Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Intake Heat Shield Pics.
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109639 posted 04/22/04 09:17 AM     Remind Me!  Send Private Message   Edit Post
I've wanted to make one of these for a while and I was feeling a bit ambitious last night so I finally did it. If anyone else has interest in one I can give you the dimensions I used. The only place I screwed up is where it goes to the radiator I didn't make it long enough. I am going to try another and hopefully learn from my mistakes but aluminum sheet is expensive so I won't do it right away. I also plan on putting some type of insulation on the shield to further reflect the heat. It is set up to work with a trunk mounted battery, 2G MAS, and a stock 2G intake boot. Here are some pics.
John
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (68.193.209.233) | Report this post to a Moderator
bleck
Galant VR-4 org Post #: 109640 posted 04/22/04 09:32 AM     Remind Me!  Send Private Message   Edit Post
Somebody's been busy! Damn, nice piece, John. To be honest tho, I don't think that the length on the radiator side is gonna be a problem.
Btw, thanks for the crank pulley, I'm gonna hit you up with 5 stars. I think I may have a little "surprise" for you guys on Sat. morning. [Big Grin]
| | | IP: (67.84.11.26) | Report this post to a Moderator
bob in chicago
Galant VR-4 org Post #: 109641 posted 04/22/04 10:51 AM     Remind Me!  Send Private Message   Edit Post
You can use ABS plastic sheet to make a cover to keep the hot underhood air away.
| | | IP: (216.80.12.5) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109642 posted 04/22/04 10:57 AM     Remind Me!  Send Private Message   Edit Post
Yeah, I want to do something like that but in aluminum. Maybe on hinges with a DZUS fastener to latch it.
John
GeeRIDE
Galant VR-4 org Post #: 109643 posted 04/22/04 11:55 PM     Remind Me!  Send Private Message   Edit Post
Looks good John!
| | | IP: (68.169.157.168) | Report this post to a Moderator
BlackHole
Galant VR-4 org Post #: 109644 posted 04/22/04 12:18 PM     Remind Me!  Send Private Message   Edit Post
Another easy option to seal it is to use clip-on weatherstripping. If you get the wall height right and put the weatherstripping on the top edge it will seal to the hood when closed. It works very well this way - my temps are within 5F of ambient at almost all times.
| | | IP: (130.36.27.125) | Report this post to a Moderator
fmlycar569
Galant VR-4 org Post #: 109645 posted 04/22/04 12:21 PM     Remind Me!  Send Private Message   Edit Post
NOICE!!!
| | | IP: (161.57.211.5) | Report this post to a Moderator
keydiver
Galant VR-4 org Post #: 109646 posted 04/22/04 02:33 PM     Remind Me!  Send Private Message   Edit Post
quote:
Thats what I want to do! Where do you guys get the sheetmetal or ABS???
| | | IP: (67.35.17.143) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109647 posted 04/22/04 05:56 PM     Remind Me!  Send Private Message   Edit Post
After searching every Home Depot and Lowes within 30 miles of home for almuminum sheet, I found it at the local hardware store in the small town that I live. It is about 1/8" thick.
John
Mitsuturbo
Galant VR-4 org Post #: 109648 posted 04/22/04 06:04 PM     Remind Me!  Send Private Message   Edit Post
that big flat metal area under the filter can be cut out as well.. getting more cool air to your filter/intake
i cut mine across the front, and down the 2 sides, then folded the metal down so my tire won't throw shit up in there.. works great! took about 20 minutes of creative cutting with a die grinder cutoff wheel and 2 pair of tinsnips
oh.. and a hammer to kind of "smooth out some rough edges" [Big Grin]
| | | IP: (67.161.247.241) | Report this post to a Moderator
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 109649 posted 04/22/04 06:04 PM     Remind Me!  Send Private Message   Edit Post
Before and after air temps?
Looks good BTW.
Posts: 3855 | From: Cypress, TX | Member Since: 08/07/02 | IP: (24.17.247.200) | Report this post to a Moderator
bleck
Galant VR-4 org Post #: 109650 posted 04/22/04 10:47 PM     Remind Me!  Send Private Message   Edit Post
True, Mitsuturbo. Jayru made an intake that went right down that spot under the filter. A true cold air intake for the VR4. Worked pretty damned well, too. Think he sold it on here a while back.
BlackHole
Galant VR-4 org Post #: 109651 posted 04/23/04 08:01 AM     Remind Me!  Send Private Message   Edit Post
Jeff,
RTP, I've got a bit of hi-temp plastic if you want some. While Al is easier to work with, I went with hi-temp plastic [don't remember which kind, but good for >210F] to eliminate any possibility of heat transfer.
Romanova,
According to my datalogger the factory MAS reported:
Before: at idle, temps ~40F over ambient; at highway speeds temps ~20F over
After: at idle, temps 15-20F over; at speed >20mph, temps <5F over
This "after" data is with the old unsealed airbox. I don't have the new sealed airbox installed yet, but I have no doubt it will keep temps at ambient all the time.
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109652 posted 04/23/04 08:30 PM     Remind Me!  Send Private Message   Edit Post
I am going to cut a circular hole under the filter with a hole saw, flange it, and run a duct to where the passenger side foglight used to be. That should work well.
John
2fasdsm
Galant VR-4 org Post #: 109653 posted 04/26/04 09:59 AM     Remind Me!  Send Private Message   Edit Post
nice john [Applause] wanna make one for me?
| | | IP: (216.153.183.114) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 109654 posted 04/26/04 08:05 PM     Remind Me!  Send Private Message   Edit Post
quote:
I may be willing to sell you mine if my latest idea becomes reality. Let me know if you're interested, I just want the 30.00 the sheet of aluminum cost me.
John
Generated in 0.092 seconds in which 0.037 seconds were spent on a total of 14 queries. Turbo powered.
