Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » Keyless Entry
Keyless Entry
138/2000
152/1000
Galant VR-4 org Post #: 1091317 posted 10/26/12 07:48 AM     Remind Me!  Send Private Message   Edit Post
PART / COLOR / LOCATION
12 VOLT CONSTANT / WHITE (+) / IGNITION SWITCH HARNESS
STARTER / BLACK/YELLOW (+) / IGNITION SWITCH HARNESS
IGNITION 1 / BLACK/WHITE (+) / IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1 / BLUE/BLACK (+) / IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) / GREEN/WHITE (+) / IN DRIVERS KICK PANEL
POWER LOCK / BROWN/WHITE (TYPE B) / @ RELAY BLOCK, ABOVE FUSEBOX
POWER UNLOCK / BROWN/BLUE (TYPE B) / @ RELAY BLOCK, ABOVE FUSEBOX
DOOR TRIGGER/ RED/GREEN (-) / IN DRIVERS KICK PANEL
HORN / GREEN/BLACK (-) / @ STEERING COLUMN HARNESS
TACH / YELLOW/BLACK / @ IGNITION COIL
BRAKE / GREEN (+) / @ SWITCH ABOVE BRAKE PEDAL
ALL OTHER LEFT OVER WIRES SHOULD BE INDIVIDUALLY TAPED OFF AND ZIP TIED OUT OF THE WAY.
I have found the wiring diagram for it and broke it down to this. I will now be ordering a keyless entry system, It's a Audiovox AA925 3-button Remote Keyless Entry System. It's extremely inexpensive and looks small enough to fit inside of the Evo flip keys i am making. I will post pictures of the product and installation as i move along.
138/2000
152/1000
Edited by transparentdsm (10/27/12 03:05 PM)
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.237.230) | Report this post to a Moderator
138/2000
152/1000
Galant VR-4 org Post #: 1122489 posted 05/09/13 09:20 AM     Remind Me!  Send Private Message   Edit Post
so i got around to installing the unit, everything is pretty easy to install except finding the relay to tap the lock unlock button into, so here are pictures of the relay and where the wires are. took me maybe 40 minutes to install the whole thing. thats counting pulling the car apart and putting it back together.
this is the relay, remove the two screws and flip that whole block over.
these are the wires, this is the lock, the unlock is in the back on the oposite side, i couldn't take a picutre that was good enough.
138/2000
152/1000
Edited by transparentdsm (05/09/13 05:26 PM)
Posts: 3675 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (70.44.0.205) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.059 seconds in which 0.016 seconds were spent on a total of 14 queries. Turbo powered.
