Galant VR-4 Forums » Marketplace » Parts For Sale » FS: '91 Gvr4 Partout (xxxx/2000) SW *Updated June 19, 2020
pot Galant VR4.org Moderator
182/1000
Galant VR-4 org Post #: 871018 posted 02/04/10 11:29 AM     Remind Me!  Send Private Message   Edit Post
For sale are stock parts removed from a 158K Summit White. Everything offered is in used but serviceable condition.
All parts prices include PayPal fees & Shipping Costs for CONUS based transactions. I accept all payments via PayPal to: [email protected]
If interested please contact me via PM or mobile no (910) 689-6150. Thank you for looking!
ENGINE
Engine Mount Bracket (Rear) $20.00
Intake Manifold Support Bracket $15.00
Alternator Bracket $5.00
Cam Gear $15.00
Crank Pulley Bolt & Washer $5.00 *2 available
Crankshaft Sprocket B $10.00
Flange $3.00
Silent Shaft Sprocket $8.00 each
Water Pump Pulley Set $15.00
Throttlebody Ground Tab $3.00
Spark Plug Wire Guide $3.00 each
Aircan Vacuum Line Mounting Bracket $15.00
EGR Valve *3 Galant/1g Available $15.00
Alternator Relay part no MD113566 $5.00
Alternator Pivot Bolt $3.00
Oil Cap $8.00 each *3 Available
Fuel Pressure Regulator *1g Non-Turbo $15.00
Fuel Filter Banjo Bolt $3.00
Banjo Bolt (Oil Feed on Turbo) $3.00 each
Banjo Bolt (Coolant Feed/Drain) $3.00 each
Fuel Purge Control Solenoid $20.00
Fuel Purge Solenoid Valve w/ Wiring $20.00
Fuel Pressure Solenoid Valve Wiring $8.00
EGR Control Solenoid Wiring $12.00
Oil Squirter Check Valve $8.00
Fuse Box Fuse *Complete set for engine bay $5.00
02 Sensor Housing Gasket $3.00
BODY
Headlight Relay part no MB183865 $5.00 each
Corner Lamp Spring $5.00
Lower Radiator Hose Clamps $1.00 each
Washer Reservoir Hardware Set $2.00
Hood Switch (Alarm) *Rubber cracked $3.00
Washer Fluid Nozzle $1.00
Cowl Vent (Passenger Side) $10.00
Trim Panel (Passenger Side) $3.00
Fender Bolts *Summit White $3.00
Horn $8.00
A/C Condenser High Relay $5.00
MAF Intake Hose Clamp $2.00 each
ECU Harness Retainer $3.00
Timer, Defogger Delay part no MB572253 $3.00
Fuel Filter Bracket *2 Available $3.00 each
EGR Line Retainer $1.00 each
Downpipe Mount $3.00
Exhaust Hardware $1.50
Radiator Bracket Bolt Set $1.00
Door Rubber Molding (Body Side) *Set of all four doors $50.00, or $20.00 each
Side Skirt Hardware Set $2.00
Wheel Well Retainer $.50 each
Galant GSX 3rd Brake Light $20.00
Fuel Door Hardware $1.00
Fuel Door Lock Cylinder Retainer $.50
Tailight Cover (Left Side) $10.00
Tail Light Center Section *Passenger side, slight crack $12.00
License Plate Lights $15.00 for pair
Trunk Lid Bracket $10.00 for pair
Trunk Molding $20.00
Fuel Pump Cover $10.00
Trunk Striker $3.00
Trunk Striker Bolts $2.00
Trunk Grommet $1.00 for pair
Rear Bumper Mounting Bracket Set $10.00
INTERIOR
ALDL Cable $25.00
Fuse Panel $20.00
Fuse Puller (Interior Fuse Block) $1.00
Footwell Carpet Clip Set $2.00
Hood Release Assembly $15.00
Dash Speaker Cover $15.00 *For pair
Defogger Switch $ 15.00
Driverside Visor *Mirror cover unattached $15.00
Dome Light *Sunroof model $40.00
Sunroof Control Motor *part no MB549075 $20.00
Sunroof Power Relay part no MB627895 $5.00
Sunroof Adjust Plate $1.00 Each
Radio Antenna Cable $15.00
Buzzer Switch, part no MB802356 $5.00
Ashtray Cover $2.00
HVAC Selector Tab $1.00
HVAC Vent Tab $1.00
Door Card Handle $5.00 each
Door Handle Cover *Rear Driver side sold $3.00 each
Door Light with lens $5.00
Door Sensor $5.00
Control Unit, Door part no MB543647 $10.00
Driver Window Switch Cover $5.00 each
Driver Window Switch Cover $1.00
Control Unit Auto Seat *Part No MB617345 $2500
Window Switch $10.00 each
Scuff Plate Hardware $2.00
Armrest Stay $15.00
Arm Rest Hardware $1.00
Seat Trim Bolt Cover $1.50 each or $20.00 for full set
Rear Door Ashtray $3.00 (Each)
Trunk Trim Access $8.00
Tool Bag $5.00 each
SUSPENSION & STEERING
P/S Mounting Bracket $5.00
P/S Pump Mounting Hardware Set $2.00
P/S Heat Shield $5.00
Cruise Control Cable mount *Mounted on Passenger Side $2.00
Front Control Arm to Subframe Bolts $5.00 *Per pair
Axle Carrier Bracket Bolt w/ washer Set $5.00 each
Front Subframe Lower Plate & Stopper $5.00
Gusset Plate Bolt Set $8.00
Connector *4WS, mounts on steering rack $3.00
4WS Plug *Off the shelf fastener for use in eliminating 4WS $3.00
Front Steering Rack Brackets $15.00
P/S Line Bracket $3.00
P/S Reservoir Mount Bracket $3.00
Upper Rear Control Arm *Only Passenger Side Left $25.00
Rear Suspension Mount Bolt *1 left $7.00
Rear Camber Bolt Set $8.00 *For pair
DRIVETRAIN
Speedo Gear $20.00 each
Shifter Cable Clip $.75 each *2 left
Transfercase Hardware 5 Piece Set $12.00 *1 bolt not pictured
Pressure Plate Hardware Set $2.00
Rear Main Seal Cover $10.00
Driveshaft Hardware Set $3.00
Slave Cylinder Mounting Hardware $1.00
Shifter Bracket $10.00
Shifter Bracket Mount Hardware (Lower) $1.00
Shifter Bracket Mount Hardware (Upper) $1.00
Transmission Mount Hardware $2.00
Transmission Vent Plug Set $1.00
Transfercase Fill Plug $1.00
Rear Differential Bolt Set $5.00
BRAKES
Parking Brake Adjustment Retainer $3.00
ABS Electronic Control Unit $40.00
ABS G Sensor (Rear) $20.00
ABS Sensor Mount (Front) $3.00
ABS Ring (front) $20.00
ABS Dust Shield $20.00
Parking Brake Stay $5.00
Brake Fluid Level Sensor Wiring $5.00
Brake Fluid Reservoir $15.00
Brake Bleeder Screws $1.00
Brake Caliper Brackets (Rear) *Powdercoated Gloss Black $20.00 for pair
Brake Pedal Return Spring *2 available $1.00
Brake Line Clip $.50 each
Brake Line Separator *Driver side fender $1.00
Brake Line Separator $1.00 each
Brake Caliper Guide/Lock Pine Set (Front) *2g, For 1 side $10.00
[email protected] [email protected]
182/1000
Edited by pot (06/27/20 04:52 PM)
Posts: 1524 | From: Fayetteville, NC | Member Since: 10/28/03 | IP: (75.178.25.93) | Report this post to a Moderator
Galant VR-4 org Post #: 871493 posted 02/05/10 09:52 PM     Remind Me!  Send Private Message   Edit Post
PM sent.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10770 | From: Michigan | Member Since: 03/05/01 | IP: (74.47.152.165) | Report this post to a Moderator
Galant VR-4 org Post #: 874015 posted 02/13/10 07:32 PM     Remind Me!  Send Private Message   Edit Post
Bump for a good guy.
Posts: 10770 | From: Michigan | Member Since: 03/05/01 | IP: (74.47.152.252) | Report this post to a Moderator
momax
Galant VR-4 org Post #: 874109 posted 02/14/10 04:44 AM     Remind Me!  Send Private Message   Edit Post
pm sent. thanks
| | | IP: (120.28.64.70) | Report this post to a Moderator
stevetford
Galant VR-4 org Post #: 876487 posted 02/22/10 06:22 PM     Remind Me!  Send Private Message   Edit Post
Quoting Pot:
For sale are several stock parts removed from a 158K summit white '91 gvr4. Shipping and paypal charges have been included hence my prices. Shipping charges for OCONUS transactions will be handled on a case by case basis.
I will be continually adding parts over the next twenty-four hours therefore if you don't see something your interested in feel free to PM me.
First PM first served and thank you for your time.
28.) TURBO WATER PIPE *2 AVAILABLE $20.00
Looks like the water pipe in the background is a non turbo pipe. If this is true I will take it. PM sent
| | | IP: (67.216.122.49) | Report this post to a Moderator
Gizmovr4
Member +
431/1000
584/1000
Galant VR-4 org Post #: 877563 posted 02/25/10 08:43 PM     Remind Me!  Send Private Message   Edit Post
PM sent
Nate Crisman Racing www.performancepartout.com
Vinny Ten Racing click
431/1000 [email protected] 584/1000 556AWHP
Posts: 366 | From: andover,NJ | Member Since: 11/18/09 | IP: (75.97.91.50) | Report this post to a Moderator
momax
Galant VR-4 org Post #: 878640 posted 03/01/10 09:41 PM     Remind Me!  Send Private Message   Edit Post
payment sent! thanks again.
| | | IP: (120.28.64.75) | Report this post to a Moderator
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 878684 posted 03/02/10 05:12 AM     Remind Me!  Send Private Message   Edit Post
PM me a Price shipped to 18960 in PA for the black cover CAS. Thanks!
91 #108/2000- link
97 Kawi ZX7R Street / 03 ZX6R Track
03 Kawi KLX400R Supermoto
05 CTS-V
09 Hummer H3T
Posts: 1630 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (68.80.109.52) | Report this post to a Moderator
a2vr4
Boot Strap Bill's boy
Galant VR-4 org Post #: 878717 posted 03/02/10 10:13 AM     Remind Me!  Send Private Message   Edit Post
trunk/gas popper sold
~Brian A. Moreno
91 Galant GSX auto green
582/2000 Belize Green crushed
92 Expo sp 2wd auto white crushed
@garagemoreno
Posts: 1543 | From: Ann Arbor MI | Member Since: 08/13/05 | IP: (76.226.106.217) | Report this post to a Moderator
esleepy
Galant VR-4 org Post #: 878806 posted 03/02/10 06:43 PM     Remind Me!  Send Private Message   Edit Post
PM for clock sent.
| | | IP: (216.58.143.224) | Report this post to a Moderator
onesickcrx
Brother of the Year
449/2000
Galant VR-4 org Post #: 880364 posted 03/08/10 09:59 PM     Remind Me!  Send Private Message   Edit Post
Whats up with the strut bars are they for sale
Lack of boost
Posts: 1076 | From: NY | Member Since: 06/03/07 | IP: (68.193.45.104) | Report this post to a Moderator
BoostedAWD91
815/2000
Galant VR-4 org Post #: 880397 posted 03/08/10 11:29 PM     Remind Me!  Send Private Message   Edit Post
pm sent on black top cas and paint
#815/2000- Lexus Pearl White
Edited by BoostedAWD91 (03/08/10 11:29 PM)
Posts: 2937 | From: Danville,Pa | Member Since: 03/01/07 | IP: (71.181.147.147) | Report this post to a Moderator
KiNgMaRtY
Member +++
802/1000
Galant VR-4 org Post #: 881124 posted 03/10/10 11:52 PM     Remind Me!  Send Private Message   Edit Post
What kind of condition is the power steering rack in? Mileage? Complete with tie rods? PS pump? Do you have the hose the goes from the fuel door to the tank?
PM me if you do
92 GVR4 #802 link
17 CTS-V,06 Evo IX MR, 98 Montero
94 MX5 M-Edition - On Xidas, LS1 Swap in progress
SOLD: 92 GVR4 #611
Posts: 793 | From: Corona, CA | Member Since: 04/08/08 | IP: (76.171.207.31) | Report this post to a Moderator
momax
Galant VR-4 org Post #: 882446 posted 03/16/10 07:48 AM     Remind Me!  Send Private Message   Edit Post
got the package!:D bump for a great guy!
| | | IP: (120.28.64.77) | Report this post to a Moderator
AWDnoobie
129/2000
Galant VR-4 org Post #: 885362 posted 03/27/10 05:55 PM     Remind Me!  Send Private Message   Edit Post
Im interested in the engine mounts 345, 346 and 347.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Posts: 112 | From: Alberta, Canada | Member Since: 01/13/10 | IP: (68.150.162.61) | Report this post to a Moderator
weed831
Galant VR-4 org Post #: 885631 posted 03/28/10 10:24 PM     Remind Me!  Send Private Message   Edit Post
I'm interested in the coolant overflow. How much shipped to 85714?
| | | IP: (68.104.212.129) | Report this post to a Moderator
AWDnoobie
129/2000
Galant VR-4 org Post #: 887267 posted 04/04/10 12:47 PM     Remind Me!  Send Private Message   Edit Post
Hey Pot, do you still have the rear steering rack? If so what kind of shape is it in, looks kind of rusty in the picture. Id like to get a 2nd one to rebuild
EvoMR15
Galant VR-4 org Post #: 908144 posted 06/16/10 09:45 PM     Remind Me!  Send Private Message   Edit Post
Hey bro do you still have the vr-4 emblem???????????
| | | IP: (98.148.175.86) | Report this post to a Moderator
EvoMR15
Galant VR-4 org Post #: 908145 posted 06/16/10 09:47 PM     Remind Me!  Send Private Message   Edit Post
IF you still have the emblem email me at [email protected] plz
chrisfullwood
Member +
Galant VR-4 org Post #: 910386 posted 06/25/10 12:55 AM     Remind Me!  Send Private Message   Edit Post
Do you still have the air conditioning system on the car? if so does it work, if not, is it complete and how much thanks.
Chris
Sarcasm, is the bodies natural defense against stupid.
Posts: 256 | From: bartlesville, ok | Member Since: 04/28/06 | IP: (209.236.250.213) | Report this post to a Moderator
EvoMR15
Galant VR-4 org Post #: 912157 posted 07/02/10 03:11 AM     Remind Me!  Send Private Message   Edit Post
Do you still have the vr4 emblem
EvoMR15
Galant VR-4 org Post #: 912158 posted 07/02/10 03:11 AM     Remind Me!  Send Private Message   Edit Post
Email at [email protected]
or pm
RJ_P
Newbie
Galant VR-4 org Post #: 917752 posted 07/25/10 12:08 AM     Remind Me!  Send Private Message   Edit Post
Hey, sent payment already for antenna assembly.. Please confirm.
Posts: 21 | From: Philippines and California | Member Since: 01/14/10 | IP: (112.203.63.188) | Report this post to a Moderator
92Galant926
Galant VR-4 org Post #: 918066 posted 07/26/10 03:14 PM     Remind Me!  Send Private Message   Edit Post
pm'ed
| | | IP: (192.174.37.50) | Report this post to a Moderator
mayat
Galant VR-4 org Post #: 922105 posted 08/11/10 07:44 PM     Remind Me!  Send Private Message   Edit Post
hyundai valve cver still available??pm sent
| | | IP: (202.184.60.101) | Report this post to a Moderator
Pages: 1 | 2 | 3 | 4 | 5
Galant VR4.org Moderator:  4orced4door, curtis, steve, atc250r, jcgalntvr4-244, cheekychimp, jepherz, Rausch, toybreaker, G, iceman69510, pot
Rating: **
Generated in 0.158 seconds in which 0.118 seconds were spent on a total of 14 queries. Turbo powered.
