Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Idle Issues? Rebuild your servo module and FIAV.
misterfixit
Victory Runner
Galant VR-4 org Post #: 1201593 posted 02/13/15 04:46 PM     Remind Me!  Send Private Message   Edit Post
Hi all,
It's been a long time since I posted any 'work' here. I rediscovered these pictures from about two years ago after a conversation with another Galant guy here. so I'm posting this thread to document the process.
This issue came to me as a colleague had a galant and he told me the car would not idle correctly. He'd been to a shop and they had screwed around with the idle screw and unplugged the throttle stop switch. I checked the ECU which had been capped about 6 months before and it was all fine. The idle screw was wound shut and when I logged the car I found the servo was hard over shut but still the idle was high.
Our cars have 4 methods for air to pass through the throttle body. all work together to make things good.
1/ throttle plate - driver uses this to control the airflow to the motor.
2/ idle screw - this is used to adjust the bypass air to the engine.
3/ servo - ecu uses this to finely adjust the air flow for smooth running
4/ fiav - this is the equivalent of the choke. at low temp it is open and allows air through (more air to go with more fuel for warm up).
The FIAV is under the knockout cover here:
When I took the servo module off the gap was huge so we did some experiments. The FIAV should close at about 90C. So in a pan of hot water it went with a thermometer.
The valve did not close at all. Only option was to reset it all. Here is the valve disassembled:
Now as I had not done this before I was curious how much stroke I needed. so I put the thing in cold water and noted the position of the core poker. then we heated it again and noted the position. Poker is shown here (looking inside the FIAV that has been stripped):
After doing this I set the valve back (with a dab of sealant on the thread to hold it) and adjusted it so I could no longer blow through the servo body. Once I found this position I backed out the valve orifice (round bit with the thread on) approximately the same distance as I'd seen the poker move earlier.
Once this was done I verified the aperture was ok. We then heated the servo again to 90C and verified I could not blow through the FIAV.
After that everything was reassembled and I reconnected the stop screw. We confirmed with the idle screw shut, it would slow, and with it open it was very fast. And also with the logger the servo was controlling open as the screw was closed and closed as the screw was opened.
I set up the logger and adjusted the idle screw so the servo was hovering around the middle of it's stroke after the car had warmed up. And it's been a doll ever since.
Hope this helps
Rich
92 UK 1800 GALANT DD
88 JDM E39A GALANT VR-4, running. But only just.
93 CB4A --- rewound
91 PDM GTI Resurection project. Aborted
Stuff Index
Edited by misterfixit (02/13/15 04:53 PM)
Posts: 1555 | From: Midlands, UK | Member Since: 08/04/04 | IP: (119.94.69.211) | Report this post to a Moderator
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1201602 posted 02/13/15 08:28 PM     Remind Me!  Send Private Message   Edit Post
Awesome work and info as usual Rich. I messed around with this on my colt a few months ago when rebuilding the TB. How did you remove the threaded part? I used needle nose pliers once the plug was removed. Out of 4 FIAV's every one of them was seized in there and the plastic was very brittle so they broke before loosening up. I finally experimented with a 5th one and ended up cutting the aluminum housing ( I had plenty of spares from old TB's ) to see what was holding them in so tight. All I saw was a white substance that had acted like loc-tite or something. It was caked in the threads. Did you not experience anything like this?
93 Mitsubishi Expo LRV
95 Eagle Summit DL coupe
98 Mitsubishi Mirage DE coupe
Posts: 2502 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (184.3.237.217) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 1201666 posted 02/14/15 04:14 PM     Remind Me!  Send Private Message   Edit Post
Strange, well it seems like the one I looked at was strange then.
We'd stripped the module off and boiled it at least once, as I wanted to see what happens. It had the white gunky stuff, but it was no issue to pull out on the one I took pics of.
maybe boiling it was a trick?
I have another to do. I guess I''ll find out how brittle it is then
Cheers
Rich
93 CB4A --- rewound
Stuff Index
89Mirageman
It's no Mirage, man
Galant VR-4 org Post #: 1201676 posted 02/14/15 07:51 PM     Remind Me!  Send Private Message   Edit Post
I bet heating it up did break it loose. Sadly I really didn't think about that at the time. I seem to have a good one on my colt since I have a rock steady idle with no revving up and down but I will definitely do this trick on my next TB build.
Galant VR-4 org Post #: 1201678 posted 02/14/15 08:22 PM     Remind Me!  Send Private Message   Edit Post
it sees coolant temp normally so i doubt it was the 90 degree tap water making the difference. Mine is sliced in half and then JB welded shut. I still idle fine.
Before blocking off a 1g I had, the idle would bounce when she was cold. I had no luck backing out that plastic disk either. It wouldn't budge.
Wheres the rebuild on the servo!? That's the good stuff.
Edited by tektic (02/14/15 08:38 PM)
Posts: 1499 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.90.241) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 1202220 posted 02/21/15 04:44 PM     Remind Me!  Send Private Message   Edit Post
Servo module is the whole lot. The servo is a separate piece. The one off m car here is in pieces.
For reference servo numbers old and new. Mitsubishi's service letter superceding the metal type to the plastic type.
Cheers,
Rich
93 CB4A --- rewound
Stuff Index
Posts: 1555 | From: Midlands, UK | Member Since: 08/04/04 | IP: (49.144.24.240) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1203756 posted 03/12/15 09:30 AM     Remind Me!  Send Private Message   Edit Post
hey Rich, how much did your poker/plunger stick out after heating?
the one on my experiment was 6mm.
and my valve stopper was metal and not the same as the black one on your exploded view of the valve ass'y.
so approx 6mm from the point when i couldn't blow through is the 'correct' opening right?
i have reassembled it yet...
oh, and the freeze plug is reusable?
Posts: 273 | From: NV | Member Since: 08/05/08 | IP: (120.29.75.12) | Report this post to a Moderator
misterfixit
Victory Runner
Galant VR-4 org Post #: 1204002 posted 03/15/15 08:10 AM     Remind Me!  Send Private Message   Edit Post
I re-use the freeze plug. A quick wipe of sealant around the edge and reinsert.
Cheers,
Rich
93 CB4A --- rewound
Stuff Index
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1216893 posted 09/20/15 10:42 AM     Remind Me!  Send Private Message   Edit Post
I put it in a vise and sprayed a little liquid wrench on top. Then applied a pool of CRC Brakleen (red). With well fitting needle nose pliers tips, I rocked it back and forth until it started to loosen. The Brakeleen is similar to dry cleaning fluid so that may work as well. The adhesive on the threads looked like contact cement. I've removed two plugs this way...this plastic (bakelite?) version and a metal one from a 90 GGSX. Both had 200K+ miles on them.
Posts: 1275 | From: MD | Member Since: 04/07/05 | IP: (108.31.167.181) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1216924 posted 09/20/15 06:49 PM     Remind Me!  Send Private Message   Edit Post
were you able to test if it 'helps' on cold starts?
Posts: 273 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
holeshotmoe
subclass marmoreus
Galant VR-4 org Post #: 1217079 posted 09/22/15 12:00 PM     Remind Me!  Send Private Message   Edit Post
Did it this summer, so haven't had the cold weather to test yet. But as explained above, I put it in boiling water and the valve never completely closed. Then into ice water I watched it open up fully. This verified the "wax pellet" and rod under the valve were still functional (but out of adjustment, likely due to aging). With the hot & cold measurements, I had to adjust it downward to get to the halfway point. I added another revolution downward, hoping to err on the side of closing a little early (lower temp) rather than late. Also installed new shaft seals during reassembly. Now upon cold startup (70-ish degrees F), idling is 1050-1100 rpm for a few minutes then settles back to 750. And four years of idle surge is gone! BTW, definitely use an impact driver to pull the screws. I fouled the ones on the first fiav and had to use little vice grips to remove them :-O Used the tool on the second one and they came out like a breeze. **Edit to clarify: I used a hand held impact driver LIKE THIS , not a powered one**
Edited by holeshotmoe (09/27/15 09:43 AM)
"Just to be pedantic!"
Galant VR-4 org Post #: 1217186 posted 09/24/15 06:52 AM     Remind Me!  Send Private Message   Edit Post
Could someone please explain how to get the knock-out/freeze plug removed? I tried prying it from behind and tapping one side but it didn't seem to want to budge.
Posts: 2161 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (168.1.99.209) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1217190 posted 09/24/15 07:30 AM     Remind Me!  Send Private Message   Edit Post
pry it slowly in the opening where Rich has his index finger on in this pic:
Edited by AllanL (09/25/15 01:08 PM)
Posts: 273 | From: NV | Member Since: 08/05/08 | IP: (120.29.72.11) | Report this post to a Moderator
Galant VR-4 org Post #: 1217334 posted 09/25/15 09:50 PM     Remind Me!  Send Private Message   Edit Post
Thanks! I did try prying it there but it didn't seem to want to budge. Oh well, I have three spare FIAV's I can try pull apart, and also one from a 6A12 V6 that has the FIAV deleted from factory, only contains the ISC in the housing and a bypass for the coolant.
Posts: 2161 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (168.1.75.25) | Report this post to a Moderator
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1217335 posted 09/25/15 10:41 PM     Remind Me!  Send Private Message   Edit Post
You need JIS bits to remove them easily, not phillips.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8896 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
AllanL
Heal and Toe
Galant VR-4 org Post #: 1217372 posted 09/26/15 06:57 PM     Remind Me!  Send Private Message   Edit Post
got pics of those G?
Posts: 273 | From: NV | Member Since: 08/05/08 | IP: (112.204.231.138) | Report this post to a Moderator
Galant VR-4 org Post #: 1217945 posted 10/05/15 03:29 PM     Remind Me!  Send Private Message   Edit Post
Philips on top JIS on the bottom.
More from here click
Posts: 2161 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (168.1.99.211) | Report this post to a Moderator
Generated in 0.075 seconds in which 0.02 seconds were spent on a total of 14 queries. Turbo powered.
