Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » non-cruise cable install
Joojoo Bee
Galant VR-4 org Post #: 143592 posted 10/17/04 12:44 PM     Remind Me!  Send Private Message   Edit Post
Finally got the non-cruise cable in. It was all very easy until I got to the part where you actually have to take the ball and clip part off the base of the throttle pedal. I'm not exactly a small guy so I actually had to unmount the pedal by removing the two 12mm bolts that holds the assembly against the wall. Even then, it was a pain getting it off. A guy with slim fingers could probably have done it easily but not me. After many attempts and curses, I got the thing off. I don't know how any of you actually got the clip and ball off the throttle pedal without unmounting the pedal itself but if I hadn't unmounted the pedal, I never would've got this done.
Just some advice for the bigger framed and more fat-fingered guys out there. Take the time to unscrew the 2 botlts holding the throttle pedal against the wall. I spent a stupid amount of time trying to just take off the clip as it is.
| | | IP: (67.83.7.61) | Report this post to a Moderator
DongeR
Galant VR-4 org Post #: 144879 posted 10/20/04 11:20 AM     Remind Me!  Send Private Message   Edit Post
Use a screwdriver and pop that ball off. i had the hardest time as well. then ward (467) showed me the light.
| | | IP: (68.122.33.163) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 145167 posted 10/21/04 06:08 AM     Remind Me!  Send Private Message   Edit Post
discommect the engine end so the cable goes slack, pull ALL the slack through at the top of the pedal, then lever the yellow thing out of the pedal.
Oh yea, you'll need to drop the lower dash panel then you can see what you are doing!
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Posts: 1555 | From: Midlands, UK | Member Since: 08/04/04 | IP: (194.129.249.241) | Report this post to a Moderator
Dustin
Galant VR-4 org Post #: 251368 posted 08/28/05 06:46 PM     Remind Me!  Send Private Message   Edit Post
part numer MB539465 for non-cruise throttle cable
| | | IP: (24.21.112.98) | Report this post to a Moderator
drewwillgetyou
Galant VR-4 org Post #: 274226 posted 11/08/05 01:31 PM     Remind Me!  Send Private Message   Edit Post
where can you get that cable from?
| | | IP: (12.219.137.184) | Report this post to a Moderator
14u2nV
Resident Pedobear
Galant VR-4 org Post #: 274230 posted 11/08/05 01:42 PM     Remind Me!  Send Private Message   Edit Post
Dealer, online, junkyard, other member. Part number is listed above.
~Kenneth Brian
"Censorship offends me" ~Author Unknown
Posts: 9397 | From: Agency/St. Joe, MO | Member Since: 07/22/04 | IP: (207.192.227.177) | Report this post to a Moderator
1uGlyGalaNt
im a troller on a budget
Galant VR-4 org Post #: 274235 posted 11/08/05 01:51 PM     Remind Me!  Send Private Message   Edit Post
you can use 1.5L csm cables or 1.8 cables w/out cruise.
ya, those things are the easiest mods in the world. just disconnect from the tb, intake mani, and pop that yellow ball off the back of the pedal, voila!
Old electrical engineers don't die, they just light the way. RIP Chester Quantz, 1926-2009.
Posts: 2558 | From: Plano, TX | Member Since: 06/16/04 | IP: (66.169.216.45) | Report this post to a Moderator
MrVito
Galant VR-4 org Post #: 737441 posted 12/21/08 08:47 PM     Remind Me!  Send Private Message   Edit Post
I just finished putting in a non-cruise control cable myself. I was replacing the clutch pedal assembly today, along with the associated bushings, and ordered the non-CC cable to do at the same time. 4 bolts later and it was done. I dropped the lower dash panel and then used a set of needle nose pliers on the green/yellow retaining clip that attaches to the upper portion of the gas pedal to pull the stock, cruise control cable off, then WHAMM-O, done.
| | | IP: (76.125.31.199) | Report this post to a Moderator
Generated in 0.029 seconds in which 0.015 seconds were spent on a total of 14 queries. Turbo powered.
