Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » GM 3 Bar MAP Sensor and harness source
keydiver
Galant VR-4 org Post #: 169123 posted 01/05/05 11:50 AM     Remind Me!  Send Private Message   Edit Post
Guys, I've been shopping for a good price for the GM 3 BAR MAP sensor for a while, and I think I found a reasonable source. Most guys that have it don't have the harness, or expect you to go to Pep Boys, buy a similar harness, and modify it. But this GM dealer in Akron, Ohio had the sensor and harness for ~$81, with 1-1.5' of wires to splice unto:
His name is Dallas (Dal) Slabaugh, 800-362-9494.
sensor part # 12223861
harness part # 15305891
Just FYI.
Edited by keydiver (01/05/05 11:51 AM)
| | | IP: (65.8.37.217) | Report this post to a Moderator
Key Fob Guy
Galant VR-4 org Post #: 169127 posted 01/05/05 11:54 AM     Remind Me!  Send Private Message   Edit Post
Someone move this to the How To and Info Archive forum.
-mitsuturbo
Posts: 18895 | From: NJ | Member Since: 09/11/03 | IP: (208.215.178.150) | Report this post to a Moderator
teet
Senior Teeter
Galant VR-4 org Post #: 169137 posted 01/05/05 12:11 PM     Remind Me!  Send Private Message   Edit Post
why wouldn't you just get it from RRE for 60?
thx
john
Posts: 1245 | From: northwest | Member Since: 03/08/01 | IP: (134.134.136.1) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 169213 posted 01/05/05 02:22 PM     Remind Me!  Send Private Message   Edit Post
Well, if I could have found it on their site, I might have. Do you have a link?
It was $60.44 from Dal. But, as I said, most places that carry the sensor don't have the right plug. I preferred to get both a sensor and the proper plug from one source.
jpgvr4
Galant VR-4 org Post #: 169402 posted 01/05/05 08:36 PM     Remind Me!  Send Private Message   Edit Post
what make model and year of gm are these found on?
| | | IP: (67.167.2.250) | Report this post to a Moderator
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 170097 posted 01/07/05 10:25 AM     Remind Me!  Send Private Message   Edit Post
Didn't know about Buschur's pricing, but Dal is a great guy. He has been "the man" for all GM parts for a long time in the Impala community as well as f-bodys, t-buicks, etc. Great guy to do business with.
-Paul G.
#490/1000
Posts: 1558 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (12.44.48.39) | Report this post to a Moderator
pudhed
Galant VR-4 org Post #: 170850 posted 01/10/05 03:52 AM     Remind Me!  Send Private Message   Edit Post
RRE has it w/ pigtail for $60, http://www.roadraceengineering.com/ems.htm
Summit has it for $51 as part MSD-2313. No pigtail. Pretty much every GM
in the junkyard will have a map sensor pigtail, though you might need to cut off
some tabs to make it fit.
http://store.summitracing.com/default.asp?target=eproduct.asp&N=120+4294925143+4294924502+310152
| | | IP: (66.218.52.237) | Report this post to a Moderator
pisces
Galant VR-4 org Post #: 173915 posted 01/18/05 10:00 AM     Remind Me!  Send Private Message   Edit Post
The 3 BAR MAP sensor is found on turbo Trans Ams of the late 80's. I'd go straight to GM for the part rather than trying to source it out at a parts store.
| | | IP: (24.158.18.222) | Report this post to a Moderator
teet
Senior Teeter
Galant VR-4 org Post #: 174650 posted 01/19/05 05:49 PM     Remind Me!  Send Private Message   Edit Post
bout half way down
jpgvr4
Galant VR-4 org Post #: 177495 posted 01/26/05 07:27 PM     Remind Me!  Send Private Message   Edit Post
Okay, a little more research shows that is a great price. Most of the "Trademotion" resellers get about $80 for the sensor, and $27 for the harness.
It appears the sensor is used on most turbo'd GM's including Diesel's and the 89' TA. Those particular part no.'s are GMC.
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 774536 posted 03/28/09 08:28 AM     Remind Me!  Send Private Message   Edit Post
To go with this, you could instead of splicing one get a complete harness that connects both the 3 bar GM MAP sensor and the IAT sensor to the stock maf connector.
link
It's $40 bucks and can make life much easier for those looking into a speed density conversion. Just an idea I figured I could add to this topic, it's worked out great for me.
Posts: 2798 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (63.160.231.176) | Report this post to a Moderator
9t1tsi
Galant VR-4 org Post #: 775152 posted 03/30/09 10:49 AM     Remind Me!  Send Private Message   Edit Post
^ how would that plug affect if your running an aem ems? because we hard wired the plug wiring into the ecu, so with this i wouldnt need to? is that correct?
| | | IP: (71.244.143.27) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 775196 posted 03/30/09 12:08 PM     Remind Me!  Send Private Message   Edit Post
Honestly not I'm sure, as I'm running DS-MAP for map based tuning instead of the AEM EMS unit. I believe it would work just the same. I mean you can try it and see just how well it works with your setup, but as you already got it set and it works fine why change it, you know.
92 Galant VR-4 362/1000
76 ColtGalant Hardtop
79 Colt Sigma Wagon -1UZ Swap!
88 Fiji Blue Starion
94 Montero SR
Posts: 2798 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (204.214.131.136) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 775206 posted 03/30/09 12:40 PM     Remind Me!  Send Private Message   Edit Post
Quoting 9t1tsi:
All this changes is you'll be using the factory wiring for the MAP and temp sensors, rather than running new wires to your AEM.
-Jeff
1881/2000
50/1000
Posts: 7874 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
0 registered and 4 anonymous users are browsing this forum.
Generated in 0.032 seconds in which 0.015 seconds were spent on a total of 14 queries. Turbo powered.
