pri (MB699877)
MB534856 M/cyl line Sec (MB699878)
Please post if you can find these parts available form any suppliers. I have heard many times that these parts are going "NLA"
324vr4
Bozeman, Montana
that is badass! thanks guys. a whole brand new mitsubishi abs delete for 80.54 plus 8.05 for shipping. not bad, not bad at all.
spartan
Sheboygan, WI
Yes, these are the part numbers that I used on 2/4/07 with prices:
Master cylinder to proportioning valve lines:
MB534-426 caps# 56256B $4.52
MB500-561 caps# 56255B $4.88
Front brake lines to proportioning valve:
MB857-176 caps# 56267R (passenger side) $3.60
MB534-428 caps# 56267L (driver side) $5.15
powerplay
Norwell, MA
I ordered the four brake line parts from PartsForMitsubishi.com a week ago just to see if I could get them. It was canceled today "NLA" from Mitsubishi. I know JNZ can't get some of the parts as well. So if you are planning on doing this it is a word to the wise, plan accordingly.
spartan
Sheboygan, WI
UPDATE: I received all of the lines from mitsubishiparts.com MINUS the prop valve to passenger side front line. It is NLA from both them and the dealer, just FYI.
CP
West Simsbury, CT
It's only the short master to p-valve lines that are NLA. I was able to order the p-valve to wheelwell front lines from JNZ a few months ago, as well as the intermediate lines that bolt to the front struts.
slugsgomoo
Tacoma, WA
the board going down appears to have eaten my post. I called to order from Walkers Mitsu (Mitsubishiparts.com) and the proportioning valve and the secondary line are NLA, but the other three lines were available. It cost me like $50 including shipping to my door. Now i just have to find the other two pieces and i'm good to go. Alternatively you can grab a prop valve and make SS lines.
I used a proportioning valve out of a 3000gt/stealth NON TURBO, found it in a junk yard.
my brakes feel great, no problems 2+ years.
I built my own brake lines: bought ~20 feet of brake line and re-used the fittings on the ABS box because some of the stock fittings were really rusty.
hope this helps.
