Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Winter wheel/tire storage - inflate or deflate?
Scott Y
mighty skunk hunter
953/1000
Galant VR-4 org Post #: 233005 posted 07/04/05 10:21 AM     Remind Me!  Send Private Message   Edit Post
I'm putting some mounted winter tires away until the snow flies again. We have a storage shed that I'm going to put them in, and I'm going to clean the wheels up, put them in tire bags, and stack them in the corner.
Should I leave the tires fully inflated, partly inflated?
-Scott Y
Scott Y
Posts: 482 | From: Lakewood, Colorado, USA | Member Since: 05/08/01 | IP: (12.160.40.63) | Report this post to a Moderator
DongeR
Galant VR-4 org Post #: 233007 posted 07/04/05 10:23 AM     Remind Me!  Send Private Message   Edit Post
deflated.
| | | IP: (68.122.33.71) | Report this post to a Moderator
Barnes
Firechicken
908/1000
237/2000
Galant VR-4 org Post #: 233040 posted 07/04/05 01:26 PM     Remind Me!  Send Private Message   Edit Post
I never even thought of that. Thanks for the info.
-Jon Barnes
#580/2000 (Long Gone)
#908/1000 Black (Sold)
#237/2000 White
Posts: 6249 | From: Richland, WA | Member Since: 02/09/03 | IP: (68.119.13.59) | Report this post to a Moderator
Scott Y
mighty skunk hunter
953/1000
Galant VR-4 org Post #: 233054 posted 07/04/05 02:45 PM     Remind Me!  Send Private Message   Edit Post
Can you expand on that? The technical reason(s) you should deflate mounted tires before storing them is....
thanks for any info.
Scott Y
Scott Y
josh long
Galant VR-4 org Post #: 233088 posted 07/04/05 05:53 PM     Remind Me!  Send Private Message   Edit Post
Keep them off the ground,and it will help keep the rubber from drying out.
| | | IP: (206.81.222.24) | Report this post to a Moderator
1uGlyGalaNt
im a troller on a budget
Galant VR-4 org Post #: 233136 posted 07/04/05 09:19 PM     Remind Me!  Send Private Message   Edit Post
Put them in trash bags.
Old electrical engineers don't die, they just light the way. RIP Chester Quantz, 1926-2009.
Posts: 2558 | From: Plano, TX | Member Since: 06/16/04 | IP: (4.225.190.92) | Report this post to a Moderator
Matticus
Galant VR-4 org Post #: 233146 posted 07/04/05 10:26 PM     Remind Me!  Send Private Message   Edit Post
Here's a little cut & paste from a Tirerack article:
Since heat and exposure to the elements are the primary factors that influence a tire's aging process, drivers can prolong their tire's life by minimizing their impact. Here are some tips for storing tires that will not be used continuously.
• Don't store a vehicle with weight on its tires for extended periods of time. Long-term inactivity is more harmful to tires than short weekly drives that flex the tires and help maintain oil dispersion within the rubber compounds.
• DO NOT APPLY ANY TIRE DRESSINGS. Tire compounds are formulated to resist ozone cracking or weather checking.
• Keep the tires out of direct sunlight. The sun’s ultraviolet rays and radiant heat are detrimental to rubber. We have used a pyrometer to measure tires that were simply sitting in direct sunlight on a parked vehicle. Surprisingly those tires’ temperatures were 135° Fahrenheit on their surface.
• Place each tire in its own large, opaque, airtight plastic bag (such as lawn and garden bags) for storing. Avoid allowing any moisture and remove as much air as practical (some drivers even use a vacuum cleaner to draw out as much as possible). Close the bag tightly and tape it shut. This places the tire in its own personal mini-atmosphere to help reduce oil evaporation.
• Place the tires in a cool, dry location. It is better to place tires in a dry basement than outdoors or in a hot garage or attic. The basement temperatures will tend to remain cooler and more stable, while outdoor, garage and attic temperatures will often become hot and face daily fluctuations in temperature.
• Keep the tires away from sources of ozone. Electric motors that use contact brushes generate ozone. Keep your tires away from the furnace, sump pump, etc.
While tires will age somewhat regardless of what precautions are taken, these procedures will help slow the process compared to not doing anything.
I hate to advocate the use of drugs and alcohol to anyone, but hey, they worked for me. - Dr. Gonzo
Posts: 1184 | From: Pasco, WA | Member Since: 11/30/02 | IP: (68.33.145.69) | Report this post to a Moderator
1941Galant
Will fight mice for food
1941/2000
Galant VR-4 org Post #: 233156 posted 07/04/05 11:31 PM     Remind Me!  Send Private Message   Edit Post
I guess I should take my 17's off my car since it isn't going to be running for a while.
Posts: 1904 | From: Charles Town, WV | Member Since: 08/21/04 | IP: (24.115.170.83) | Report this post to a Moderator
SteveHebert
Galant VR-4 org Post #: 233185 posted 07/05/05 03:34 AM     Remind Me!  Send Private Message   Edit Post
Nice post Matticus - good stuff.
| | | IP: (64.136.26.228) | Report this post to a Moderator
Generated in 0.042 seconds in which 0.022 seconds were spent on a total of 14 queries. Turbo powered.
