Brett Adams' 1991 Galant VR-4 1837/2000
Owner: Brett Adams
Message Board Name: GSTwithPSI
Year: 1991
Number: 1837/2000
Best 1/4 Mile Pass: 12.030 @ 119.39 mph
Best Trap: 119.39 mph
Best 60': 1.722
Dyno: 436whp/417ft-lbs
Dyno Video: Click
Build Thread: 1837/2000
Track Thread: Click
Fuel:
• Dual in-tank Aeromotive 340 E85 stealth fuel pumps
• Aeromotive A1000 external fuel pump (plumbed in series)
• Aeromotive A1000 AFPR (set @ 50 PSI BFP)
• Aeromotive 14105 fuel rail
• OBP 2 liter fuel surge tank
• -6 AN rail lines/fittings
• Fuel pump rewire
• Fuel Lab 818 In-Line Fuel Filter
• FIC 1650cc High-Z injectors
Intake & Intercooler:
• K&N 4.0" high flow air filter (RU-2520)
• Custom 4" intake pipe and heat shield
• Turbosmart Kompact BOV
• Bar and plate FMIC 20"x 13" x 3.5" core
• 2.25" short route aluminum intercooler piping
• 1G non turbo throttle body w/ FIAV block off plate
• Magnus V3 cast intake manifold
Turbo & Exhaust:
• Forced Performance 3052 ball bearing turbo (700382-5012):
--- Anti-surge compressor cover
--- Compressor (57.02MM Inducer / 76.2MM Exducer)
--- Turbine (60.0MM Inducer / 54.8MM Exducer)
--- DSM FP30 bolt-on turbine housing
• Forced Performance 3" cast recirculated V-band O2 housing (O2FPDSM3C)
• Forced Performance -4AN inline oil filter (black .030" restrictor)
• Tial 44mm wastegate
• 3" CM Performance turbo back exhaust
• FP race exhaust manifold
• Turbo Performance exhaust manifold blanket
• PTP FP30 turbine housing blanket
Cooling:
• Dual core 2 row aluminum radiator
• 41mm upper radiator hard pipe
• Greddy 1.3 bar radiator cap
• Stant SuperStat 180* T-stat
• 12" SPAL high performance puller fan (VA01-AP70/LL-36A)
• 13" SPAL slim pusher fan (VA13-AP9/C-3 5A)
Interior:
• Recaro SRD seats
• Sabelt 3-point safety harnesses
• Personal steering wheel and shift knob combo
• Custom Galant VR-4 horn button by André Phan
• 89' under dash
• OEM metal brake and clutch pedal covers
• Kicker DS series speakers (4", 5.25", 6.5")
• Kicker CompR sub woofer (43CWR102 dual-voice-coil)
• Alpine MRD-M1001 amplifier w/ remote bass control (RUX-4180)
• Rockford Fosgate 1 farad - 20 volt surge capacitor (CPC10-03)
• Alpine CDA-7894 deck
• Ecliptec Shift-P2
• Greddy 52mm boost & EGT gauges
• Greddy 60mm water temp gauge
• Intellitronix digital oil pressure gauge
• Paulo fiberglass dual gauge pod
• OEM Mitsubishi rear sunshade
• Custom floor mats
Exterior:
• JDM RS hood
• JDM front and rear bumpers
• JDM clear corners
• JDM door handle scratch guards
• JDM door & rear window visors
• JDM keyless fuel lid
• JDM headlights w/ HID conversion
• 55W 2500k H3 fog lights
• Eterna Grille (pictured white)
• Euro Grille (pictured with fog lights)
Motor:
• 6 bolt block .020" over
• Stock uncut crankshaft
• King XP tri-metal racing series main & rod bearing set
• Eagle H-beam rods sized for a 22mm wrist pin
• Ross 2G 85.5mm 8.3:1 forged aluminum pistons
• ARP main studs/bolts
• 2G oil pickup tube
• 1G cylinder head (Oil port mod, Manley valve springs, titanium retainers, 3G revised lifters)
• ARP head studs/bolts
• HKS cams (264 intake / 272 exhaust)
• Fidanza adjustable cam gears
• ARP cam gear bolts
• Fluidampr engine damper
• ARP engine damper bolts
• Fel-Pro composite head gasket (9627PT)
• All new engine gaskets (FelPro)
• New water pump and timing components (Gates)
• Gates accessory belts
• Gates timing belt
• OEM Mitsubishi hydraulic tensioner
• HKS clear upper timing belt cover
• New oil pump with straight cut gears & OEM BSE kit
• -8AN B&M oil cooler setup (11'' x 5-3/4'' x 1-1/2'')
• -10 AN shaved valve cover
• -10 AN 3 port sealed/baffled catch can
• Custom billet aluminum Galant VR-4 oil cap by Jason Everts (RIP)
EMS, Logging & Electronics:
• ECMlink V3 full (tuned on speed density)
• Dynatek ARC-2
• Coil on plug ignition w/ JMF coil plate
• NGK BR8EIX plugs @ .028
• Black top CAS
• Innovate LC-1 wideband O2
• Moroso sealed battery box relocated to trunk
• Bosch 90 amp AL4008X alternator
• Custom 8 Gauge grounding kit
• Battery cutoff switch in trunk
• ECMlink boost control setup with Ingersoll Rand BCS
• New OEM knock sensor
• Blitz Dual turbo timer
• Omni Power 4 bar MAP sensor
• GM IAT
• Engine wiring harness semi-tucked and recovered with Raychem DR-25
Drivetrain:
• Shep stage 2 transmission KW5M332NPXV (Red Line MT-90):
--- New input shaft
--- New 3-4 hub/sleeve
--- New 3-4 fork
--- New DSM 3-4 gears
--- Double 2-3 synchros
--- Welded center diff
• Quarter Master 7.25″ Rally Gear-Drive 6-leg street twin disk clutch (Custom spec'd by TMZ Performance):
--- QM 7.25" V-Drive Rally Clutch cover w/ 3500# diaphragm spring
--- QM 7/8" x 20-spline street friction gear drive 7.25" twin disk clutch pack
--- QM 7.25" V-Drive pressure plate
--- QM 7.25" V-Drive floater plate
--- TMZ Performance 6-leg street flywheel
• Competition Clutch forged steel release fork & pivot ball
• OEM Mitsubishi TOB
• B1H 4 bolt viscous LSD (Red Line Heavy ShockProof)
• 23 spline transfer case (Red Line Heavy ShockProof)
• New OEM shifter cables/brackets
• JNZ Tuning short shifter
• Solid shifter base bushings
• Stainless braided line from master to slave
• New OEM 1G clutch master
• New OEM slave cylinder (13/16" bore "green piston")
• New front CV shafts
• Driveshaft Shop 3.5" aluminum drive shaft (MISH3-HD)
• Torque Solutions billet engine mounts
Brakes, Wheels & Suspension:
• Work Meister S1R Wheels:
--- 4x114
--- 17x7 & 17x8
--- Offset 30
• Federal RS-RR tires 255/40 R17
• Ichiba V1 hubcentric spacers (10mm front, 12mm rear)
• Aluminum hub centric Rings * OD 73.1 mm * ID 67.1 mm
• Extended lug studs
• Project Kics Leggdura 2 piece lug nuts
• New front stabilizer links
• JIC Magic FLT-A2 coilovers
• Tein front camber plates
• JDM strut tower covers
• Whiteline front and rear swaybars
• Ingalls 1G DSM adjustable rear camber arms
• 3SX rear AWS delete kit w/ adjustable toe arms
• Whiteline front and rear strut tower bars
• 4 wheel steering delete
• ABS delete w/ 1G AWD prop valve
• Volk Metal Craft 3KGT caliper adapter brackets
• 1st Gen 3KGT VR-4 four piston front calipers
• StopTech Sport drilled & slotted brake rotors (127.46052L/R)
• Hawk HP Plus brake pads (HB120N.560)
• New OEM rear brake calipers & rotors
• JNZ Tuning stainless braided brake line kit
• 3G Eclipse master cylinder w/ braided lines to prop valve
• JMF aluminum brake fluid reservoir cap
Mods I'm waiting to install:
Evo rocker arms
Gamble Garage aluminum coolant reservoir
Wish List:
XR DSM 61-56 ball bearing turbo
More time to work on my turd...
brett_pull3-png.323930
Here's 1837 looking all bare bones (August, 2011)
1837 after its first makeover by oldman tau (~December, 2011)
And here's 1837 since I've had it (July, 2014)
1837 @ East Coast MOD (October, 2014)
1837 @ Capitol Raceway (November, 2014)
13.6 Pass
13.8 Pass
June 2015 updates:
1837 @ Capitol Raceway again (August, 2015):
1837 @ East Coast MOD (October, 2015)
1837 @ Capitol Raceway (October & November, 2015)
12.8 pass
1837 @ Capitol Raceway (December, 2015)
1837 going 12.2
1837 @ East Coast MOD again (September, 2016)
6CHQdiamaxwFhWrYvJUe_a3E4-l6gVzyXlRa2SZasCYyTVAEmfBmXb0oAE5dGRBInKpmpTe974TzKOhqUZOySP_RTHzESIQMrVkyxGqJtTYqnAUuRnsdVZm8CeqYK9YjriBxiEzu8lylAyZLsweCzq8R72x2tGltucVH5we8EwU64l0Z_baeBVFOhszUjNpF-_T8IEj0wTGtp1QWYB9b7fh_RTVBXNqjFSk4fFH23a7ARoddhYN-P_YDARUxoBgz1cbseFNLtqjbSLkIuaT-kSu1LOI_PkUfSW3vThoooqBkTOGHxkn_W4Pd-cFrxCvtf6J2F6NOzm-vKXB2LcImiawaizhEMVZzXiuPBtUtSILl-hjX-2mrSGthwZQhi4uoyXUMYk8HsgllobwpTkUVQwmSBs9R-iXSejbG67klNwKe5rHmjcek6YUyvHlKnP_-lwhDshe-08bvLcaRQS_4s2O6lptLaFKotArbZakTgHzMJqntJND9w6L8RHPBhvzEsI5aXvhlRVduFQA8DDrQ_mTiblqCjobkUWJJTzBG05YInt8vzX7Jt7-eRa8AqOozNKN_Ux2UPrZUK1enE63ZRF4jKAuMcD_Y7KqU2PyTAASr6KVZoA=w514-h685-no
-Lkvfm5fDOfuxIjOsmddiRYaU0v8pf2bBS2MTwJBNaSDiZfG9IrR7IBJGOJn3e3YvWiHeTPok4Kc3Mpj9f_3pIuRzIEqGmdA6d_AOuax0Lw86RhP7v5qfryWIUy7nbQ7AmugrR9teLuPseczpFaj465le7aEHzC2g3cej08ArXmw66Hu7EvX9VL_biTtCbKlqzNB4Qp62rUxGm_T6UeNTjubtjVtxPqUo_1WsD5iuscL1ZuoiBeczynII5ylFYRcKTbP2Og6V-sZQjwFyC5sEtWh1SBdbfW7GFyN5OJcnFFbET7BXzD44PefbwTCjgA7RIb2Qg5NHEv55SkEmlnLwG1TSu6uJN5nvcsaZSMyEN1DsnrZ8E8SCy02FO6d7sqQsytsRakXp3yyxW_I-ZNVXP5C2ZLf7KRFzi6KdBDVyoII9rh6j5eqyB0tQ2PRqnSq8O56OM9V8WPCBhNAL-HKLsADBZgQYtrK5WCAuOAepCgZVi4V-qh_Gt2qVVyTdUG2tnUXjqTG2Yz94Z13MEPVyrFjUoSvAir2myxQPVcify5-UELIf-o1DX46OqY0oUHIff3RLEMWseEHN0ve1feuSwPBn-uI2OBx6XpGU9tLg-i366oGeQ=w914-h685-no
P3R-nH0U1UDRlGGTbOX0QXPanEv00EGnILuHx4MkskIDuvE2KoUJkP7LcHIEeetMVixrVnSV23CwKEOeSmEbUbXZL9j9j0mMfLPrFVnWyMCd7ipdGOW_ZCgQn6ivOIHR5MMRoBhEJ3hgcfTbTLu1tQONN99GRGN7wm1__0NPysbPKkUqp6BsuWPH9l8dyadl60-zX00pu60crj8z707pCAS_5EzSys7z_UdJn4nB91I2Xwb2mHiyNW8RQP6JOl3UG56bCxJdwmy1Lc4P6QJEe9MY-aihmezS-jFC4UIT6wvvnv8J1xTXbYUHqsj-4Zhr5ycs3EYcFCtpieEbg-Hy2ticv5SOPe9X2ZGpu7ptxSfWzjZMhGGu2XKdHa17WdAidH4HZRjbSZpD783FaXMb4HtLAimTe-zqwbJbIBkmK3g98flYhUPeQ2jkPDkyroFSqNpUbbdpOJh77Tv_WThGvPfWtQhsILKGKqjnkR1x5ksKQ3g9rZh8h8O09Cri7iFBuQtHuWJKJ_683zK4M5izj4fym9e22ATMygPscjSTl9EWtERRUr2Gm-UPNM7hGf0TM8JH2KSiCwkRj4cixLzK6TzV4Xgkwr45fm1JFUVlGCHRYjcKyQ=w914-h685-no
BYYBJXDEbTUmvc_9hKQs2h8OKtxfVTWUnUq0yIUiXkiycJbKPhdcdEeRCbS_fILC38XEE-HLyiYp4WwP4lZt8L0qkOnA-90s7En1JnlfPwKl6iaCHqzQA2yNiy2zCeg9P1K4OOck9IyL_S5o9QqGH4k0Ue2t_3msb4i9ezJ-9ibhZl__mgXPFyRTMJF29Hui6iG-qOeIRY0LddfXWFPOj6Oza_7H_eacsdyjDC3lCj6ndRpCjgHtPZu-kKcKGlRKLlKuPjvXV14RjbLdJA6qiW6Q83PQxRbiYbreffBtQb0j3rnybBSJJWOx3s1eUYyWvWfhHLzBmA4GfzoF30oG6QGSM2wCpPkNFGLG9G8vhmyEOkKNW4GWke6P3AjF12_68JcPBvr-imf8UxaMDnE9jnH_UhQwJi4tDjgdlIQS424icF3g2IlvEzPsJJuOhUipqPCnN0d7CQVWC0I5HvlcFhK8PbXaeCDiWQ-EN3hYuilgr1xoUTWTyV_q3QJSD5XYBmBqI2gyhxKaRcrqYd7mMZP-ESky1X8zcOrRjiaJS7zH9bE0tDgVWkq_Bt4S9SqDbqVWwPBabJi7-1im4UqPCyHiEdDlrBxRHK1hcYdtu_AHRFMG_A=w914-h685-no
qC3z-pENHjfD7jpP6kmg5bSNabglUIFLVKeLawLbaHmvwC4G7QDIrNdua5WD8Q2MldxIeZkfaWdUL2BtBpI_fQjR5sJd4sdQ702QL2tZAr_0tXAt4IZRbcxXRMwuBZ5FBoTJzIVE0aCHqXEDzKeZMMWBHQbAkNOTc-d4jrS3ZauRJL-x5miu1tkHUBLu7iVr2ZCBz7iZYUW19zypC-KcQN7vieLsDnnWHUz4v-BLlZG3ZVBTRRsv3B77bySHtfVxRwgFjUCR3UeX5UQpCZ5IcuumVZ_6JYYmAu8lsdpdX6HFE3ggoCYoRAPTS5F-MfTHLed8BJ_ZK3Lo3g3PTPNYnAIs-gd4oG-oyS356ouqymylG3bnxTt975Bb2wwJljbi9dZNsLO9EZKQHSv2qkmkGBrozpUKXzP613NYcgqyXjhsQK7iUnVIn_16faImFf1V3wVTyoQe0rsYSrLENHugy5zcJ8RRPgvw1a5g_S4aKGGvE7fwLYCjkAxsPEQy_eUTq1QIAcbzhzpuHdbA4MyJx4zN1w2YSvyME6-Crc1kEuqxUfBMxWJLfbYWxJmKDqJxhRWtY0Qv3YbAvgOrLLVwQ6WWdkXdHHff7UV9uSOHf5eJOV8EmA=w914-h685-no
uCD64QNH3TvDm4MnhwVcc9a6LOV052NhTS0X8oTFSLdRt7VOFEUHYwF81B_EfXoezTGh8Ok7KYiWn_8rlbm36iECnFr704vPnIIGR9nBgiaIQOVg_zyAHzqadrTOTmD-R9fS6JyxbWJ84xtk6ziyRWgYzT_Ia2Lw0GsvcdoqMl4CWhoZmP_CUWaGjXXN4HTiLwGgEKDZrUrO8YLhq_acfxTAO5fwc_428zGIYystj3owIxoBKkwAm4te_ptjIRCl6AZ6DyNPdHdi9ATMqR7-32hFVTVE_96xtEZMk0jeYUbOUSnASSo0eGACVaOKC4avpraBx3ue408aGHMJhM-cjJWLGBab7ApWXP-wplpvnyKGFEHLE61Jy9czgXWIP3jNbGiTM3wsFgx4ub3XohCM__Fx4gOUARHWVjhXW30m2c-HZFIUYQfFAdqv0RhY4D4QV9XI6J3UpMZQPtJECfrWGj9ZNLv-yWQPqEvQeoiNIKsSV9OlPfppt7gnhnI60sK6VmsE73DtAzZa6DJvZ5RoDvGxgFzKM2WCNGlyjEUtP0XsicFMeDUcdV8hyh1wES85sg7N57u-mc8VvrpIIwKvtH9yJd0FE9RJ_9WyOvUTz7Bd5p6lNg=w914-h685-no
xcgmsixwXNYZD4d1eWvFfCkgNGD-d6wFRcQMEn0SIeUDdGzbgadyhJz8L7BnNDei6_qBeBxyGdXF5xwlveBFaGPt9O8RyV09gFyXk6pRO9waNSGC-zOKpxCVZiYRhxk8DpeQesftbqTX_1Vy39PaK27l-PSS6udKhGVq_HUVW9ijJo2j-Cc46NSAbaQ7k60yk0_nU08CbsDgp5igOBYo6tL3LAVx3J3udIWsCAlVFuQgrMXwR79PmxgcUjRhuHFK9feqM6GUhAMKMKwBsbJRVNMIoOsUuJpXE-pRTjxkh6Kl0ieYblyd9mfm9-sdrz8aE1i6yhy6EWOEAdAPAbT9YIcCo9r_Imf4-hD0k8Xyt3m-j7BznxvhAEuNDTC0StHCU-ft_1RaUnpLDw9EPc2mfgWetgr7S5UqmsIkBhr4o0wiwbzCcs3qNVtBSY5W2wxst9hWZxX9nm00mAq6f-FP_gsIAmfTwRY1ysqNH6jlSPeUN2D4gvER4bVHi9IW1mQiM7IrofJV4vNHk-kPj4MmERUa3upKKxjR4PVhEmLK5mt3znVzLmsps2cK7PD-5g0sv0fKFZwQWncdJeAPCvVjMOV-ErfpJzUcdB9pnLWRDiN66LJKbA=w914-h685-no
Fall, 2016 updates:
omqPUBxWTGId1-YJgCFR_3NOzrUkFrFaDhXurHhMjJQTYFAobEt3UuRUHDj032mX33EEj9fVmNaO5sJTkfFsDMnlWhs-A1SXUy-yxyVQvGCCyih9NU00lwqSvuSnjXduqQHhEdLq03ARAsyLVvzKEl7OYgBViWlo-AaMKEdtWvblWTkQljs-wR3cF2XWbTypVVn-PMtiouvdJGJS3reDVMI-pvlxiwXfkFhFUKiBb3bMcj9U85PymIqwB4E1aQhQ4koZQhdxYkuKCG3gdYXaErq9at3yYLZZsw7cGVBdo7F9Lh6fOmxEWnUmS26m1M-YUq1SrISmszU3DleoAdzHWzS5LN86Ut85xQHLds2soawBUPw6vTzJ9g9LdIr0puh7VX503oDGGp_5-GDebFXGCVoSk2ioMCnsHmt6Duvof4H4doxDZfn2p1v2u3gYxMfVwqUj3eXDJjbya8ldocYehMwkBDerQnc_bMBidUZ_B4iee880TXEGmmAaE0jy9TYqO5qFzDS1qBGE6xgNz4H-kBNAlHEC1lj51GrCCQ7ox4UMN_HRISZJ_n2SoMTQvLU_eIFQJ5XCmVGycO2jsFjQb2uNO9x4HeGy=w1218-h685-no
1837 @ Capitol Raceway (April, 2017)
3n-xe03g6jjvadlqrmkndcyrnqosuqtyhfvqtbmukyd6bkhurll011owvqtq0xganpxxtnlxsznd5werfpe-w386-h685-no-jpg.331272
July, 2017 updates:
lvpozx1ialnisopkkq6htwmyncfsghytir3bkv0ynbpqcukqwymptmvgfhq15yxpdato1enwuvkyxfvd2g-w1218-h685-no-jpg.338226
05tnezpvzhwzrkvlmyolqyscjvnw-bmkekgls5rxhkc99yhytpyi9mjtdm2nrhh4ewoqmtcbbyi3htl6e4-w1218-h685-no-jpg.338227
xnkpfs2jw6-0plowpzhmhayv37rm-vxzbowe8olrcmw1zz6-u7w4cknoez_fpuje2mhz2mjcyorjblsqag-w1218-h685-no-jpg.338228
ysak4govqcsx3yoducjjyzw-b48-tqwvawt6upu-dcu-kxerbrwq4txfsm9y2ctm00cf2d7gcixqprye-w1218-h685-no-jpg.338229
bnepdennkdfeobtz6epwcvoyhudidieeit_dohe711hso945-o-vrxjzafkwbaa1akfyoy6hetp3g6ag2m-w1218-h685-no-jpg.338230
