Galant VR-4 Forums » Galant VR-4 » How To and Info Archive » How to remove a stuck rotor with a simple nut and bolt.
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 1021569 posted 09/29/11 12:29 AM     Remind Me!  Send Private Message   Edit Post
I have tried to explain to people how to use a nut and bolt to remove a pesky rotor and can never really explain it very well. Since I was doing just that tonight I decided to take some quick pics so people can see what I'm talking about.
Something to keep in mind if the rotor is really stick this is most likely going to chew it up. If that's the case it may not be reusable. Try this at your own risk.
What I basically do is take off the caliper and find any bolt a little smaller that the caliper mounting hole. I put the bolt in backwards with a nut on the inside of the mounting flange and thread it towards the caliper. If the nut isn't bigger than the caliper hole find a think washer that is bigger. Once the end of the bolt makes contact with the rotor tighten it just a bit, back it off, rotate the rotor a little bit and do it again until the rotor finally pops off.
Here is how I set it up.
This picture kinda sucks but you can see where the bolt pushes on the rotor.
If you look at the rotor in relation to the ABS ring you can see how much I pushed the rotor before rotating it and doing it again. After 3 or 4 tries the rotor popped right off.
Posts: 4085 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (70.162.87.93) | Report this post to a Moderator
pauleyman
Galant VR-4 org Post #: 1021922 posted 09/30/11 07:52 AM     Remind Me!  Send Private Message   Edit Post
OEM rotors (and most aftermarket) have a bolt hole on the face to accomplish this same task. If you use the oem holes you don't push on the face of the rotor but instead you are pushing on the hub. A light coating of anti seize on the mating surfaces will help this problem from happening in the first place. Only one time have I ever seen a rotor not come off by using the the factory bolt holes and that one was so bad I cut the rotors off the hub in pieces. Literally several pieces. It was the worst I had ever seen a rotor stuck to a hub.
Paul Lyons
24 years of mitsu
I must be nuts.
Posts: 89 | From: Oklahoma City, OK | Member Since: 02/27/11 | IP: (99.172.167.147) | Report this post to a Moderator
donkeylips
Swapped Female Parts
924/1000
108/1000
372/1000
Galant VR-4 org Post #: 1022192 posted 10/01/11 05:16 PM     Remind Me!  Send Private Message   Edit Post
Although this trick has worked for me many times, just a heads up: I recently broke a steering knuckle doing this. The brake caliper bracket ear sheared right off. I'll get a pic if I get a chance. On the same car, tons of MAPP gas heat got the other side off without using this trick.
1990 Nordic Blue Galant GSX, A71 KG 372/1000
A72 KG 108/1000 & A72 BG 924/1000 - Both Rotted
93 Mirage, 92 TealSI AWD, 85 200sx, 87 Trans Am
Posts: 552 | From: Rochester, NY | Member Since: 06/19/09 | IP: (74.74.141.199) | Report this post to a Moderator
Hard Snarker
1051/2000
Galant VR-4 org Post #: 1023070 posted 10/04/11 02:22 PM     Remind Me!  Send Private Message   Edit Post
For the front rotors I just thread two bolts through the two smaller threaded holes in the rotor. Tighten those down and they push the rotor right off the hub.
For the rears I use a block of wood and a small sledge to hammer them off.
-Mark
1051
Posts: 11959 | From: Yakima, WA | Member Since: 04/29/01 | IP: (74.82.68.160) | Report this post to a Moderator
boostedinaz
Fatty McButterpants
1101/2000
Galant VR-4 org Post #: 1023351 posted 10/05/11 12:47 PM     Remind Me!  Send Private Message   Edit Post
When I tried to use those little threaded holes they stripped and wouldn't push the rotor off so I went this route. I could see if a rotor was really stuck it could break an ear off but as always try at your own risk. Personally I haven't had that issue the few times I have used this method.
Michael
The rebuild of 1101
Posts: 4085 | From: Scottsdale, AZ | Member Since: 04/20/06 | IP: (167.80.246.204) | Report this post to a Moderator
91VR41400
Galant VR-4 org Post #: 1024224 posted 10/08/11 11:43 AM     Remind Me!  Send Private Message   Edit Post
Yeah just in case anybody didnt know, like already mentioned, some rotors have 2 threaded holes to stick screws into and it pushes the rotor off..
Posts: 109 | From: Rockville MD 20852 | Member Since: 07/24/04 | IP: (69.255.225.22) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1024523 posted 10/09/11 04:08 PM     Remind Me!  Send Private Message   Edit Post
Quoting pauleyman:
Antisieze is a great idea but if you have to take off a rotor that is stuck AND the two little threaded holes strip out (Yes is does happen) just take a big mallet and smack TOWARDS the hub between the wheel studs (the hub part not the rotor!) It's like smacking a balljoint or tierod from the side, kind of counter intuitive but a few good whacks and it will pop right off.
I love my crazy mother!!!
Posts: 1624 | From: Manchester, NH | Member Since: 07/17/06 | IP: (71.181.62.3) | Report this post to a Moderator
GVRBound
Galant VR-4 org Post #: 1060265 posted 04/02/12 10:03 PM     Remind Me!  Send Private Message   Edit Post
Ive always used a 3 pound brass mallet and hit them once or twice. MANY MANY brake jobs this guy has done and that hasnt failed me yet. The brass hammer deforms before the rotor does.. My first .02 post!
| | | IP: (98.183.19.254) | Report this post to a Moderator
Generated in 0.033 seconds in which 0.01 seconds were spent on a total of 14 queries. Turbo powered.
