Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » HOTBITS SHOCK DYNO DATA.....
Larry Parker
Rally Member
Galant VR-4 org Post #: 237543 posted 07/19/05 06:54 AM     Remind Me!  Send Private Message   Edit Post
Well we dynoed the hotbits adjustable VR4 strut and as I thought they are great!
Many would not belive this but at 30" a second on the F/V curve they are 15 times more adjustable than a DMS!!!!! Also they dont lag a bit!!! Even at a meter a second....... What does this mean? Well they rock and blow JIC out of the water! (sorry guys) These shocks adjustment mech is on par with ohlins, penske, JRZ, MOTON.....etc.....
I am very very pleased with this.....!!!
More info to come......!!!
Cheers
Larry
Parker Rally Sport
1500lbs of adjustment at 30" a sec
Here is the football showing NO lags
Here is famed DMS strut for a EVO 4..... Note the small adjustment range in both bump and rebound....... and the very linear nature of the curve.....Take note of the scale on the left..... 100lbs of adjustment at 30" a sec
Edited by Larry Parker (07/19/05 07:14 AM)
Posts: 1092 | From: Metro detroit | Member Since: 02/11/04 | IP: (204.80.222.11) | Report this post to a Moderator
a_santos
Brasileiro Turbinado
Galant VR-4 org Post #: 237805 posted 07/19/05 08:57 PM     Remind Me!  Send Private Message   Edit Post
thats sweet. I hope my graph looks like that, minus the adjustment.
I've been telling guys about these for a while, and there are always alot of skeptics. Well here is some hard evidence.
Abhay Schweitzer
www.techne-us.com
Posts: 2057 | From: San Diego, CA, USA | Member Since: 10/22/02 | IP: (68.41.75.130) | Report this post to a Moderator
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 237928 posted 07/20/05 10:34 AM     Remind Me!  Send Private Message   Edit Post
Dumb Q: How does Hotbits compare to say, Ground Controls?
Ryan Hertz
Posts: 13500 | From: Chicago, IL | Member Since: 07/29/02 | IP: (68.254.141.70) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 237963 posted 07/20/05 11:41 AM     Remind Me!  Send Private Message   Edit Post
The ground control shocks? Advanced design? They STINK.... NO ADJUSTMENT AT ALL! the knobs dont work.... If you are refering to the coil kits...Its a spring...There is no comparison...... There is really no better coil over Its all threaded collars and a spring.... Springs are the last equation in a suspension setup......
LP
"shock builder, tuner and designer"
Parker Rally Sport/Hotbits tuning USA
Rally America #622
OPEN class
KT
Turbotoolbox
Galant VR-4 org Post #: 238206 posted 07/21/05 03:05 AM     Remind Me!  Send Private Message   Edit Post
OK, another question. Hot do Hotbits compare to Tein SS?
KT
2016 Wrangler JKU
2012 VW Jetta TDI
2002 F-250 PSD
1999 LS7 C5
1988 Conquest TSi
Posts: 1243 | From: Omaha, NE | Member Since: 10/20/03 | IP: (202.44.112.10) | Report this post to a Moderator
markrieb
Galant VR-4 org Post #: 238231 posted 07/21/05 07:51 AM     Remind Me!  Send Private Message   Edit Post
For those of us that are not shock engineers how about a quick primer on what the differences are between a good shock curve and a bad shock curve. The difference between regressive and digressive valving and why one is better than the other. High speed vs. low speed curves.
First off, the space between the curves gives you an idea of the range of adjustment of the shock. So the further apart the lines, the more adjustment that is available. I would guess that you also want the curves to be parallel and smooth.
I'm still trying to learn what is good and bad.
I'm also considering a set of the Hotbits for my EVO.
Thanks,
Mark
Posts: 612 | From: Kennewick, WA, USA | Member Since: 02/23/01 | IP: (65.219.190.90) | Report this post to a Moderator
Galant VR-4 org Post #: 238232 posted 07/21/05 07:55 AM     Remind Me!  Send Private Message   Edit Post
+1 for Mark's comments.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10753 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 238236 posted 07/21/05 08:02 AM     Remind Me!  Send Private Message   Edit Post
Man you guys are gonna make me write a novel!
I will do a little write up soon... as far as tein SS??? I dunno I never dynoed them?
If some one has one please send it for dynoing.....
A few comment for now.....
Linear curves are no good for street or race cars on gravel or tarmac......good for off road racing trucks.....
Small adjustment ranges are no good either.....
digressive curves work best on racing/sport vehicles
LP
Edited by Larry Parker (07/21/05 08:59 AM)
SinCityVR4
Galant VR-4 org Post #: 238533 posted 07/21/05 10:53 PM     Remind Me!  Send Private Message   Edit Post
Any websites or links on where to get this for a good price?
| | | IP: (68.108.148.120) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 238580 posted 07/22/05 06:42 AM     Remind Me!  Send Private Message   Edit Post
Yeah... ME! I am the US rebuild/service center and also do sales....
Email me at
[email protected]
Rally America #622
OPEN class
mj_rosenfeld
Galant VR-4 org Post #: 238587 posted 07/22/05 07:03 AM     Remind Me!  Send Private Message   Edit Post
And how would you compare the Hotbits to Koni Sports?
Mike R.
| | | IP: (64.0.248.227) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 238597 posted 07/22/05 08:08 AM     Remind Me!  Send Private Message   Edit Post
Sense I started building shocks in 98' I have always belived KONI's to be junk.... They have LARGE variations from part to part in general forces and adjustment ranges.... KONI's are not in the same leauge as these shocks! THIS IS NOT HYPE! ALL DATA! In the past racers would buy 6 or 8 koni and dyno them to try and find a pair that matched.... If there was something better for the money guys I would push it! If you all dont remeber I designed a 50mm inverted mono tube, but decided to work with these instead as they are that good..... I just ripped one open to take a look see at the adjustment mech and I am very impressed and so is my good friend and shock engineer for arvin meritor!.....
Regards
LP
Rally America #622
OPEN class
twkd
Galant VR-4 org Post #: 238748 posted 07/22/05 03:32 PM     Remind Me!  Send Private Message   Edit Post
Some day the youth will realize when somebody knows what they are talking about. Thanks for all the good information, Larry.
It's good to know that hard data can finally prove when a product is good and not left to some jaded punk to review it.
I'm tickled pink with this suspension. I can now take a cloverleaf at close to 60 when I could only do close to 40 stock and close to 50 with the Whiteline springs. I'm a happy man
Larry, could you use a raw set of Hotbits to come up with a new application?
twkd
| | | IP: (68.206.0.156) | Report this post to a Moderator
Arty
Galant VR-4 org Post #: 238905 posted 07/23/05 12:12 AM     Remind Me!  Send Private Message   Edit Post
It's great to see some real data on suspension.
While you have the shock "ripped open" how about posting some pictures of some of the more interesting internal bits, like, the piston and its valving, and the adjustment mechanism. I'd appreciate it, if you could give us some comments as to why the Hotbits design works better than some of the other adjustables.
How many of the Hotbits parts have you been able to test so far?
Edited by Arty (07/23/05 12:19 AM)
Posts: 384 | From: Victoria. Australia | Member Since: 09/09/02 | IP: (202.162.64.245) | Report this post to a Moderator
NZVR4
Galant VR-4 org Post #: 238910 posted 07/23/05 12:55 AM     Remind Me!  Send Private Message   Edit Post
Can someone supply the part/model number of these shocks.
I can get them from aussie, but need to know the model number.
| | | IP: (203.173.159.212) | Report this post to a Moderator
KingGalantVr4
Galant VR-4 org Post #: 238927 posted 07/23/05 07:26 AM     Remind Me!  Send Private Message   Edit Post
Which units are these? 40mm? 50mm? 60mm?
How do the hotbits hold up to rally? Do they break at the tabs like the DMS instead of bending? As I'm sure you know, its a lot cheaper to buy a tab and have it re-welded to a shock body then it is to replace the whole unit. DMS ability to be rebuilt and survive is amazing. What kind of extention do the hotbits have? Thanks Larry!
| | | IP: (70.22.27.150) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 239047 posted 07/23/05 04:50 PM     Remind Me!  Send Private Message   Edit Post
The EVO 4 data from above is the 50mm rally units......As for there ability to hold up to ralling... YES! They are stout and cost less to rebuild than a DMS Also they need no service between events like a DMS or any inverted strut..... As for failures.... I have only heard of one failure of tabs and that was recently on a neon SRT4...... Neons with stock rear mounts side load shocks alot! as they can deflect upto an 1" under load...... As for pics of the guts.... No can do........ sorry
But they are superior for many reasons......
They are built under controled conditions......
They where designed by an aeronautical engineer that knows his shite.....
They are made in malaysia where labor is cheap and many features can be built in
for much less.......
They use CNC machine pistons and screw machined adjustment mechs........All parts are held to TIGHT tolerances..........
The adjuster mech is a prop shape and designed to meter the amount of fluid that a 22mm piston rod displaces.... BIG ROD = more sensitivity.........
Im glad to dispel shock myths..... I hate junk dampers that are proclamied as great!!
Cheers
LP
Rally America #622
OPEN class
Posts: 1092 | From: Metro detroit | Member Since: 02/11/04 | IP: (68.61.97.115) | Report this post to a Moderator
Galant VR-4 org Post #: 239065 posted 07/23/05 06:28 PM     Remind Me!  Send Private Message   Edit Post
Larry,
What would be involved in getting Hotbits to make me some shocks for an application that isn't already in existence. Or is there already a Hotbits application for the 1997 and up 8th Generation Galants?
Paul.
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (218.189.72.4) | Report this post to a Moderator
rob323
Galant VR-4 org Post #: 239296 posted 07/24/05 06:55 PM     Remind Me!  Send Private Message   Edit Post
Larry,
I have the hot bits adjustable race spec coilovers on my J spec. the front springs are 8kg/cm. I have to wind the shocks up to at least 10 clicks from full hard before they start to stop the car from bouncing (very off putting at high speed on rough roads). My feeling is that the spring rate for the fronts is too stiff for Aussie roads and are considering on getting some 6kg/cm springs to see what they are like. Got any advice?
| | | IP: (220.236.27.116) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 239384 posted 07/25/05 06:05 AM     Remind Me!  Send Private Message   Edit Post
6kg seems like a good choice..... That is the rate used on the rally sets and that is around 450lbs..... Rather stiff for a rally car, but an evo 5 Ohlins set uses 500lbs springs up front for gravel..... This will also close up the split front to rear on your car making if feel a bit more balanced......
Best of luck
LP
Rally America #622
OPEN class
Larry Parker
Rally Member
Galant VR-4 org Post #: 239385 posted 07/25/05 06:08 AM     Remind Me!  Send Private Message   Edit Post
Paul is this the E85A body car??? If so we have a spec already....
LP
Rally America #622
OPEN class
Galant VR-4 org Post #: 239390 posted 07/25/05 06:31 AM     Remind Me!  Send Private Message   Edit Post
Larry,
No it's an EC5A body !!!
Paul
Posts: 7333 | From: East Sussex, U.K. | Member Since: 04/19/04 | IP: (219.78.136.177) | Report this post to a Moderator
CamZR4
Galant VR-4 org Post #: 261125 posted 09/25/05 03:22 PM     Remind Me!  Send Private Message   Edit Post
So you would actually recomend these units for use on a gravel rally car?
I've been using a set of inverted 30mm Bilstiens, but I bent one, and then damaged it again at the weekend. so it looks like it is time for an upgrade.
As these are a lot cheaper than DMS or 50mm Bilstiens I have to look seriously at them.
Thanks for the good infomation.
| | | IP: (60.234.208.229) | Report this post to a Moderator
Larry Parker
Rally Member
Galant VR-4 org Post #: 261275 posted 09/26/05 07:25 AM     Remind Me!  Send Private Message   Edit Post
DMS are junk.... They are tough enough to hold up but are almost non adjustable......
They are just not worth the 4k they cost now..... Yes the VR4/talon setup is suitable for gravel use.....
Regards
lp
Rally America #622
OPEN class
Bimmubishi
giant log
Galant VR-4 org Post #: 261358 posted 09/26/05 11:05 AM     Remind Me!  Send Private Message   Edit Post
Here's a good thread on shock dynos.
http://www.honda-tech.com/zerothread?id=1104049&page=1
http://www.koni-na.com/presentations/civic/slide2.html
Larry, can you list some prices on these? Be sure to qualify that the Konis that people are talking about are street and not race parts. Bilstein and Koni also make racing suspension. This is some serious info. thanks for posting it!
Thanks,
Al
Posts: 5701 | From: Boston, Massachusetts | Member Since: 07/15/03 | IP: (65.174.55.100) | Report this post to a Moderator
Rating: *****
Generated in 0.237 seconds in which 0.114 seconds were spent on a total of 14 queries. Turbo powered.
