Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Electrical Question - Palm Serial Cable + Car Charger + Pics
GalantVR4-1229
Galant VR-4 org Post #: 300391 posted 01/30/06 01:09 PM     Remind Me!  Send Private Message   Edit Post
I've got a Sony Clie N760c which I've got to successfully log with MMCD. I've also got a car charger which chargers it.
I'd like to combine the two so I can power the palm while logging.
I've opened up both connectors and it looks like it would be easy to do.
My plan is to simply hook the red wire from the car charger up to the serial connector the same way it is now. I was not going to bother with the ground since the serial cable is grounded through the ECU when logging anyways.
The 170 Kohm resister on the Car Charger is too much, it would signal the palm to look for USB serial connection. 47 Kohm is for signaling serial communications.
My question is, should I also ground the black cable from the charger too the serial cable or the car? and will I burn out the ECU? :P
| | | IP: (24.75.136.130) | Report this post to a Moderator
DarkDevilMMM
if I want a potential headache, I rather just get another GVR4
335/1000
Galant VR-4 org Post #: 300427 posted 01/30/06 02:04 PM     Remind Me!  Send Private Message   Edit Post
connect both ground, from logger cable and charger cable, to pin 13. then the charger to cig. lighter, and logger to ALDL connector just you would normally do. ground is ground, as long as you are not shorting any connection, you won't burn anything. Normally
huh?
Posts: 4065 | From: Vacaville, CA | Member Since: 06/08/01 | IP: (158.96.4.13) | Report this post to a Moderator
Generated in 0.023 seconds in which 0.016 seconds were spent on a total of 14 queries. Turbo powered.
