Galant VR-4 Forums » Community » Members' Showcase » VR4PLAY'S VR-4 Auto-x car
vr4play
handles best on 3 tires
816/1000
Galant VR-4 org Post #: 1093789 posted 11/13/12 12:57 AM     Remind Me!  Send Private Message   Edit Post
Mods
Engine:
JE 8.5:1 Pistons 0.20 over ceramic and moly coated
Manley turbo tuff Rods
Total Seal RIngs
Fel-Pro perma-torque MLS Headgasket
ACL Race Bearings
All ARP Hardware
Ported & Polished 2G Head with Ferrara valves and Crower springs and reatainers
HKS 264 Cams, Fidanza Cam gears
Turbonetics T304E 50 Trim BB turbo w/stg2 Exhaust and Bullseye power housing
Tial mvs Wastegate with MAP O2 Housing
2.5" DP with 3" custom cat back
Extrude Honed Intake and exhaust manifold
Earls oil cooler
Custom Front mount and piping
Fuel:
255lph In-tank pump
034 Motorsports 044 surge tank with Bosch 044 pump.
Holly E85 safe -6 HIgh flow 10 micron filter
-6 Braided fuel lines
AEM fuel pressure regulator
PTE 1200cc injectors
Drivetrain:
Dbl syncro Evo III 1st & 2nd
TRE 4 spider center diff
Southbend stage 4 clutch with ceramic disc
Evo 9 Rear Diff
Suspension:
Koni 8611 race shocks with custom housings 2g custom valved rear shocks
Ground Control coilovers with custom spring rates
Whiteline 24mm rear sway bar and 21mm front bar
Poly control arm and subframe bushes
Rear active toe eliminator kit
Misc:
Rota 17x9.5 ET 12
Corbeau FX1 Race seats
Dsmlink V3
JCS Dual inlet catch can
Evo III Radiator w/custom mounts
Custom Big brake kit
Edited by vr4play (05/11/15 07:23 PM)
Posts: 396 | From: Cincinnati, Ohio | Member Since: 02/07/08 | IP: (174.101.174.53) | Report this post to a Moderator
0 registered and 0 anonymous users are browsing this forum.
Rating: **
Generated in 0.078 seconds in which 0.054 seconds were spent on a total of 14 queries. Turbo powered.
