Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Roll Cage Building
Roll Cage Building
Pivvay
Galant VR-4 org Post #: 110076 posted 07/17/04 09:28 PM     Remind Me!  Send Private Message   Edit Post
Real roll cages cost money. A few grand minimum. I now know why. This post will be about installing a rollcage (not just bar) in my galant. It should pass NHRA spec but more importantly it is actually safe <img border="0" title="" alt="[Smile]" src="images/graemlins/smile.gif" /> I'm sure I'll leave out some of the steps but I'll do my best to answer questions. The guy holding the cutout is Erron, he owns the bender and is the real genious here. He's done 4+ cages now, not including the 3 iterations in his sweet road race 3SI.
First steps. Gut the rear of the car. All of it. Carpet, seats, tar at least around the base plate areas, unbolt the wiring. The car will be torn apart for a while although I've kept mine drivable to get back and forth from home to Erron's place. Both front seats have to come out when you are doing this. Mine are in for this picture but they came out right afterwards. It doesn't work with them in the car, believe me I tried.
<img src="http://www.shiftedthinking.com/pivvay/pictures/rearprecage.jpg" alt=" - " />
Next make a cutout. Get a big ass piece of cardboard and make it line up as well as possible with the inside of the b pillar. This is important as it makes life much nicer when you are at the bender and your car is 50 feet away. I have 2 of these now. I may consider loaning them out.
<img src="http://www.shiftedthinking.com/pivvay/pictures/cutout.JPG" alt=" - " />
Next help Erron setup the bender in the new concrete at the new house. This is long process. You get hot, burn your arms and neck because you are stupid. Doh. Now bender is setup. It looks sweet. Good thing you only dropped it once and not on your toes. It weighs a lot.
<img src="http://www.shiftedthinking.com/pivvay/pictures/bendersetup.JPG" alt=" - " />
Next cut your tubing. I'll save you all the hassel and tell you to cut a 13 foot length. Don't mess up or you'll have to cut a second 13 foot length. Like we did on the 2nd bend. I''m dumb. Our tubing came in 20 foot lengths. Then you'll need a ~6 and ~7 feet pieces for the harness bar and main hoop diagonal. These 3 bars (including the main hoop) are the most important to get in. You cannot do ANYTHING until they're in. The messed up first piece is still good for other bars. The pound the floor flat where the base plates go. I'll detail this tomrrow when I finish. This part is hard. Plasma cutter or a sawzall at least are very nice. You'll see why tomorrow. Finish the main hoop. Angle it into the car. It's too long on one side. Take it back out and cut it. Try again. The top and side angles are not quite far enough. Bend a bit more. Now you got it perfect. Main hoop fits TIGHT into the car. Look at work below and smile. All day and main hoop is finally bent. It's okay that it comes "in" at the bottom. We'll be expanding the hoop INTO the b pillar and seam welding it there when finished. This will further increase the strength.
<img src="http://www.shiftedthinking.com/pivvay/pictures/mainhoop.JPG" alt=" - " />
This concludes the first of many many installments of how to do a real, tight cage install. BTW the main hoop weighs 17 pounds. GVR4s have BIG main hoops.
| | | IP: (128.138.45.184) | Report this post to a Moderator
4orced4door Galant VR4.org Moderator
Out Standing
Galant VR-4 org Post #: 110077 posted 07/17/04 11:38 PM     Remind Me!  Send Private Message   Edit Post
Nice man, I am looking forward to seeing the entire process. Try to document it as good as you can! This is one of those mods I'd like to do but since it's so hard to find solid GVR4 specific info I haven't really made any plans.
Posts: 9846 | From: Raleigh, NC | Member Since: 07/19/02 | IP: (65.41.13.43) | Report this post to a Moderator
skratch
Galant VR-4 org Post #: 110078 posted 07/18/04 12:50 AM     Remind Me!  Send Private Message   Edit Post
Post deleted by Team Ducktape
| | | IP: (68.202.173.235) | Report this post to a Moderator
Jayru
Galant VR-4 org Post #: 110079 posted 07/18/04 12:51 AM     Remind Me!  Send Private Message   Edit Post
Nice looking Pivvay, but it doesn't cost thousands for a cage, usually good shops charge about $100 a point + the cost of tubing which isn't that much.
| | | IP: (24.238.67.128) | Report this post to a Moderator
Doug Thomas
Galant VR-4 org Post #: 110080 posted 07/18/04 01:37 AM     Remind Me!  Send Private Message   Edit Post
Are using using chromoly steel?
| | | IP: (67.87.104.200) | Report this post to a Moderator
Doug Thomas
Galant VR-4 org Post #: 110081 posted 07/18/04 01:39 AM     Remind Me!  Send Private Message   Edit Post
quote:
That's true in NY, NJ and PA area, but they might be more in Colorado areas.
TeamDucktape
Galant VR-4 org Post #: 110082 posted 07/18/04 02:07 AM     Remind Me!  Send Private Message   Edit Post
Very nice. Keep us updated.
Moved, and cleaned.
| | | IP: (65.31.186.75) | Report this post to a Moderator
Pivvay
Galant VR-4 org Post #: 110083 posted 07/18/04 10:32 AM     Remind Me!  Send Private Message   Edit Post
This isn't a slam at anyone's cage building but there is no one out here that is $100/pt that I trust to do it "right". I will detail all the steps and issues along the way that I feel make it come out the safest possible. Erron has taught me a lot.
Generated in 0.039 seconds in which 0.013 seconds were spent on a total of 14 queries. Turbo powered.
