Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Radiator fan does not run??? !!!!FIXED!!!!
4g63t
Galant VR-4 org Post #: 238891 posted 07/22/05 10:51 PM     Remind Me!  Send Private Message   Edit Post
My car is overheating b/c the rad fan does not run. I removed the radiator to swap the turbo and it worked before. Everything is plugged in, the stock gauge works, the temp works on the datalogger, the relays are fine, and the fan motor works. The only thing I haven't checked is the temp sensor thats in the bottom of the rad and the resistor(?). Any tips on checking them?
-Chris-
2004 Ford E350
09 HD VRSC Night Rod Special
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
Edited by 4g63t (07/24/05 02:59 PM)
Posts: 2073 | From: Lancaster PA | Member Since: 01/31/02 | IP: (24.23.111.115) | Report this post to a Moderator
oneup
Galant VR-4 org Post #: 238895 posted 07/22/05 10:57 PM     Remind Me!  Send Private Message   Edit Post
I think thats the fan switch(plug on bottom of the radiator)...I don't think it would too expensive to replace it..might as well as put new ones in to see if it does come on or not.
Edited by oneup (07/22/05 10:59 PM)
| | | IP: (65.27.148.111) | Report this post to a Moderator
crucible
Galant VR-4 org Post #: 238925 posted 07/23/05 06:55 AM     Remind Me!  Send Private Message   Edit Post
Chris
Try grounding the wire of the rear-facing sensor on the thermo housing.Thats the back up emergency temp switch that turns both fans on high.Hopefully the fans will kick on as thats your last resort for cooling.Might help indicate the problem.
Double check the fan connections since you recently messed with them
| | | IP: (69.118.8.97) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 239004 posted 07/23/05 02:42 PM     Remind Me!  Send Private Message   Edit Post
I just tried grounding that wire and nothing happened
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
crucible
Galant VR-4 org Post #: 239009 posted 07/23/05 03:09 PM     Remind Me!  Send Private Message   Edit Post
Did you have the key in the "ON" position or car running?
4g63t
Galant VR-4 org Post #: 239017 posted 07/23/05 03:47 PM     Remind Me!  Send Private Message   Edit Post
I tried key off and key on
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
4g63t
Galant VR-4 org Post #: 239018 posted 07/23/05 03:53 PM     Remind Me!  Send Private Message   Edit Post
I just removed the resistor thing and cleaned the contacts. put it back on, still nothing...
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
crucible
Galant VR-4 org Post #: 239020 posted 07/23/05 03:56 PM     Remind Me!  Send Private Message   Edit Post
Relays.Swap some from another known working circuit
4g63t
Galant VR-4 org Post #: 239028 posted 07/23/05 04:10 PM     Remind Me!  Send Private Message   Edit Post
I did that, but I just did it again just in case I missed something, still no-go. I used a multimeter to test the relay fuse bx and the relays are getting power...
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 239032 posted 07/23/05 04:13 PM     Remind Me!  Send Private Message   Edit Post
so the fan works when you connect it directly to 12v's ?
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (24.145.203.12) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 239034 posted 07/23/05 04:17 PM     Remind Me!  Send Private Message   Edit Post
Yes
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
SEVEN26
Galant VR-4 org Post #: 239036 posted 07/23/05 04:18 PM     Remind Me!  Send Private Message   Edit Post
i don't know what to tell you about the problem. i got a new temp sensor and that didn't help me. so i just hooked up a fan to a switch inside the car. when ever the datalogger displays slightly high temp i just flip the switch. you might want to do that for now
| | | IP: (68.51.188.195) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 239051 posted 07/23/05 05:06 PM     Remind Me!  Send Private Message   Edit Post
Yeah, I'm really at a loss here, I'm gonna call it quits for now, and resume tomorrow. I'm going to try to go through the entire schematic and find the problem, I'm not that great at electrical problems, but I'll give it a shot. Thanks for all the help.
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
twkd
Galant VR-4 org Post #: 239057 posted 07/23/05 05:51 PM     Remind Me!  Send Private Message   Edit Post
Does that fan have a resistor in it to control speed? If it does, perhaps it could be bad.
twkd
| | | IP: (24.175.75.11) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 239064 posted 07/23/05 06:19 PM     Remind Me!  Send Private Message   Edit Post
Yeah, it has that weird little metal/ceramic resistor thing attached to the fan. I took it off and cleaned it up, but still haven't had any luck.
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
Senior Ricer
1552/2000
Galant VR-4 org Post #: 239067 posted 07/23/05 07:01 PM     Remind Me!  Send Private Message   Edit Post
Chris,
Try bypassing that resistor by running a jumper from one side to the other or just cut the wires off of it, throw it in the garbage (where it belongs) and even if that doesn't fic it you'll be better off in the long run. However if you grounded the wire on the back of the t-stat housing (I can't remember the color but if you really need it I can track it down) it should turn both fans on HIGH which means that the resistor on each fan is bypassed since that's how you get high speed on the fans. Look in the schematics and see if one fuse feeds all off the relays for the cooling fans and that may be all it is. Sorry I can't help you more from here.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.222.254) | Report this post to a Moderator
twkd
Galant VR-4 org Post #: 239068 posted 07/23/05 07:02 PM     Remind Me!  Send Private Message   Edit Post
Test the resistor with an ohmmeter to see if it's still good.
twkd
Senior Ricer
1552/2000
Galant VR-4 org Post #: 239069 posted 07/23/05 07:05 PM     Remind Me!  Send Private Message   Edit Post
The problem is not usually in the resistor but where the wires are soldered to it. I've that go bad on both of my GVR4's as well as a couple of others and after soldering mine twice I just tore it out and soldered/heat shrunk the wires together.
John
Galant VR-4 org Post #: 239087 posted 07/23/05 08:09 PM     Remind Me!  Send Private Message   Edit Post
These might be two stupid suggestion but I thought I'd bring them up just in case.
(1) When you said that the fans work if you connect them directly to the 12V supply, did you connect the power to the connector plug or did you connect it somewhere else more convenient nearer the body of the fan? I'm just thinking it might be something stupid like a broken wire.
(2) Did you previously remove any relays? Not all relays are identical and I once spent hours trying to work out a similar problem before I realized I'd plugged the wrong friggin' relay back in.
Paul.
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (219.78.136.177) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 239246 posted 07/24/05 02:58 PM     Remind Me!  Send Private Message   Edit Post
John, you are the man!! I definately owe you a beer! I cut the resistor out and soldered the wires together, and lo and behold, it works great! Thanks everyone for the tips and advice.
-Chris-
2004 Ford E350
91 GGSX - Sold
297/1000 - Sold
140/1000 - R.I.P.
Generated in 0.056 seconds in which 0.022 seconds were spent on a total of 14 queries. Turbo powered.
